[GRASS-SVN] r70369 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Sat Jan 14 03:27:30 PST 2017
Author: marisn
Date: 2017-01-14 03:27:30 -0800 (Sat, 14 Jan 2017)
New Revision: 70369
Removed:
grass/trunk/gui/wxpython/modules/vkrige.py
Remove vkriege from modules as it is an addon
Deleted: grass/trunk/gui/wxpython/modules/vkrige.py
--- grass/trunk/gui/wxpython/modules/vkrige.py 2017-01-14 11:26:49 UTC (rev 70368)
+++ grass/trunk/gui/wxpython/modules/vkrige.py 2017-01-14 11:27:30 UTC (rev 70369)
@@ -1,759 +0,0 @@
-MODULE: vkrige
-AUTHOR(S): Anne Ghisla <a.ghisla AT gmail.com>
-PURPOSE: Dedicated GUI for v.krige script.
-DEPENDS: R 2.x, packages gstat, maptools and spgrass6, optional: automap
-COPYRIGHT: (C) 2009 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
-#@TODO move here imports related to wxGUI
-# generic imports
-import os
-import sys
-from tempfile import gettempdir
-import time
-import thread
-from core.utils import _
-# dependencies to be checked once, as they are quite
-# time-consuming. cfr. grass.parser.
-try:
- import grass.script as grass
-except ImportError:
- sys.exit(_("No GRASS-python library found."))
-from core import globalvar
-from gui_core import gselect
-from core import gconsole
-from gui_core import goutput
-from core.settings import UserSettings
-from gui_core.widgets import GNotebook
-from core.giface import Notification
-from gui_core.wrap import SpinCtrl
-#import help
-import wx
-# import wx.lib.plot as plot # for plotting the variogram.
-import rpy2.robjects as robjects
-import rpy2.rinterface as rinterface
-# global variables
-# instead of sys.maxint, not working with SpinCtrl on 64bit [reported by
-# Bob Moskovitz]
-maxint = 1e6
-#@TODO move away functions not regarding the GUI
-class KrigingPanel(wx.Panel):
- """Main panel. Contains all widgets except Menus and Statusbar. """
- def __init__(self, parent, Rinstance, controller, *args, **kwargs):
- wx.Panel.__init__(self, parent, *args, **kwargs)
- self.parent = parent
- self.border = 4
- # 1. Input data
- InputBoxSizer = wx.StaticBoxSizer(
- wx.StaticBox(
- self,
- id=wx.ID_ANY,
- label=_("Input Data")),
- orient=wx.HORIZONTAL)
- flexSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
- flexSizer.AddGrowableCol(1)
- flexSizer.Add(
- wx.StaticText(
- self,
- id=wx.ID_ANY,
- label=_("Point dataset:")),
- flag=wx.ALIGN_CENTER_VERTICAL)
- self.InputDataMap = gselect.VectorSelect(parent=self,
- ftype='points',
- updateOnPopup=False)
- self.InputDataMap.SetFocus()
- flexSizer.Add(self.InputDataMap, flag=wx.ALIGN_CENTER_VERTICAL)
- RefreshButton = wx.Button(self, id=wx.ID_REFRESH)
- RefreshButton.Bind(wx.EVT_BUTTON, self.OnButtonRefresh)
- flexSizer.Add(RefreshButton, flag=wx.ALIGN_CENTER_VERTICAL)
- flexSizer.Add(
- wx.StaticText(
- self,
- id=wx.ID_ANY,
- label=_("Numeric column:")),
- self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
- flexSizer.Add(self.InputDataColumn)
- self.InputDataMap.GetChildren()[0].Bind(
- wx.EVT_TEXT, self.OnInputMapChanged)
- self.InputDataColumn.GetChildren()[0].Bind(
- wx.EVT_TEXT, self.OnInputColumnChanged)
- InputBoxSizer.Add(flexSizer)
- # 2. Kriging. In book pages one for each R package. Includes variogram
- # fit.
- KrigingSizer = wx.StaticBoxSizer(
- wx.StaticBox(
- self,
- id=wx.ID_ANY,
- label=_("Kriging")),
- wx.HORIZONTAL)
- self.RPackagesBook = GNotebook(
- parent=self, style=globalvar.FNPageDStyle)
- # , "geoR"]: #@TODO: enable it if/when it'll be implemented.
