[GRASS-SVN] r70431 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Wed Jan 25 01:35:29 PST 2017
Author: martinl
Date: 2017-01-25 01:35:29 -0800 (Wed, 25 Jan 2017)
New Revision: 70431
grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: binary input + more guisections
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2017-01-25 09:20:02 UTC (rev 70430)
+++ grass/trunk/raster/r.in.gdal/main.c 2017-01-25 09:35:29 UTC (rev 70431)
@@ -95,7 +95,7 @@
/* Setup and fetch parameters. */
- parm.input = G_define_standard_option(G_OPT_F_INPUT);
+ parm.input = G_define_standard_option(G_OPT_F_BIN_INPUT);
parm.input->description = _("Name of raster file to be imported");
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -106,6 +106,7 @@
parm.band->multiple = YES;
parm.band->required = NO;
parm.band->description = _("Band(s) to select (default is all bands)");
+ parm.band->guisection = _("Bands");
parm.memory = G_define_option();
parm.memory->key = "memory";
@@ -124,7 +125,8 @@
parm.target->description =
_("Name of location to create or to read projection from for GCPs transformation");
parm.target->key_desc = "name";
+ parm.target->guisection = _("Projection");
parm.title = G_define_option();
parm.title->key = "title";
parm.title->key_desc = "phrase";
@@ -178,12 +180,14 @@
_("Override projection check (use current location's projection)");
flag_o->description =
_("Assume that the dataset has same projection as the current location");
+ flag_o->guisection = _("Projection");
flag_j = G_define_flag();
flag_j->key = 'j';
flag_j->description =
_("Perform projection check only and exit");
flag_j->suppress_required = YES;
+ flag_j->guisection = _("Projection");
G_option_requires(flag_j, parm.input, NULL);
flag_e = G_define_flag();
@@ -191,7 +195,8 @@
flag_e->label = _("Extend region extents based on new dataset");
flag_e->description =
_("Also updates the default region if in the PERMANENT mapset");
+ flag_e->guisection = _("Region");
flag_f = G_define_flag();
flag_f->key = 'f';
flag_f->description = _("List supported formats and exit");
@@ -207,6 +212,7 @@
flag_k->key = 'k';
flag_k->description =
_("Keep band numbers instead of using band color names");
+ flag_k->guisection = _("Bands");
flag_c = G_define_flag();
flag_c->key = 'c';
@@ -217,6 +223,7 @@
flag_p = G_define_flag();
flag_p->key = 'p';
flag_p->description = _("Print number of bands and exit");
+ flag_p->guisection = _("Print");
flag_p->suppress_required = YES;
G_option_requires(flag_p, parm.input, NULL);
