[GRASS-SVN] r70326 - grass/branches/releasebranch_7_2/vector/v.proj
Mon Jan 9 07:53:30 PST 2017
Author: mlennert
Date: 2017-01-09 07:53:30 -0800 (Mon, 09 Jan 2017)
New Revision: 70326
   grass/branches/releasebranch_7_2/vector/v.proj/main.c
v.proj: add no topology flag (backport from trunk r69960)
Modified: grass/branches/releasebranch_7_2/vector/v.proj/main.c
--- grass/branches/releasebranch_7_2/vector/v.proj/main.c	2017-01-09 14:46:46 UTC (rev 70325)
+++ grass/branches/releasebranch_7_2/vector/v.proj/main.c	2017-01-09 15:53:30 UTC (rev 70326)
@@ -59,6 +59,7 @@
 	struct Flag *list;	/* list files in source location */
 	struct Flag *transformz;	/* treat z as ellipsoidal height */
 	struct Flag *wrap;		/* latlon output: wrap to 0,360 */
+	struct Flag *no_topol;		/* do not build topology */
     } flag;
     G_gisinit(argv[0]);
@@ -124,6 +125,11 @@
 	_("Disable wrapping to -180,180 for latlon output");
     flag.transformz->guisection = _("Target");
+    flag.no_topol = G_define_flag();
+    flag.no_topol->key = 'b';
+    flag.no_topol->label = _("Do not build vector topology");
+    flag.no_topol->description = _("Recommended for massive point conversion");
     /* The parser checks if the map already exists in current mapset,
        we switch out the check and do it
        in the module after the parser */
@@ -498,7 +504,8 @@
     Vect_close(&Map);
-    Vect_build(&Out_Map);
+    if (!flag.no_topol->answer)
+        Vect_build(&Out_Map);
     Vect_close(&Out_Map);
     if (recommend_nowrap)
