[GRASS-SVN] r70446 - grass-addons/grass7/imagery/i.superpixels.slic
svn_grass at osgeo.org
Fri Jan 27 13:19:46 PST 2017
Author: mmetz
Date: 2017-01-27 13:19:46 -0800 (Fri, 27 Jan 2017)
New Revision: 70446
grass-addons/grass7/imagery/i.superpixels.slic/main.c
i.superpixels.slic: optimize SLIC
Modified: grass-addons/grass7/imagery/i.superpixels.slic/main.c
--- grass-addons/grass7/imagery/i.superpixels.slic/main.c 2017-01-27 20:29:13 UTC (rev 70445)
+++ grass-addons/grass7/imagery/i.superpixels.slic/main.c 2017-01-27 21:19:46 UTC (rev 70446)
@@ -65,7 +65,7 @@
int step;
int offset;
DCELL ***pdata;
- int **klabels, **nlabels;
+ int **klabels, **nlabels, label_change;
double **distvec, **distspec;
double xerrperstrip, yerrperstrip;
@@ -80,7 +80,7 @@
double *kseedsx, *kseedsy;
double **kseedsb;
double **sigmab, *sigmax, *sigmay;
- double *maxdistspec;
+ double *maxdistspeck, maxdistspec, maxdistspecprev;
double invwt;
double dist, distxy, dx, dy;
@@ -108,7 +108,7 @@
opt_iteration->type = TYPE_INTEGER;
opt_iteration->required = NO;
opt_iteration->description = _("Maximum number of iterations");
- opt_iteration->answer = "10";
+ opt_iteration->answer = "100";
opt_super_pixels = G_define_option();
opt_super_pixels->key = "k";
@@ -384,10 +384,11 @@
distspec[row][col] = 0;
- maxdistspec = G_malloc(sizeof(double) * numk);
+ maxdistspeck = G_malloc(sizeof(double) * numk);
+ maxdistspec = maxdistspecprev = 0;
for (k = 0; k < numk; k++)
- maxdistspec[k] = 1;
+ maxdistspeck[k] = 1;
/* magic factor */
invwt = 0.1 * compactness / (offset * offset);
@@ -395,6 +396,8 @@
for (itr = 0; itr < n_iterations; itr++) {
G_percent(itr, n_iterations, 2);
+ label_change = 0;
for (row = 0; row < nrows; row++) {
for (col = 0; col < ncols; col++) {
distvec[row][col] = 1E+9;
@@ -426,12 +429,14 @@
distxy = (dx * dx + dy * dy) / 2.0;
- distsum = dist / maxdistspec[k] + distxy * invwt;
+ distsum = dist / maxdistspeck[k] + distxy * invwt;
/* dist = sqrt(dist) + sqrt(distxy*invwt); this is more exact */
if (distsum < distvec[y][x]) {
distvec[y][x] = distsum;
distspec[y][x] = dist;
+ if (klabels[y][x] != k)
+ label_change++;
klabels[y][x] = k;
@@ -443,18 +448,34 @@
/* adaptive m for SLIC zero */
if (itr == 0) {
- maxdistspec[k] = 1.0 / nbands;
+ maxdistspeck[k] = 1.0 / nbands;
k = klabels[row][col];
if (k >= 0) {
- if (maxdistspec[k] < distspec[row][col])
- maxdistspec[k] = distspec[row][col];
+ if (maxdistspeck[k] < distspec[row][col])
+ maxdistspeck[k] = distspec[row][col];
+ else {
+ maxdistspecprev = maxdistspec;
+ maxdistspec = 0;
+ for (row = 0; row < nrows; row++) {
+ for (col = 0; col < ncols; col++) {
+ k = klabels[row][col];
+ if (k >= 0) {
+ if (maxdistspec < distspec[row][col])
+ maxdistspec = distspec[row][col];
+ for (k = 0; k < numk; k++)
+ maxdistspeck[k] = maxdistspec;
+ G_debug(3, "maxdistspec = %.15g", maxdistspec);
for (k = 0; k < numk; k++) {
memset(sigmab[k], 0, sizeof(double) * nbands);
@@ -497,9 +518,17 @@
+ if (label_change == 0)
+ break;
+ G_debug(3, "Number of changed labels: %d", label_change);
+ if (!slic0 && maxdistspecprev == maxdistspec)
+ break;
G_percent(1, 1, 1);
+ if (itr < n_iterations)
+ G_message(_("SLIC converged after %d iterations"), itr);
nlabels = G_malloc(sizeof(int *) * nrows);
nlabels[row] = G_malloc(sizeof(int) * ncols);