- for Rpackage in ["gstat"]:
- self.CreatePage(
- package=Rpackage,
- Rinstance=Rinstance,
- controller=controller)
- # Command output. From menuform module, cmdPanel class
- self._gconsole = gconsole.GConsole(guiparent=self)
- self.goutput = goutput.GConsoleWindow(
- parent=self, gconsole=self._gconsole, margin=False)
- self.goutputId = self.RPackagesBook.GetPageCount()
- self.outpage = self.RPackagesBook.AddPage(
- page=self.goutput, text=_("Command output"), name='output')
- self._gconsole.Bind(
- gconsole.EVT_CMD_RUN,
- lambda event: self._switchPageHandler(
- event=event,
- notification=Notification.MAKE_VISIBLE))
- gconsole.EVT_CMD_DONE,
- event=event,
- notification=Notification.RAISE_WINDOW))
- self.RPackagesBook.SetSelection(0)
- KrigingSizer.Add(self.RPackagesBook, proportion=1, flag=wx.EXPAND)
- # 3. Output Parameters.
- OutputSizer = wx.StaticBoxSizer(
- wx.StaticBox(
- self,
- id=wx.ID_ANY,
- label=_("Output")),
- wx.HORIZONTAL)
- OutputParameters = wx.GridBagSizer(hgap=5, vgap=5)
- OutputParameters.Add(
- wx.StaticText(
- self, id=wx.ID_ANY,
- label=_("Name for the output raster map:")),
- flag=wx.ALIGN_CENTER_VERTICAL, pos=(0, 0))
- self.OutputMapName = gselect.Select(parent=self, id=wx.ID_ANY,
- type='raster',
- mapsets=[grass.gisenv()['MAPSET']])
- OutputParameters.Add(self.OutputMapName, flag=wx.EXPAND | wx.ALL,
- pos=(0, 1))
- self.VarianceRasterCheckbox = wx.CheckBox(
- self, id=wx.ID_ANY, label=_("Export variance map as well: "))
- self.VarianceRasterCheckbox.SetValue(state=True)
- OutputParameters.Add(self.VarianceRasterCheckbox,
- pos=(1, 0))
- self.OutputVarianceMapName = gselect.Select(
- parent=self, id=wx.ID_ANY, type='raster',
- self.VarianceRasterCheckbox.Bind(
- wx.EVT_CHECKBOX, self.OnVarianceCBChecked)
- self.OutputVarianceMapName,
- flag=wx.EXPAND | wx.ALL,
- pos=(
- 1,
- 1))
- self.OverwriteCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_(
- "Allow output files to overwrite existing files"))
- self.OverwriteCheckBox.SetValue(
- UserSettings.Get(
- group='cmd',
- key='overwrite',
- subkey='enabled'))
- OutputParameters.Add(self.OverwriteCheckBox,
- pos=(2, 0), span=(1, 2))
- OutputParameters.AddGrowableCol(1)
- OutputSizer.Add(
- OutputParameters,
- proportion=0,
- border=self.border)
- # 4. Run Button and Quit Button
- ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
- HelpButton = wx.Button(self, id=wx.ID_HELP)
- HelpButton.Bind(wx.EVT_BUTTON, self.OnHelpButton)
- QuitButton = wx.Button(self, id=wx.ID_EXIT)
- QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
- # no stock ID for Run button..
- self.RunButton = wx.Button(self, id=wx.ID_ANY, label=_("&Run"))
- self.RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
- # disable it on loading the interface, as input map is not set
- self.RunButton.Enable(False)
- ButtonSizer.Add(
- HelpButton,
- proportion=0,
- flag=wx.ALIGN_LEFT | wx.ALL,
- ButtonSizer.Add(
- QuitButton,
- proportion=0,
- flag=wx.ALIGN_RIGHT | wx.ALL,
- ButtonSizer.Add(
- self.RunButton,
- proportion=0,
- # Main Sizer. Add each child sizer as soon as it is ready.
