[GRASS-SVN] r70380 - grass-addons/grass7/vector/v.in.pygbif
svn_grass at osgeo.org
Mon Jan 16 06:46:53 PST 2017
Author: sbl
Date: 2017-01-16 06:46:53 -0800 (Mon, 16 Jan 2017)
New Revision: 70380
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
More unicode fixes
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2017-01-16 09:05:46 UTC (rev 70379)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2017-01-16 14:46:53 UTC (rev 70380)
@@ -21,6 +21,7 @@
- use proper cleanup routine, esp if using csv + vrt (copy from other modules)
- handle layers in mask input
- add progress bar
+- make date_from and date_to dependent on each other or use today as date_to if not specified
@@ -184,6 +185,9 @@
from grass.pygrass.vector.geometry import Point
from dateutil.parser import parse
+#reload(sys)
+#sys.setdefaultencoding('utf-8')
if not os.environ.has_key("GISBASE"):
grass.message("You must be in GRASS GIS to run this program.")
sys.exit(1)
@@ -238,6 +242,8 @@
rank = options['rank']
# Define static variable
+ #Initialize cat
+ cat = 0
# Number of occurrences to fetch in one request
chunk_size = 300
# lat/lon proj string
@@ -533,7 +539,7 @@
new = Vector(mapname)
new.open('w', tab_name=mapname, tab_cols=cols)
- cat = 1
+ cat = 0
# Download the data from GBIF
for c in range(chunks):
@@ -574,8 +580,9 @@
if k not in res.keys():
res.update({k: None})
- new.write(point, attrs=(
- u'{}'.format(s),
+ cat = cat + 1
+ new.write(point, cat=cat, attrs=(
+ u'{}'.format(s.decode('utf-8')),
res['key'],
res['taxonRank'],
res['taxonKey'],
@@ -596,8 +603,8 @@
res['phylumKey'],
res['kingdom'],
res['kingdomKey'],
- str(res['eventDate']),
- str(res['verbatimEventDate']),
+ u'{}'.format(res['eventDate']) if res['eventDate'] else None,
+ u'{}'.format(res['verbatimEventDate']) if res['verbatimEventDate'] else None,
res['startDayOfYear'],
res['endDayOfYear'],
res['year'],
@@ -627,15 +634,15 @@
res['recordedBy'],
res['identificationID'],
u','.join(res['identifiers']),
- str(res['dateIdentified']),
- str(res['modified']),
+ u'{}'.format(res['dateIdentified']) if res['dateIdentified'] else None,
+ u'{}'.format(res['modified']) if res['modified'] else None,
res['institutionCode'],
- str(res['lastInterpreted']),
- str(res['lastParsed']),
+ u'{}'.format(res['lastInterpreted']) if res['lastInterpreted'] else None,
+ u'{}'.format(res['lastParsed']) if res['lastParsed'] else None,
res['references'],
u','.join(res['relations']),
res['catalogNumber'],
- str(res['occurrenceDetails']),
+ u'{}'.format(res['occurrenceDetails']) if res['occurrenceDetails'] else None,
res['datasetKey'],
res['datasetName'],
res['collectionCode'],
@@ -644,7 +651,7 @@
res['license'],
res['publishingOrgKey'],
res['publishingCountry'],
- str(res['lastCrawled']),
+ u'{}'.format(res['lastCrawled']) if res['lastCrawled'] else None,
res['specificEpithet'],
u','.join(res['facts']),
u','.join(res['issues']),
