[GRASS-SVN] r70437 - grass-addons/grass7/imagery/i.superpixels.slic
svn_grass at osgeo.org
Thu Jan 26 13:13:15 PST 2017
Author: mmetz
Date: 2017-01-26 13:13:15 -0800 (Thu, 26 Jan 2017)
New Revision: 70437
grass-addons/grass7/imagery/i.superpixels.slic/main.c
i.superpixels.slic: fix memory allocation, prepare for SLIC0, disable minsize
Modified: grass-addons/grass7/imagery/i.superpixels.slic/main.c
--- grass-addons/grass7/imagery/i.superpixels.slic/main.c 2017-01-26 12:54:17 UTC (rev 70436)
+++ grass-addons/grass7/imagery/i.superpixels.slic/main.c 2017-01-26 21:13:15 UTC (rev 70437)
@@ -54,23 +54,21 @@
char grp_name[INAME_LEN];
- int nfiles;
+ int n_iterations, n_super_pixels;
- int n_iterations, n_super_pixels, n_compactness;
struct Option *output; /* option for output */
int nrows, ncols;
- int **pdata;
+ DCELL **pdata;
off_t sz;
/* loop variables */
int nf;
- int i_fd, index, row, col;
- RASTER_MAP_TYPE i_data_type;
- void *i_band;
+ int *ifd, index, row, col, nbands;
+ DCELL **ibuf, *min, *max, *rng;
+ struct FPRange drange;
double compactness;
int superpixelsize;
@@ -102,13 +100,14 @@
int x1, y1, x2, y2, itr;
double dist, distxy, dx, dy, dbl_offset;
+ double distsum;
int* nlabels;
int k, r, c, ind, i;
int k_offset, np, outfd, z;
- CELL *ubuff;
+ CELL *obuf;
perturbseeds = 0;
hexgrid = 0;
compactness = 0;
@@ -144,7 +143,7 @@
opt_compactness = G_define_option();
opt_compactness->key = "co";
- opt_compactness->type = TYPE_INTEGER;
+ opt_compactness->type = TYPE_DOUBLE;
opt_compactness->required = NO;
opt_compactness->description = _("Compactness");
opt_compactness->answer = "20";
@@ -166,13 +165,13 @@
/* get the group ref */
if (!I_get_group_ref(grp_name, (struct Ref *)&group_ref))
G_fatal_error(_("Could not read REF file for group <%s>"), grp_name);
- nfiles = group_ref.nfiles;
- if (nfiles <= 0) {
+ nbands = group_ref.nfiles;
+ if (nbands <= 0) {
G_important_message(_("Group <%s> contains no raster maps; run i.group"),
grp->answer);
exit(EXIT_SUCCESS);
if (opt_iteration->answer) {
if ( sscanf(opt_iteration->answer, "%d", &n_iterations) != 1 ) {
@@ -194,53 +193,72 @@
if (opt_compactness->answer) {
- if ( sscanf(opt_compactness->answer, "%d", &n_compactness) != 1 ) {
+ if ( sscanf(opt_compactness->answer, "%lf", &compactness) != 1 ) {
G_fatal_error(_("Illegal value for co (%s)"), opt_compactness->answer);
else {
- n_compactness = 20;
+ compactness = 20;
- const char* result = output->answer;
+ const char *outname = output->answer;
nrows = Rast_window_rows();
ncols = Rast_window_cols();
- pdata = G_malloc (sizeof (int) * group_ref.nfiles);
+ pdata = G_malloc (sizeof (DCELL *) * group_ref.nfiles);
sz = nrows * ncols;
+ ifd = G_malloc (sizeof (int *) * group_ref.nfiles);
+ ibuf = G_malloc (sizeof (DCELL **) * group_ref.nfiles);
+ min = G_malloc (sizeof (DCELL) * group_ref.nfiles);
+ max = G_malloc (sizeof (DCELL) * group_ref.nfiles);
+ rng = G_malloc (sizeof (DCELL) * group_ref.nfiles);
for (nf = 0; nf < group_ref.nfiles; nf++) {
+ ibuf[nf] = Rast_allocate_d_buf();
+ ifd[nf] = Rast_open_old(group_ref.file[nf].name, group_ref.file[nf].mapset);
- i_fd = -1;
- i_data_type = -1;
- i_band = NULL;
- index = 0;
- i_fd = Rast_open_old(group_ref.file[nf].name, group_ref.file[nf].mapset);
- i_data_type = Rast_map_type(group_ref.file[nf].name, group_ref.file[nf].mapset);
- i_band = Rast_allocate_buf(i_data_type);
+ Rast_read_fp_range(group_ref.file[nf].name, group_ref.file[nf].mapset,
+ &drange);
+ Rast_get_fp_range_min_max(&drange, &min[nf], &max[nf]);
+ rng[nf] = max[nf] - min[nf];
- pdata[nf] = G_malloc (sizeof (int) * sz);
- memset (pdata[nf], 0, sizeof (int) * sz);
- for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
- Rast_get_row(i_fd, i_band, row, i_data_type);
- for (col = 0; col < ncols; col++) {
- pdata[nf][index] = ((int *) i_band)[col];
- index++;
+ pdata[nf] = G_malloc (sizeof (DCELL) * sz);
+ memset (pdata[nf], 0, sizeof (DCELL) * sz);
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ for (nf = 0; nf < group_ref.nfiles; nf++)
+ Rast_get_d_row(ifd[nf], ibuf[nf], row);
+ for (col = 0; col < ncols; col++) {
+ int isnull = 0;
+ for (nf = 0; nf < group_ref.nfiles; nf++) {
+ if (Rast_is_d_null_value(&ibuf[nf][col])) {
+ isnull = 1;
+ break;
+ pdata[nf][row * ncols + col] = (ibuf[nf][col] - min[nf]) / rng[nf];
+ if (isnull) {
+ Rast_set_d_null_value(&pdata[nf][row * ncols + col], 1);
- G_free(i_band);
- Rast_close(i_fd);
+ Rast_close(ifd[nf]);
+ G_free(ibuf[nf]);
+ G_free(ifd);
+ G_free(ibuf);
- compactness = (double) n_compactness;
superpixelsize = 0.5+(double)ncols * (double)nrows / (double)n_super_pixels;
@@ -298,7 +316,7 @@
printf("numseeds=%d\n", numseeds);
#endif
- kseeds = G_malloc (sizeof (int) * group_ref.nfiles);
+ kseeds = G_malloc (sizeof (double *) * group_ref.nfiles);
G_percent(nf, group_ref.nfiles, 2);
kseeds[nf] = G_malloc (sizeof (double) * numseeds);
@@ -337,7 +355,7 @@
inv = G_malloc (sizeof (double) * numk);
memset (inv, 0, sizeof (double) * numk);
- sigma = G_malloc (sizeof (int) * group_ref.nfiles);
+ sigma = G_malloc (sizeof (double *) * group_ref.nfiles);
sigma[nf] = G_malloc (sizeof (double) * numk);
memset (sigma[nf], 0, sizeof (double) * numk);
@@ -353,15 +371,31 @@
double *distvec;
distvec = G_malloc (sizeof (double) * sz);
- invwt = 1.0/((offset/compactness)*(offset/compactness));
+ double *distspec;
+ distspec = G_malloc (sizeof (double) * sz);
+ for( s = 0; s < sz; s++ )
+ distspec[s] = 0;
+ double *maxdistspec;
+ maxdistspec = G_malloc (sizeof (double) * numk);
+ for( n = 0; n < numk; n++ )
+ maxdistspec[n] = 1;
+ invwt = compactness * 0.005 / (offset * offset);
dbl_offset = (double)offset;
for( itr = 0; itr < n_iterations ; itr++ ) {
+ G_percent(itr, n_iterations, 2);
for( p = 0; p < sz; p++ )
distvec[p] = 1E+9;
- G_percent(itr, n_iterations, 2);
+ for( p = 0; p < sz; p++ )
+ distspec[p] = 0;
for( n = 0; n < numk; n++ ) {
y1 = (int)MAX(0.0, kseedsy[n]-dbl_offset);
@@ -379,15 +413,17 @@
dist += ((pdata[nf][i] - kseeds[nf][n]) * (pdata[nf][i] - kseeds[nf][n]));
+ dist /= nbands;
distxy = (dx - kseedsx[n])*(dx - kseedsx[n]) +
(dy - kseedsy[n])*(dy - kseedsy[n]);
- dist += distxy*invwt;
- /* dist = sqrt(dist) + sqrt(distxy*invwt); /* this is more exact */
+ distsum = dist / maxdistspec[n] + distxy*invwt;
+ /* dist = sqrt(dist) + sqrt(distxy*invwt); this is more exact */
- if( dist < distvec[i] ) {
- distvec[i] = dist;
+ if( distsum < distvec[i] ) {
+ distvec[i] = distsum;
+ distspec[i] = dist;
klabels[i] = n;
@@ -395,7 +431,16 @@
} /* for( y=y1 */
} /* for (n=0 */
+#if 0
+ if (itr == 0) {
+ maxdistspec[n] = 0;
+ for( s = 0; s < sz; s++ ) {
+ if (maxdistspec[klabels[s]] < distspec[s])
+ maxdistspec[klabels[s]] = distspec[s];
+#endif
@@ -440,6 +485,7 @@
+ G_percent(1, 1, 1);
@@ -463,16 +509,15 @@
G_free(nlabels);
z = 0;
- outfd = Rast_open_new(result, CELL_TYPE);
+ outfd = Rast_open_new(outname, CELL_TYPE);
+ obuf = Rast_allocate_c_buf();
- CELL *ubuff = Rast_allocate_c_buf();
for(col = 0; col < ncols; col++) {
- ubuff[col] = klabels[z]+1; /* +1 to avoid category value 0*/
+ obuf[col] = klabels[z]+1; /* +1 to avoid category value 0*/
z++;
- Rast_put_row(outfd, ubuff, CELL_TYPE);
- G_free(ubuff);
+ Rast_put_row(outfd, obuf, CELL_TYPE);
@@ -571,7 +616,7 @@
If segment size is less then a limit, assign an
adjacent label found before, and decrement label count.
- if(count <= SUPSZ >> 2) {
+ if(count <= 0) {
for( c = 0; c < count; c++ ) {
ind = yvec[c]*width+xvec[c];
nlabels[ind] = adjlabel;