- Sizer = wx.BoxSizer(wx.VERTICAL)
- Sizer.Add(
- InputBoxSizer,
- proportion=0,
- Sizer.Add(
- KrigingSizer,
- proportion=1,
- Sizer.Add(
- OutputSizer,
- proportion=0,
- Sizer.Add(
- ButtonSizer,
- proportion=0,
- self.SetSizerAndFit(Sizer)
- # last action of __init__: update imput data list.
- # it's performed in the few seconds gap while user examines interface before clicking anything.
- #@TODO: implement a splashcreen IF the maps cause a noticeable lag [markus' suggestion]
- self.InputDataMap.GetElementList()
- def CreatePage(self, package, Rinstance, controller):
- """Creates the three notebook pages, one for each R package """
- for package in [
- "gstat"]: # @TODO add here other packages when they will be implemented
- classobj = eval("RBook" + package + "Panel")
- setattr(
- self,
- "RBook" +
- package +
- "Panel",
- (classobj(
- self,
- id=wx.ID_ANY,
- controller=controller)))
- self.RPackagesBook.AddPage(
- page=getattr(
- self,
- "RBook" +
- package +
- "Panel"),
- text=package)
- def OnButtonRefresh(self, event):
- """Forces refresh of list of available layers. """
- def OnCloseWindow(self, event):
- """Cancel button pressed"""
- self.parent.Close()
- event.Skip()
- def OnHelpButton(self, event):
- grass.run_command('g.manual', entry='v.krige')
- event.Skip()
- def OnInputMapChanged(self, event):
- """Refreshes list of columns."""
- MapName = event.GetString()
- self.InputDataColumn.InsertColumns(
- vector=MapName, layer=1, excludeKey=False,
- type=['integer', 'double precision'])
- def OnInputColumnChanged(self, event):
- """Fills output map name TextCtrl """
- MapName = self.InputDataMap.GetValue()
- enable = bool(self.InputDataColumn.GetValue())
- self.RunButton.Enable(enable)
- self.RBookgstatPanel.PlotButton.Enable(enable)
- if enable:
- self.OutputMapName.SetValue(MapName.split("@")[0] + "_kriging")
- self.OutputVarianceMapName.SetValue(
- MapName.split("@")[0] + "_kriging.var")
- else:
- self.OutputMapName.SetValue('')
- self.OutputVarianceMapName.SetValue('')
- def OnRunButton(self, event):
- """Execute R analysis. """
- #@FIXME: send data to main method instead of running it here.
- #-1: get the selected notebook page. The user shall know that [s]he can modify settings in all
- # pages, but only the selected one will be executed when Run is
- # pressed.
- SelectedPanel = self.RPackagesBook.GetCurrentPage()
- if self.RPackagesBook.GetPageText(
- self.RPackagesBook.GetSelection()) == 'Command output':
- self._gconsole.WriteError(
- "No parameters for running. Please select \"gstat\" tab, check parameters and re-run.")
- return False # no break invoked by above function
- # mount command string as it would have been written on CLI
- command = [
- "v.krige",
- "input=" +
- self.InputDataMap.GetValue(),
- "column=" +
- self.InputDataColumn.GetValue(),
- "output=" +
- self.OutputMapName.GetValue(),
- "package=" +
- '%s' %
- self.RPackagesBook.GetPageText(
- self.RPackagesBook.GetSelection())]
- if not hasattr(
- SelectedPanel, 'VariogramCheckBox') or not SelectedPanel.VariogramCheckBox.IsChecked():
- command.append(
- "model=" + '%s' %
- SelectedPanel.ModelChoicebox.GetStringSelection().split(" ")[0])
- for i in ['Sill', 'Nugget', 'Range', 'Kappa']:
- if getattr(SelectedPanel, i + "ChextBox").IsChecked():
- command.append(
- i.lower() +
- '%s' %
- getattr(
- SelectedPanel,
- i +
- 'Ctrl').GetValue())
- if SelectedPanel.KrigingRadioBox.GetStringSelection() == "Block kriging":
- command.append(
- "block=" + '%s' %
- SelectedPanel.BlockSpinBox.GetValue())
- if self.OverwriteCheckBox.IsChecked():
- command.append("--overwrite")
- if self.VarianceRasterCheckbox.IsChecked():
- command.append(
- "output_var=" +
- self.OutputVarianceMapName.GetValue())
- # give it to the output console
- #@FIXME: it runs the command as a NEW instance. Reimports data, recalculates variogram fit..
- # otherwise I can use Controller() and mimic RunCmd behaviour.
- self._gconsole.RunCmd(command)
- def OnVarianceCBChecked(self, event):
- self.OutputVarianceMapName.Enable(event.IsChecked())
- def _switchPageHandler(self, event, notification):
- self._switchPage(notification=notification)
- event.Skip()
- def _switchPage(self, notification):
- """Manages @c 'output' notebook page according to event notification."""
- if notification == Notification.HIGHLIGHT:
- self.RPackagesBook.HighlightPageByName('output')
- if notification == Notification.MAKE_VISIBLE:
- self.RPackagesBook.SetSelectionByName('output')
- if notification == Notification.RAISE_WINDOW:
- self.SetFocus()
- self.Raise()
-class KrigingModule(wx.Frame):
- """Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
- wx.Frame.__init__(self, parent, *args, **kwargs)
- # setting properties and all widgettery
- self.SetTitle(_("Kriging Module"))
- self.SetIcon(
- wx.Icon(
- os.path.join(
- globalvar.ICONDIR,
- 'grass_dialog.ico'),
- wx.BITMAP_TYPE_ICO))
- self.log = Log(self)
- self.CreateStatusBar()
- self.log.message(_("Ready."))
- self.Panel = KrigingPanel(self, Rinstance, controller)
- self.SetMinSize(self.GetBestSize())
- self.SetSize(self.GetBestSize())
-class Log:
- """The log output is redirected to the status bar of the containing frame. """
- def __init__(self, parent):
- def message(self, text_string):
- """Updates status bar """
- self.parent.SetStatusText(text_string.strip())
-class RBookPanel(wx.Panel):
- """Generic notebook page with shared widgets and empty kriging functions. """
- def __init__(self, parent, *args, **kwargs):
- self.VariogramSizer = wx.StaticBoxSizer(
- wx.StaticBox(
- self,
- id=wx.ID_ANY,
- label=_("Variogram fitting")),
- wx.HORIZONTAL)
- self.LeftSizer = wx.BoxSizer(wx.VERTICAL)
- self.RightSizer = wx.BoxSizer(wx.VERTICAL)
- self.ParametersSizer = wx.GridBagSizer(vgap=5, hgap=5)
- self.VariogramSizer.Add(
- self.LeftSizer,
- proportion=0,
- border=parent.border)
- self.RightSizer,
- proportion=0,
- # left side of Variogram fitting. The checkboxes and spinctrls.
- self.PlotButton = wx.Button(
- self, id=wx.ID_ANY, label=_("Plot/refresh variogram"))
- self.PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
- # grey it out until a suitable layer is available
- self.PlotButton.Enable(False)
- self.LeftSizer.Add(
- self.PlotButton,
- proportion=0,
- flag=wx.ALL,
- self.ParametersSizer,
- proportion=0,
- self.ParametersList = ["Sill", "Nugget", "Range", "Kappa"]
- MinValues = [0, 0, 1, 0.1]
- for n in self.ParametersList:
- setattr(
- self,
- n + "ChextBox",
- wx.CheckBox(
- self,
- id=self.ParametersList.index(n),
- label=_(
- n + ":")))
- # Kappa must be float
- if n == "Kappa":
- setattr(
- self,
- n + "Ctrl",
- (wx.SpinCtrlDouble(
- self,
- id=wx.ID_ANY,
- min=MinValues[
- self.ParametersList.index(n)],
- max=maxint,
- inc=0.1,
- initial=0.5)))
- else:
- setattr(
- self,
- n + "Ctrl",
- (SpinCtrl(
- self,
- id=wx.ID_ANY,
- min=MinValues[
- max=maxint)))
- getattr(self, n + "ChextBox").Bind(wx.EVT_CHECKBOX,
- self.UseValue,
- id=self.ParametersList.index(n))
- setattr(self, n + "Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
- self.ParametersSizer.Add(getattr(self, n + "ChextBox"),
- pos=(self.ParametersList.index(n), 0))
- self.ParametersSizer.Add(getattr(self, n + "Ctrl"),
- flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL,
- pos=(self.ParametersList.index(n), 1))
- # right side of the Variogram fitting. The plot area.
