[GRASS-SVN] r70373 - grass/trunk/scripts/v.db.addtable
svn_grass at osgeo.org
Sun Jan 15 02:33:02 PST 2017
Author: martinl
Date: 2017-01-15 02:33:02 -0800 (Sun, 15 Jan 2017)
New Revision: 70373
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
v.db.addtable: fails gracefully when vector is open level 1
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2017-01-14 17:34:55 UTC (rev 70372)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2017-01-15 10:33:02 UTC (rev 70373)
@@ -86,7 +86,7 @@
grass.verbose(_("Using user specified table name: %s") % table)
# check if DB parameters are set, and if not set them.
- grass.run_command('db.connect', flags='c')
+ grass.run_command('db.connect', flags='c', quiet=True)
grass.verbose(_("Creating new DB connection based on default mapset settings..."))
kv = grass.db_connection()
database = kv['database']
@@ -133,10 +133,17 @@
map=map_name, database=database, driver=driver,
layer=layer, table=table, key=key)
- # finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
- # (creates new row for each vector line):
- grass.run_command('v.to.db', map=map_name, layer=layer,
- option='cat', column=key, qlayer=layer)
+ # finally we have to add cats into the attribute DB to make
+ # modules such as v.what.rast happy: (creates new row for each
+ # vector line):
+ try:
+ grass.run_command('v.to.db', map=map_name, layer=layer,
+ option='cat', column=key, qlayer=layer)
+ except CalledModuleError:
+ # remove link
+ grass.run_command('v.db.connect', quiet=True, flags='d',
+ map=map_name, layer=layer)
+ return 1
grass.verbose(_("Current attribute table links:"))
if grass.verbosity() > 2:
