[GRASS-SVN] r70291 - grass/branches/releasebranch_7_2/raster/r.in.xyz
svn_grass at osgeo.org
Sat Jan 7 09:08:32 PST 2017
Author: martinl
Date: 2017-01-07 09:08:32 -0800 (Sat, 07 Jan 2017)
New Revision: 70291
grass/branches/releasebranch_7_2/raster/r.in.xyz/main.c
grass/branches/releasebranch_7_2/raster/r.in.xyz/r.in.xyz.html
r.in.xyz: hide interactive input in GUI
output not required when -s or -g flag given
update manual, link other modules
(merge r70290 from trunk)
Modified: grass/branches/releasebranch_7_2/raster/r.in.xyz/main.c
--- grass/branches/releasebranch_7_2/raster/r.in.xyz/main.c 2017-01-07 16:58:07 UTC (rev 70290)
+++ grass/branches/releasebranch_7_2/raster/r.in.xyz/main.c 2017-01-07 17:08:32 UTC (rev 70291)
@@ -164,12 +164,12 @@
module->description =
_("Creates a raster map from an assemblage of many coordinates using univariate statistics.");
- input_opt = G_define_standard_option(G_OPT_F_INPUT);
+ input_opt = G_define_standard_option(G_OPT_F_BIN_INPUT);
input_opt->description =
_("ASCII file containing input data (or \"-\" to read from stdin)");
output_opt = G_define_standard_option(G_OPT_R_OUTPUT);
method_opt = G_define_option();
method_opt->key = "method";
method_opt->type = TYPE_STRING;
@@ -179,11 +179,34 @@
"n,min,max,range,sum,mean,stddev,variance,coeff_var,median,percentile,skewness,trimmean";
method_opt->answer = "mean";
method_opt->guisection = _("Statistic");
+ G_asprintf((char **)&(method_opt->descriptions),
+ "n;%s;"
+ "min;%s;"
+ "max;%s;"
+ "range;%s;"
+ "sum;%s;"
+ "mean;%s;"
+ "stddev;%s;"
+ "variance;%s;"
+ "coeff_var;%s;"
+ "median;%s;"
+ "percentile;%s;"
+ "skewness;%s;"
+ "trimmean;%s",
+ _("Number of points in cell"),
+ _("Minimum value of point values in cell"),
+ _("Maximum value of point values in cell"),
+ _("Range of point values in cell"),
+ _("Sum of point values in cell"),
+ _("Mean (average) value of point values in cell"),
+ _("Standard deviation of point values in cell"),
+ _("Variance of point values in cell"),
+ _("Coefficient of variance of point values in cell"),
+ _("Median value of point values in cell"),
+ _("Pth (nth) percentile of point values in cell"),
+ _("Skewness of point values in cell"),
+ _("Trimmed mean of point values in cell"));
- type_opt = G_define_standard_option(G_OPT_R_TYPE);
- type_opt->required = NO;
- type_opt->answer = "FCELL";
delim_opt = G_define_standard_option(G_OPT_F_SEP);
delim_opt->guisection = _("Input");
@@ -266,6 +289,11 @@
vscale_opt->description = _("Scale to apply to alternate value column data");
vscale_opt->guisection = _("Advanced Input");
+ type_opt = G_define_standard_option(G_OPT_R_TYPE);
+ type_opt->required = NO;
+ type_opt->answer = "FCELL";
+ type_opt->guisection = _("Output");
percent_opt = G_define_option();
percent_opt->key = "percent";
percent_opt->type = TYPE_INTEGER;
@@ -281,7 +309,7 @@
pth_opt->type = TYPE_INTEGER;
pth_opt->required = NO;
pth_opt->options = "1-100";
- pth_opt->description = _("pth percentile of the values");
+ pth_opt->description = _("Pth percentile of the values");
pth_opt->guisection = _("Statistic");
trim_opt = G_define_option();
@@ -296,16 +324,24 @@
scan_flag = G_define_flag();
scan_flag->key = 's';
scan_flag->description = _("Scan data file for extent then exit");
+ scan_flag->guisection = _("Scan");
+ scan_flag->suppress_required = YES;
shell_style = G_define_flag();
shell_style->key = 'g';
shell_style->description =
_("In scan mode, print using shell script style");
+ shell_style->guisection = _("Scan");
+ shell_style->suppress_required = YES;
skipline = G_define_flag();
skipline->key = 'i';
skipline->description = _("Ignore broken lines");
+ G_option_required(output_opt, scan_flag, shell_style, NULL);
+ G_option_requires(scan_flag, input_opt, NULL);
+ G_option_requires(shell_style, input_opt, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/branches/releasebranch_7_2/raster/r.in.xyz/r.in.xyz.html
--- grass/branches/releasebranch_7_2/raster/r.in.xyz/r.in.xyz.html 2017-01-07 16:58:07 UTC (rev 70290)
+++ grass/branches/releasebranch_7_2/raster/r.in.xyz/r.in.xyz.html 2017-01-07 17:08:32 UTC (rev 70291)
@@ -7,7 +7,7 @@
<p>
Please note that the current region extents and resolution are used for
-the import. It is therefore recommended to first use the <em>-s</em>
+the import. It is therefore recommended to first use the <b>-s</b>
flag to get the extents of the input points to be imported, then
adjust the current region accordingly, and only then proceed with the
actual import.