- #Plot = wx.StaticText(self, id= wx.ID_ANY, label = "Check Plot Variogram to interactively fit model.")
- #PlotPanel = wx.Panel(self)
- #self.PlotArea = plot.PlotCanvas(PlotPanel)
- #self.PlotArea.SetInitialSize(size = (250,250))
- #self.RightSizer.Add(PlotPanel, proportion=0, flag= wx.EXPAND|wx.ALL, border=parent.border)
- self.KrigingSizer = wx.StaticBoxSizer(
- wx.StaticBox(
- self,
- id=wx.ID_ANY,
- label=_("Kriging techniques")),
- wx.VERTICAL)
- # , "Universal kriging"] #@FIXME: i18n on the list?
- KrigingList = ["Ordinary kriging", "Block kriging"]
- self.KrigingRadioBox = wx.RadioBox(self,
- id=wx.ID_ANY,
- choices=KrigingList,
- majorDimension=1,
- style=wx.RA_SPECIFY_COLS)
- self.KrigingRadioBox.Bind(wx.EVT_RADIOBOX, self.HideBlockOptions)
- self.KrigingSizer.Add(
- self.KrigingRadioBox,
- proportion=0,
- # block kriging parameters. Size.
- BlockSizer = wx.BoxSizer(wx.HORIZONTAL)
- BlockLabel = wx.StaticText(self, id=wx.ID_ANY, label=_("Block size:"))
- self.BlockSpinBox = SpinCtrl(self, id=wx.ID_ANY, min=1, max=maxint)
- # default choice is Ordinary kriging so block param is disabled
- self.BlockSpinBox.Enable(False)
- BlockSizer.Add(
- BlockLabel,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL,
- BlockSizer.Add(
- self.BlockSpinBox,
- flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
- BlockSizer,
- self.Sizer = wx.BoxSizer(wx.VERTICAL)
- self.Sizer.Add(
- self.VariogramSizer,
- proportion=0,
- self.Sizer.Add(
- self.KrigingSizer,
- proportion=0,
- def HideBlockOptions(self, event):
- self.BlockSpinBox.Enable(event.GetInt() == 1)
- def OnPlotButton(self, event):
- """Plots variogram with current options. """
- pass
- def UseValue(self, event):
- """Enables/Disables the SpinCtrl in respect of the checkbox. """
- n = self.ParametersList[event.GetId()]
- getattr(self, n + "Ctrl").Enable(event.IsChecked())
-class RBookgstatPanel(RBookPanel):
- """Subclass of RBookPanel, with specific gstat options and kriging functions. """
- RBookPanel.__init__(self, parent, *args, **kwargs)
- # assigns Rinstance, that comes from the GUI call of v.krige.py.
- robjects = Rinstance
- self.controller = controller
- if robjects.r.require('automap')[0]:
- self.VariogramCheckBox = wx.CheckBox(
- self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
- self.LeftSizer.Insert(
- 0,
- self.VariogramCheckBox,
- proportion=0,
- border=4)
- self.SetSizerAndFit(self.Sizer)
- self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
- self.VariogramCheckBox.SetValue(state=True) # check it by default
- # Get list of available models. Show long name but use short one
- ModelFactor = robjects.r.vgm()
- ModelList = robjects.r.levels(ModelFactor[1])
- self.ModelListShort = robjects.r.levels(ModelFactor[0])
- #@FIXME: no other way to let the Python pick it up..
- # and this is te wrong place where to load this list. should be at the
- # very beginning.
