[GRASS-SVN] r70310 - in grass-addons/grass7/imagery: . i.in.probav
svn_grass at osgeo.org
Mon Jan 9 01:42:35 PST 2017
Author: stjo
Date: 2017-01-09 01:42:35 -0800 (Mon, 09 Jan 2017)
New Revision: 70310
Added:
grass-addons/grass7/imagery/i.in.probav/
grass-addons/grass7/imagery/i.in.probav/Makefile
grass-addons/grass7/imagery/i.in.probav/i.in.probav.html
grass-addons/grass7/imagery/i.in.probav/i.in.probav.py
grass-addons/grass7/imagery/Makefile
i.in.probav addon: script to import PROBA-V NDVI
Modified: grass-addons/grass7/imagery/Makefile
--- grass-addons/grass7/imagery/Makefile 2017-01-08 18:23:48 UTC (rev 70309)
+++ grass-addons/grass7/imagery/Makefile 2017-01-09 09:42:35 UTC (rev 70310)
@@ -17,6 +17,7 @@
i.gcp \
i.gravity \
i.histo.match \
+ i.in.probav \
i.lmf \
i.points.auto \
i.rotate \
Added: grass-addons/grass7/imagery/i.in.probav/Makefile
--- grass-addons/grass7/imagery/i.in.probav/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.in.probav/Makefile 2017-01-09 09:42:35 UTC (rev 70310)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.in.probav
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/imagery/i.in.probav/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/imagery/i.in.probav/i.in.probav.html
--- grass-addons/grass7/imagery/i.in.probav/i.in.probav.html (rev 0)
+++ grass-addons/grass7/imagery/i.in.probav/i.in.probav.html 2017-01-09 09:42:35 UTC (rev 70310)
@@ -0,0 +1,53 @@
+<h2>DESCRIPTION</h2>
+<em>i.in.probav</em> imports Proba-V NDVI data sets.
+After the import the digital numbers (DN) are remapped to VEGETATION NDVI
+values and the NDVI color table is applied. The imported DN map is
+removed after remapping. It is also possible to change the scale and offset
+factor (default is scale: 0.004, offset: -0.08 for Proba-V)
+and to improve the memory usage (default is 300 MB).
+<p>
+Important for the Proba-V Data sets, is a user registration at
+<a href="http://www.vito-eodata.be/PDF/portal/Application.html#Home">the VITO portal</a>
+necessary (Register Button in the Upper Right Corner).
+<h2>NOTES</h2>
+The Proba-V files are delivered in NetCDF (Network Common Data Form)
+format. It is required to have the GDAL libraries installed with NetCDF support.
+Also to check the necessary scale and offset factor with <b>gdalinfo</b>.
+<h3>Before Import</h3>
+When working with Proba-V NDVI, it it necessary to fix the range of the map because
+it exceeds the -180°..+180° range with entire world extent.
+You can shift the map slightly into the right position using
+<a href="http://www.gdal.org/gdal_translate.html">gdal_translate</a>.
