[GRASS-SVN] r70334 - grass/trunk/lib/rst/interp_float
svn_grass at osgeo.org
Tue Jan 10 12:07:13 PST 2017
Author: wenzeslaus
Date: 2017-01-10 12:07:13 -0800 (Tue, 10 Jan 2017)
New Revision: 70334
grass/trunk/lib/rst/interp_float/Makefile
rst: add raster and gmath to libraries
Also reorder libraries to more common order.
Add dependencies synced to libs.
Leave math in libs as in other modules
although it likely should be in extra or just get it from link command.
This is meant to fix compilation on Mac where some of the libs are
in EXTRA_LIBS which is reasigned.
Modified: grass/trunk/lib/rst/interp_float/Makefile
--- grass/trunk/lib/rst/interp_float/Makefile 2017-01-10 19:51:10 UTC (rev 70333)
+++ grass/trunk/lib/rst/interp_float/Makefile 2017-01-10 20:07:13 UTC (rev 70334)
@@ -1,13 +1,12 @@
MODULE_TOPDIR = ../../..
LIB = INTERPFL
-DEPENDENCIES = $(GISDEP) $(RASTERDEP)
+DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(VECTORDEP) $(GMATHDEP) $(DBMIDEP) $(BITMAPDEP) $(QTREEDEP) $(INTERPDATADEP)
include $(MODULE_TOPDIR)/include/Make/Lib.make
-LIBES = $(VECTORLIB) $(INTERPDATALIB) $(DBMILIB) $(GISLIB) $(MATHLIB) $(QTREELIB) $(BITMAPLIB)
+LIBES = $(GISLIB) $(RASTERLIB) $(VECTORLIB) $(GMATHLIB) $(DBMILIB) $(BITMAPLIB) $(QTREELIB) $(INTERPDATALIB) $(MATHLIB)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS) $(OMPCFLAGS)
EXTRA_LIBS = $(OMPLIB)
@@ -17,4 +16,3 @@
$(ARCH_INCDIR)/interpf.h: interpf.h
$(INSTALL_DATA) interpf.h $(ARCH_INCDIR)/interpf.h