- self.ModelChoicebox = wx.Choice(self, id=wx.ID_ANY, choices=ModelList)
- # disable model parameters' widgets by default
- for n in ["Sill", "Nugget", "Range", "Kappa"]:
- getattr(self, n + "Ctrl").Enable(False)
- self.ModelChoicebox.Enable(False)
- VariogramSubSizer = wx.BoxSizer(wx.HORIZONTAL)
- VariogramSubSizer.Add(wx.StaticText(self,
- id=wx.ID_ANY,
- label=_("Model: ")),
- border=4)
- VariogramSubSizer.Add(self.ModelChoicebox,
- border=4)
- self.LeftSizer.Insert(2, item=VariogramSubSizer)
- def HideOptions(self, event):
- self.ModelChoicebox.Enable(not event.IsChecked())
- if not event.IsChecked():
- getattr(self, n + "Ctrl").Enable(True)
- getattr(self, n + "ChextBox").SetValue(True)
- # grey it out keeping it checked.. improvable
- getattr(self, n + "ChextBox").Enable(False)
- else:
- getattr(self, n + "ChextBox").SetValue(False)
- getattr(self, n + "ChextBox").Enable(True)
- #@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
- # BIG WARNING: smell of code duplication. Fix this asap. emminchia!
- # controller = Controller() # sed, if needed,
- #controller = self.controller
- map = self.parent.InputDataMap.GetValue()
- column = self.parent.InputDataColumn.GetValue()
- # import data or pick them up
- if self.controller.InputData is None:
- self.controller.InputData = self.controller.ImportMap(
- map=map, column=column)
- # fit the variogram or pick it up
- #~ Formula = self.controller.ComposeFormula(column = column,
- #~ isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging")
- if hasattr(
- self, 'VariogramCheckBox') and self.VariogramCheckBox.IsChecked():
- self.model = ''
- for each in ("Sill", "Nugget", "Range", "Kappa"):
- if getattr(self, each + 'ChextBox').IsChecked():
- setattr(
- self, each.lower(), getattr(
- self, each + "Ctrl").GetValue())
- else:
- setattr(self, each.lower(), robjects.r('''NA'''))
- else:
- self.model = self.ModelListShort[
- self.ModelChoicebox.GetSelection()]
- # @FIXME will be removed when chextboxes will be frozen
- setattr(
- isblock = self.KrigingRadioBox.GetStringSelection() == "Block kriging"
- if isblock is not '':
- self.predictor = 'x+y'
- else:
- self.predictor = '1'
- self.controller.Variogram = self.controller.FitVariogram(
- robjects.Formula(str(column) + "~" + self.predictor),
- self.controller.InputData, model=self.model, sill=self.sill,
- nugget=self.nugget, range=self.range, kappa=self.kappa)
- ''' Fill parameters with autofitted values '''
- if hasattr(
- for i in range(len(self.ModelListShort)):
- if self.ModelListShort[
- i] == self.controller.Variogram['model']:
- self.ModelChoicebox.SetSelection(i)
- break
- if not getattr(self, 'SillChextBox').IsChecked():
- self.sill = self.controller.Variogram['variogrammodel'][1][1]
- self.SillCtrl.SetValue(self.sill)
- if not getattr(self, 'NuggetChextBox').IsChecked():
- self.nugget = self.controller.Variogram['variogrammodel'][1][0]
- self.NuggetCtrl.SetValue(self.nugget)
- if not getattr(self, 'RangeChextBox').IsChecked():
- self.range = self.controller.Variogram['variogrammodel'][2][1]
- self.RangeCtrl.SetValue(self.range)
- if not getattr(self, 'KappaChextBox').IsChecked():
- self.kappa = self.controller.Variogram['variogrammodel'][3][1]
- self.KappaCtrl.SetValue(self.kappa)
- # use R plot function, in a separate window.
- thread.start_new_thread(self.plot, ())
- def plot(self):
- # robjects.r.X11()
- # robjects.r.png("variogram.png")
- textplot = robjects.r.plot(self.controller.Variogram['datavariogram'],
- self.controller.Variogram['variogrammodel'])
- print textplot
- self.refresh()
- # robjects.r['dev.off']()
- def refresh(self):
- while True:
- rinterface.process_revents()
- time.sleep(0.2)
-class RBookgeoRPanel(RBookPanel):
- """Subclass of RBookPanel, with specific geoR options and kriging functions. """
- #@TODO: change these two lines as soon as geoR f(x)s are integrated.
- for n in self.GetChildren():
- n.Hide()
- self.Sizer.Add(
- wx.StaticText(
- self,
- id=wx.ID_ANY,
- label=_("Work in progress! No functionality provided.")))