@@ -19,7 +19,7 @@
<!-- Doug Newcomb, US Fish & Wildlife Service -->
<p>
-Available statistics for populating the raster are:
+Available statistics for populating the raster are (<b>method</b>):
<p>
<blockquote>
<table>
@@ -65,9 +65,9 @@
data points fall within the center of a cell, as opposed to the grid-node
convention. Therefore you will need to grow the region out by half a cell
in all directions beyond what the scan found in the file. After the region
-bounds and resolution are set correctly with <em>g.region</em>, run
+bounds and resolution are set correctly with <em><a href="g.region.html">g.region</a></em>, run
<em>r.in.xyz</em> using the <i>n</i> method and verify that n=1 at all places.
-<em>r.univar</em> can help. Once you are confident that the region exactly
+<em><a href="r.univar.html">r.univar</a></em> can help. Once you are confident that the region exactly
matches the data proceed to run <em>r.in.xyz</em> using one of the <i>mean,
min, max</i>, or <i>median</i> methods. With n=1 throughout, the result
should be identical regardless of which of those methods are used.
@@ -102,8 +102,8 @@
You can use the <b>-s</b> scan flag to find the extent of the input data
(and thus point density) before performing the full import. Use
-<em>g.region</em> to adjust the region bounds to match. The <b>-g</b> shell
-style flag prints the extent suitable as parameters for <em>g.region</em>.
+<em><a href="g.region.html">g.region</a></em> to adjust the region bounds to match. The <b>-g</b> shell
+style flag prints the extent suitable as parameters for <em><a href="g.region.html">g.region</a></em>.
A suitable resolution can be found by dividing the number of input points
by the area covered. e.g.
@@ -121,8 +121,8 @@
</pre></div>
<p>
-If you only intend to interpolate the data with <em>r.to.vect</em> and
-<em>v.surf.rst</em>, then there is little point to setting the region
+If you only intend to interpolate the data with <em><a href="r.to.vect.html">r.to.vect</a></em> and
+<em><a href="v.surf.rst.html">v.surf.rst</a></em>, then there is little point to setting the region
resolution so fine that you only catch one data point per cell -- you might
as well use "<tt>v.in.ascii -zbt</tt>" directly.
@@ -132,14 +132,14 @@
Points falling outside the current region will be skipped. This includes
points falling <em>exactly</em> on the southern region bound.
(to capture those adjust the region with "<tt>g.region s=s-0.000001</tt>";
-see <em>g.region</em>)
+see <em><a href="g.region.html">g.region</a></em>)
<p>Blank lines and comment lines starting with the hash symbol (<tt>#</tt>)
will be skipped.
<p>
The <b>zrange</b> parameter may be used for filtering the input data by
vertical extent. Example uses might include preparing multiple raster
-sections to be combined into a 3D raster array with <em>r.to.rast3</em>, or
+sections to be combined into a 3D raster array with <em><a href="r.to.rast3.html">r.to.rast3</a></em>, or
for filtering outliers on relatively flat terrain.
<p>
@@ -150,10 +150,10 @@
<p>
The user can use a combination of <em>r.in.xyz</em> <b>output</b> maps to create
-custom filters. e.g. use <em>r.mapcalc</em> to create a <tt>mean-(2*stddev)</tt>
+custom filters. e.g. use <em><a href="r.mapcalc.html">r.mapcalc</a></em> to create a <tt>mean-(2*stddev)</tt>
map. [In this example the user may want to include a lower bound filter in
-<em>r.mapcalc</em> to remove highly variable points (small <em>n</em>) or run
-<em>r.neighbors</em> to smooth the stddev map before further use.]
