[GRASS-SVN] r70300 - grass/trunk/general/g.region
svn_grass at osgeo.org
Sun Jan 8 06:11:58 PST 2017
Author: martinl
Date: 2017-01-08 06:11:58 -0800 (Sun, 08 Jan 2017)
New Revision: 70300
grass/trunk/general/g.region/Makefile
grass/trunk/general/g.region/main.c
g.region: support also vectors with no topology
Modified: grass/trunk/general/g.region/Makefile
--- grass/trunk/general/g.region/Makefile 2017-01-08 12:25:46 UTC (rev 70299)
+++ grass/trunk/general/g.region/Makefile 2017-01-08 14:11:58 UTC (rev 70300)
@@ -2,8 +2,8 @@
PGM = g.region
-LIBES = $(GPROJLIB) $(VECTORLIB) $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
-DEPENDENCIES = $(GPROJDEP) $(VECTORDEP) $(RASTER3DDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(GPROJLIB) $(VECTORLIB) $(DIG2LIB) $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
+DEPENDENCIES = $(GPROJDEP) $(VECTORDEP) $(DIG2DEP) $(RASTER3DDEP) $(RASTERDEP) $(GISDEP)
EXTRA_INC = $(VECT_INC) $(PROJINC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c 2017-01-08 12:25:46 UTC (rev 70299)
+++ grass/trunk/general/g.region/main.c 2017-01-08 14:11:58 UTC (rev 70300)
@@ -475,20 +475,63 @@
temp_window = window;
- Vect_set_open_level(2);
- if (2 > Vect_open_old_head(&Map, vect_name, mapset))
- G_fatal_error(_("Unable to open vector map <%s> on topological level"),
- vect_name);
+ /* try to open head-only on level 2 */
+ if (Vect_open_old_head(&Map, vect_name, mapset) < 2) {
+ /* force level 1, open fully */
+ Vect_close(&Map);
+ Vect_set_open_level(1); /* no topology */
+ if (Vect_open_old(&Map, vect_name, mapset) < 1)
+ G_fatal_error(_("Unable to open vector map <%s>"),
+ vect_name);
- Vect_get_map_box(&Map, &box);
- map_window = window;
- map_window.north = box.N;
- map_window.south = box.S;
- map_window.west = box.W;
- map_window.east = box.E;
- map_window.top = box.T;
- map_window.bottom = box.B;
+ if (Vect_level(&Map) > 1) {
+ /* topology available */
+ Vect_get_map_box(&Map, &box);
+ else {
+ /* no topology
+ NOTE: number of points, lines, boundaries,
+ centroids, faces, kernels is still available */
+ int type;
+ int first = TRUE;
+ struct line_pnts *Points;
+ struct bound_box line_box;
+ Points = Vect_new_line_struct();
+ Vect_rewind(&Map);
+ G_message(_("Topology not available for vector map <%s>. "
+ "Registering primitives..."), vect_name);
+ while (TRUE) {
+ /* register line */
+ type = Vect_read_next_line(&Map, Points, NULL);
+ if (type == -1) {
+ G_fatal_error(_("Unable to read vector map"));
+ else if (type == -2) {
+ break;
+ dig_line_box(Points, &line_box);
+ if (first == TRUE) {
+ Vect_box_copy(&box, &line_box);
+ first = FALSE;
+ else
+ Vect_box_extend(&box, &line_box);
+ Vect_destroy_line_struct(Points);
+ map_window = window;
+ map_window.north = box.N;
+ map_window.south = box.S;
+ map_window.west = box.W;
+ map_window.east = box.E;
+ map_window.top = box.T;
+ map_window.bottom = box.B;
if (!first) {
window = map_window;
first = 1;
