[GRASS-SVN] r70359 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Thu Jan 12 20:37:14 PST 2017
Author: wenzeslaus
Date: 2017-01-12 20:37:14 -0800 (Thu, 12 Jan 2017)
New Revision: 70359
grass/trunk/gui/wxpython/xml/module_tree.xml
grass/trunk/gui/wxpython/xml/toolboxes.xml
grass/trunk/gui/wxpython/xml/wxgui_items.xml
wxGUI: call it comp region, avoid confusion with display region, add -l flag, show in Module tree
Modified: grass/trunk/gui/wxpython/xml/module_tree.xml
--- grass/trunk/gui/wxpython/xml/module_tree.xml 2017-01-13 04:35:54 UTC (rev 70358)
+++ grass/trunk/gui/wxpython/xml/module_tree.xml 2017-01-13 04:37:14 UTC (rev 70359)
@@ -5,6 +5,7 @@
<items>
<subtoolbox name="ImportExportLink"/>
<subtoolbox name="ManageMaps"/>
+ <subtoolbox name="Region"/>
<subtoolbox name="Raster"/>
<subtoolbox name="Vector"/>
<subtoolbox name="Imagery"/>
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2017-01-13 04:35:54 UTC (rev 70358)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2017-01-13 04:37:14 UTC (rev 70359)
@@ -531,9 +531,10 @@
</items>
</toolbox>
<toolbox name="Region">
- <label>Region</label>
+ <label>Computational region</label>
<items>
- <wxgui-item name="DisplayRegion"/>
+ <wxgui-item name="ShowRegion"/>
+ <wxgui-item name="ShowRegionLL"/>
<module-item name="g.region">
<label>Set region</label>
</module-item>
Modified: grass/trunk/gui/wxpython/xml/wxgui_items.xml
--- grass/trunk/gui/wxpython/xml/wxgui_items.xml 2017-01-13 04:35:54 UTC (rev 70358)
+++ grass/trunk/gui/wxpython/xml/wxgui_items.xml 2017-01-13 04:37:14 UTC (rev 70359)
@@ -248,12 +248,18 @@
<description>Defines vector output format utilizing OGR library.</description>
<keywords>vector,export,output,external,OGR,PostGIS</keywords>
</wxgui-item>
- <wxgui-item name="DisplayRegion">
- <label>Display region</label>
+ <wxgui-item name="ShowRegion">
+ <label>Show current region</label>
<command>g.region -p</command>
- <description>Manages the boundary definitions for the geographic region.</description>
+ <description>Shows the extent and resolution of the computational region.</description>
<keywords>general,settings</keywords>
</wxgui-item>
+ <wxgui-item name="ShowRegionLL">
+ <label>Show region using latitude and longitude</label>
+ <command>g.region -pl</command>
+ <keywords>general,settings</keywords>
+ </wxgui-item>
<wxgui-item name="MapsetAccess">
<label>Mapset access</label>
<handler>OnMapsets</handler>