+<em><a href="r.mapcalc.html">r.mapcalc</a></em> to remove highly variable points (small <em>n</em>) or run
+<em><a href="r.neighbors.html">r.neighbors</a></em> to smooth the stddev map before further use.]
<h3>Alternate value column</h3>
@@ -171,7 +171,7 @@
<h3>Reprojection</h3>
If the raster map is to be reprojected, it may be more appropriate to reproject
-the input points with <em>m.proj</em> or <em>cs2cs</em> before running
+the input points with <em><a href="m.proj.html">m.proj</a></em> or <em>cs2cs</em> before running
<em>r.in.xyz</em>.
@@ -179,11 +179,11 @@
The vector engine's topographic abilities introduce a finite memory overhead
per vector point which will typically limit a vector map to approximately
-3 million points (~ 1750^2 cells). If you want more, use the <em>r.to.vect</em>
+3 million points (~ 1750^2 cells). If you want more, use the <em><a href="r.to.vect.html">r.to.vect</a></em>
<b>-b</b> flag to skip building topology. Without topology, however, all
-you'll be able to do with the vector map is display with <em>d.vect</em> and
-interpolate with <em>v.surf.rst</em>.
-Run <em>r.univar</em> on your raster map to check the number of non-NULL cells
+you'll be able to do with the vector map is display with <em><a href="d.vect.html">d.vect</a></em> and
+interpolate with <em><a href="v.surf.rst.html">v.surf.rst</a></em>.
+Run <em><a href="r.univar.html">r.univar</a></em> on your raster map to check the number of non-NULL cells
and adjust bounds and/or resolution as needed before proceeding.
<p>
@@ -226,7 +226,7 @@
# The point distance is 15m here.
# detect extent, print result as g.region parameters
-r.in.xyz input=elevation.xyz separator=space -s output=dummy -g
+r.in.xyz input=elevation.xyz separator=space -s -g
# ... n=228492.5 s=215007.5 e=644992.5 w=630007.5 b=55.578793 t=156.32986
# set computational region, along with the actual raster resolution
@@ -251,7 +251,7 @@
<div class="code"><pre>
# scan and set region bounds
-r.in.xyz -s separator="," in=lidaratm2.txt out=test
+r.in.xyz -s separator="," in=lidaratm2.txt
g.region n=35.969493 s=35.949693 e=-75.620999 w=-75.639999
g.region res=0:00:00.075 -a
@@ -259,7 +259,7 @@
r.in.xyz in=lidaratm2.txt out=lidar_n separator="," method=n zrange=-2,50
# check point density [rho = n_sum / (rows*cols)]
-r.univar lidar_n | grep sum
+r.univar lidar_n
# create "min" map (elevation filtered for premature hits)
r.in.xyz in=lidaratm2.txt out=lidar_min separator="," method=min zrange=-2,50
@@ -267,7 +267,7 @@
g.region n=35:57:56.25N s=35:57:13.575N w=75:38:23.7W e=75:37:15.675W
# check number of non-null cells (try and keep under a few million)
-r.univar lidar_min | grep '^n:'
+r.univar lidar_min
# convert to points
r.to.vect -z type=point in=lidar_min out=lidar_min_pt
@@ -291,10 +291,6 @@
<tt>method=string[,string,...] output=name[,name,...]</tt><br>
This can be easily handled by a wrapper script, with the added
benefit of it being very simple to parallelize that way.
-<li> Add two new flags for support for direct binary input from libLAS
- for LIDAR data and MB-System's mbio for multi-beam bathymetry data.
- <!-- Bob Covill has supplied patches for MBIO interface already -->
- <br><i>note</i>: See the new <em>r.in.lidar</em> module for this.
</ul>
@@ -345,10 +341,7 @@
<h2>AUTHORS</h2>
-Hamish Bowman<br> <i>
-Department of Marine Science<br>
-University of Otago<br>
-New Zealand</i><br>
+Hamish Bowman, Department of Marine Science, University of Otagom New Zealand
<br>
Extended by Volker Wichmann to support the aggregate functions
<i>median, percentile, skewness</i> and <i>trimmed mean</i>.