+This example in <a href="https://grasswiki.osgeo.org/wiki/Global_datasets#ESA_Globcover_dataset">Global datasets</a> may help you.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+# import of 300m NDVI
+i.in.probav input=c_gls_NDVI300_201611010000_GLOBE_PROBAV_V1.0.1.nc \
+ output=c_gls_NDVI300_201611010000_GLOBE_PROBAV_V1.0.1 memory=500
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.in.spotvgt.html">i.in.spotvgt</a>,
+<a href="r.in.gdal.html">r.in.gdal</a>
+</em>
+<h2>REFERENCES</h2>
+<ul>
+<li> <a href="http://www.vito-eodata.be/PDF/portal/Application.html#Home">VITO Product Distribution Portal</a></li>
+<li> <a href="http://www.vito-eodata.be/PDF/image/faq_help/Faq.html">PROBA-V FAQ</a></li>
+<li> <a href="http://www.vito-eodata.be/PDF/image/faq_help/Help.html#COLLECTION">VITO Collections help</a></li>
+</ul>
+<h2>AUTHOR</h2>
+Jonas Strobel<br>
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/imagery/i.in.probav/i.in.probav.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/imagery/i.in.probav/i.in.probav.py
--- grass-addons/grass7/imagery/i.in.probav/i.in.probav.py (rev 0)
+++ grass-addons/grass7/imagery/i.in.probav/i.in.probav.py 2017-01-09 09:42:35 UTC (rev 70310)
@@ -0,0 +1,131 @@
+#!/usr/bin/env python
+# MODULE: i.in.probav
+# AUTHOR(S): Jonas Strobel, intern at mundialis and terrestris, Bonn
+# PURPOSE: i.in.probav
+# COPYRIGHT: (C) 2017 by stjo, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%module
+#% description: Imports PROBA-V NDVI data in netCDF format into a raster map with real NDVI data range.
+#% keyword: imagery
+#% keyword: import
+#% keyword: NDVI
+#% keyword: PROBA-V
+#%end
+#%option G_OPT_F_INPUT
+#% description: Name of input PROBA-V NDVI .nc file
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+#%option
+#% key: scale
+#% type: double
+#% required: no
+#% multiple: no
+#% answer: 0.004
+#% key_desc: float
+#% description: Scale factor for input
+#%end
+#%option
+#% key: shift
+#% type: double
+#% required: no
+#% multiple: no
+#% answer: -0.08
+#% key_desc: float
+#% label: Shift factor for input
+#% description: Offset factor for input
+#%end
+#%option
+#% key: memory
+#% type: double
+#% required: no
+#% multiple: no
+#% options: 0-2047
+#% answer: 300
+#% key_desc: integer
+#% description: Maximum memory to be used in MB
+#%end
+import sys
+import os
+import atexit
+import grass.script as gscript
+from grass.exceptions import CalledModuleError
+def cleanup():
+ pass
+def main():
+ global tmpfile
+ infile = options['input']
+ out = options['output']
+ scale = options['scale']
+ offset = options['shift']
+ mem = options['memory']
+ pid = os.getpid()
+ tmpname = str(pid) + 'i.in.probav'
+ tmpfile = gscript.tempfile()
+ if not gscript.overwrite() and gscript.find_file(out)['file']:
+ gscript.fatal(("<%s> already exists. Aborting.") % out)
+ # Are we in LatLong location?
+ s = gscript.read_command("g.proj", flags='j')
+ kv = gscript.parse_key_val(s)
+ if kv['+proj'] != 'longlat':
+ gscript.fatal(("This module only operates in LatLong locations"))
+ try:
+ gscript.message('Importing raster map <' + out + '>...')
+ gscript.run_command('r.in.gdal', input=infile, output=tmpname, memory=mem, quiet=True)
+ except CalledModuleError:
+ gscript.fatal(("An error occurred. Stop."))
+ # What is the relation between the digital number and the real NDVI ?
+ # Real NDVI =coefficient a * Digital Number + coefficient b
+ # = a * DN +b
+ # Coefficient a = scale
+ # Coefficient b = offset
+ # create temporary region
+ gscript.use_temp_region()
+ gscript.run_command('g.region', raster=tmpname, quiet=True)
+ gscript.message("Remapping digital numbers to NDVI...")
+ # do the mapcalc
+ gscript.mapcalc("${out} = ${a} * ${tmpname} + ${b}", out=out, a=scale, tmpname=tmpname, b=offset)
+ # remove original input
+ gscript.run_command('g.remove', type='raster', name=tmpname, quiet=True, flags='f')
+ # set color table to ndvi
+ gscript.run_command('r.colors', map=out, color='ndvi')
+ gscript.message(("Done: generated map <%s>") % out)
+ return 0
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/imagery/i.in.probav/i.in.probav.py
+ text/x-python
+ native
