[GRASS-SVN] r70451 - grass/trunk/vector/v.to.db
Sun Jan 29 06:04:27 PST 2017
Author: mlennert
Date: 2017-01-29 06:04:26 -0800 (Sun, 29 Jan 2017)
New Revision: 70451
   grass/trunk/vector/v.to.db/areas.c
   grass/trunk/vector/v.to.db/global.h
   grass/trunk/vector/v.to.db/main.c
   grass/trunk/vector/v.to.db/parse.c
   grass/trunk/vector/v.to.db/report.c
   grass/trunk/vector/v.to.db/update.c
   grass/trunk/vector/v.to.db/v.to.db.html
v.to.db: added bounding box as additional measure (one suggestion of #2122)
Modified: grass/trunk/vector/v.to.db/areas.c
--- grass/trunk/vector/v.to.db/areas.c	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/areas.c	2017-01-29 14:04:26 UTC (rev 70451)
@@ -19,6 +19,7 @@
     int i, idx, found;
     int area_num, nareas;
     struct line_cats *Cats;
+    struct bound_box Bbox;
     double area, perimeter;
     Cats = Vect_new_cats_struct();
@@ -41,6 +42,9 @@
 	    if (G_projection() != PROJECTION_LL && G_projection() != PROJECTION_XY)
 		    perimeter = perimeter * G_database_units_to_meters_factor();
+	if (options.option == O_BBOX) {
+	    Vect_get_area_box(Map, area_num, &Bbox);
 	found = 0;
 	if (Vect_get_area_cats(Map, area_num, Cats) == 0) {
@@ -61,6 +65,16 @@
 		    case O_FD:
 			Values[idx].d1 = 2.0 * log(perimeter) / log(area);
 			break;
+		    case O_BBOX:
+			if (Values[idx].d1 < Bbox.N)
+			    Values[idx].d1 = Bbox.N;
+			if (Values[idx].d2 > Bbox.S)
+			    Values[idx].d2 = Bbox.S;
+			if (Values[idx].d3 < Bbox.E)
+			    Values[idx].d3 = Bbox.E;
+			if (Values[idx].d4 > Bbox.W)
+			    Values[idx].d4 = Bbox.W;
+			break;
 		    found = 1;
@@ -82,6 +96,16 @@
 		case O_FD:
 		    break;
+	        case O_BBOX:
+		    break;
Modified: grass/trunk/vector/v.to.db/global.h
--- grass/trunk/vector/v.to.db/global.h	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/global.h	2017-01-29 14:04:26 UTC (rev 70451)
@@ -9,7 +9,7 @@
     /* for sides set to 2, if more than 1 area category was found, */
     /* including no category (cat = -1)! */
     int i1, i2;			/* values; i1: query (result int), sides; i2: sides */
-    double d1, d2, d3;		/* values (length, area, x/y/z, query) */
+    double d1, d2, d3, d4;		/* values (length, area, x/y/z, bbox, query) */
     char *str1;			/* string value (query) */
     int *qcat;			/* array query categories */
     int nqcats;			/* number of query cats */
@@ -23,7 +23,7 @@
     char *name;
     int field;
-    char *col[3];
+    char *col[4];
     char *qcol;
     int type;
     int option;
@@ -72,6 +72,8 @@
 #define O_AZIMUTH	15	/* line azimuth */
+#define O_BBOX		16	/* bounding box */
 /* areas.c */
 int read_areas(struct Map_info *);
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/main.c	2017-01-29 14:04:26 UTC (rev 70451)
@@ -90,6 +90,14 @@
     Values[i].i2 = -1;
     Values[i].d1 = 0.0;
     Values[i].d2 = 0.0;
+    Values[i].d3 = 0.0;
+    Values[i].d4 = 0.0;
+	Values[i].d1 = -PORT_DOUBLE_MAX;
+	Values[i].d2 = PORT_DOUBLE_MAX;
+	Values[i].d3 = -PORT_DOUBLE_MAX;
+	Values[i].d4 = PORT_DOUBLE_MAX;
     Values[i].qcat = NULL;
     Values[i].nqcats = 0;
     Values[i].aqcats = 0;
@@ -115,6 +123,14 @@
 	    Values[i].i2 = -1;
 	    Values[i].d1 = 0.0;
 	    Values[i].d2 = 0.0;
@@ -131,7 +147,8 @@
 	query(&Map);
     else if ((options.option == O_AREA) || (options.option == O_COMPACT) ||
-	     (options.option == O_PERIMETER) || (options.option == O_FD)) {
+	     (options.option == O_PERIMETER) || (options.option == O_FD) ||
+	     (options.option == O_BBOX)) {
 	read_areas(&Map);
     else {
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/parse.c	2017-01-29 14:04:26 UTC (rev 70451)
@@ -50,7 +50,7 @@
     parms.option->required = YES;
     parms.option->multiple = NO;
     parms.option->options =
-	"cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous,azimuth";
+	"cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous,azimuth,bbox";
     parms.option->description = _("Value to upload");
     desc = NULL;
     G_asprintf(&desc,
@@ -68,7 +68,8 @@
 	       "query;%s;"
 	       "slope;%s;"
 	       "sinuous;%s;"
-	       "azimuth;%s;",
+	       "azimuth;%s;"
+	       "bbox;%s;",
 	       _("insert new row for each category if doesn't exist yet"),
 	       _("area size"),
 	       _("compactness of an area, calculated as \n"
@@ -87,7 +88,8 @@
 		 "(or geometries) from table specified by 'query_layer' option"),
 	       _("slope steepness of vector line or boundary"),
 	       _("line sinuousity, calculated as line length / distance between end points"),
-	       _("line azimuth, calculated as angle between North direction and endnode direction at startnode"));
+	       _("line azimuth, calculated as angle between North direction and endnode direction at startnode"),
+	       _("bounding box of area, N,S,E,W"));
     parms.option->descriptions = desc;
     parms.col = G_define_standard_option(G_OPT_DB_COLUMNS);
@@ -164,6 +166,7 @@
     options.col[0] = NULL;
     options.col[1] = NULL;
     options.col[2] = NULL;
+    options.col[3] = NULL;
     while (parms.col->answers && parms.col->answers[ncols]) {
 	options.col[ncols] = G_store(parms.col->answers[ncols]);
 	ncols++;
@@ -188,6 +191,12 @@
 		G_fatal_error(_("This option requires at least two columns"));
+	else if (options.option == O_BBOX) {
+	    if (ncols != 4) {
+		G_fatal_error(_("This option requires four columns"));
     if (options.option == O_QUERY && !parms.qcol->answers)
@@ -266,6 +275,8 @@
 	x = O_SINUOUS;
     else if (strcmp(s, "azimuth") == 0)
 	x = O_AZIMUTH;
+    else if (strcmp(s, "bbox") == 0)
+	x = O_BBOX;
     return x;
Modified: grass/trunk/vector/v.to.db/report.c
--- grass/trunk/vector/v.to.db/report.c	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/report.c	2017-01-29 14:04:26 UTC (rev 70451)
@@ -77,6 +77,16 @@
 	    fprintf(stdout, "%d%s%.15g\n", Values[i].cat, options.fs, Values[i].d1);
 	break;
+    case O_BBOX:
+	if (G_verbose() > G_verbose_min())
+	    fprintf(stdout, "cat%sN%sS%sE%sW\n", options.fs, options.fs, options.fs,options.fs);
+	for (i = 0; i < vstat.rcat; i++) {
+	    fprintf(stdout, "%d%s%.15g%s%.15g%s%.15g%s%.15g\n", Values[i].cat, options.fs,
+	    Values[i].d1, options.fs, Values[i].d2, options.fs, Values[i].d3,
+	    options.fs, Values[i].d4);
+	break;
     case O_LENGTH:
         if (options.print) {
Modified: grass/trunk/vector/v.to.db/update.c
--- grass/trunk/vector/v.to.db/update.c	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/update.c	2017-01-29 14:04:26 UTC (rev 70451)
@@ -75,6 +75,7 @@
     case O_START:
     case O_END:
     case O_SIDES:
+    case O_BBOX:
 	sprintf(buf1, "update %s set ", Fi->table);
 	break;
@@ -108,6 +109,14 @@
 	    sprintf(buf2, "%s %f where %s = %d", buf1, Values[i].d1, Fi->key,
 		    Values[i].cat);
 	    break;
+	case O_BBOX:
+	    sprintf(buf2,
+	    	"%s %s = %.15g, %s = %.15g, %s = %.15g, %s = %.15g where %s = %d",
+		buf1, options.col[0], Values[i].d1, options.col[1],
+		Values[i].d2, options.col[2], Values[i].d3, options.col[3],
+	       	Values[i].d4, Fi->key, Values[i].cat);
+	    break;
 	case O_COOR:
 	case O_START:
Modified: grass/trunk/vector/v.to.db/v.to.db.html
--- grass/trunk/vector/v.to.db/v.to.db.html	2017-01-29 04:47:03 UTC (rev 70450)
+++ grass/trunk/vector/v.to.db/v.to.db.html	2017-01-29 14:04:26 UTC (rev 70451)
@@ -19,6 +19,9 @@
 distance between the vertices is used.
 <p>When using <em>option=coor</em> on a vector area map,
 only coordinates of centroids with unique category will be reported.
+<p>When using <em>option=bbox</em> on a vector area map with more than one
+feature per category value, the results corresponds to the bounding box of
+all features of same category taken together.
 <p>Line azimuth is calculated as angle from the North direction to the line endnode
 direction at the line statnode. By default it's reported in decimal degrees (0-360, CW) but
 it also may be repored in radians with <em>unit=radians</em>. Azimuth value
