[GRASS-SVN] r71295 - grass/branches/releasebranch_7_2/raster/r.random
svn_grass at osgeo.org
Sat Jul 22 05:20:36 PDT 2017
Author: annakrat
Date: 2017-07-22 05:20:36 -0700 (Sat, 22 Jul 2017)
New Revision: 71295
grass/branches/releasebranch_7_2/raster/r.random/count.c
grass/branches/releasebranch_7_2/raster/r.random/local_proto.h
grass/branches/releasebranch_7_2/raster/r.random/main.c
grass/branches/releasebranch_7_2/raster/r.random/random.c
grass/branches/releasebranch_7_2/raster/r.random/support.c
r.random: use long long when available (merge from trunk, r71074, r71075)
Modified: grass/branches/releasebranch_7_2/raster/r.random/count.c
--- grass/branches/releasebranch_7_2/raster/r.random/count.c 2017-07-22 11:59:19 UTC (rev 71294)
+++ grass/branches/releasebranch_7_2/raster/r.random/count.c 2017-07-22 12:20:36 UTC (rev 71295)
@@ -55,12 +55,12 @@
nrows = Rast_window_rows();
ncols = Rast_window_cols();
- theState->nCells = (long) nrows * ncols;
+ theState->nCells = (gcell_count) nrows * ncols;
theState->nNulls = 0;
set_min(NULL, 0, &theState->min);
set_max(NULL, 0, &theState->max);
if (theState->docover == 1) {
- theState->cnCells = nrows * ncols;
+ theState->cnCells = (gcell_count) nrows * ncols;
theState->cnNulls = 0;
set_min(NULL, 0, &theState->cmin);
set_max(NULL, 0, &theState->cmax);
Modified: grass/branches/releasebranch_7_2/raster/r.random/local_proto.h
--- grass/branches/releasebranch_7_2/raster/r.random/local_proto.h 2017-07-22 11:59:19 UTC (rev 71294)
+++ grass/branches/releasebranch_7_2/raster/r.random/local_proto.h 2017-07-22 12:20:36 UTC (rev 71295)
@@ -22,12 +22,18 @@
/* End from Huidae Cho */
+#ifdef HAVE_LONG_LONG_INT
+typedef unsigned long long gcell_count;
+#else
+typedef unsigned long gcell_count;
+#endif
/* Put all the state infomation into a struct */
struct rr_state
char *inraster, *inrcover, *outraster, *outvector;
int use_nulls, docover, fd_old, fd_cold, fd_new;
- long nCells, nNulls, nRand, cnCells, cnNulls;
+ gcell_count nCells, nNulls, nRand, cnCells, cnNulls;
struct RASTER_MAP_PTR nulls, cnulls, buf, cover, min, max, cmin, cmax;
FILE *fsites;
int z_geometry;
Modified: grass/branches/releasebranch_7_2/raster/r.random/main.c
--- grass/branches/releasebranch_7_2/raster/r.random/main.c 2017-07-22 11:59:19 UTC (rev 71294)
+++ grass/branches/releasebranch_7_2/raster/r.random/main.c 2017-07-22 12:20:36 UTC (rev 71295)
@@ -31,8 +31,8 @@
short percent;
double percentage;
- long targets;
- long count;
+ gcell_count targets;
+ gcell_count count;
struct rr_state myState;
struct GModule *module;
@@ -121,13 +121,21 @@
get_stats(&myState);
if (flag.info->answer) {
G_message("Raster: %s\n"
"Cover: %s\n"
- "Cell Count: %d\n"
- "Null Cells: %d\n\n",
+ "Cell Count: %llu\n"
+ "Null Cells: %llu\n\n",
myState.inraster, myState.inrcover,
- (int)myState.nCells, (int)myState.nNulls);
+ myState.nCells, myState.nNulls);
+#else
+ G_message("Raster: %s\n"
+ "Cover: %s\n"
+ "Cell Count: %lu\n"
+ "Null Cells: %lu\n\n",
+ myState.inraster, myState.inrcover,
+#endif
exit(EXIT_SUCCESS);
@@ -145,7 +153,11 @@
else {
- if (sscanf(parm.npoints->answer, "%ld", &targets) != 1
+ if (sscanf(parm.npoints->answer, "%llu", &targets) != 1
+#else
+ if (sscanf(parm.npoints->answer, "%lu", &targets) != 1
+#endif
|| targets <= 0) {
G_fatal_error(_("<%s=%s> invalid number of points"),
parm.npoints->key, parm.npoints->answer);
@@ -156,15 +168,24 @@
myState.nCells - myState.nNulls;
if (percent)
- myState.nRand = (int)(count * percentage / 100.0 + .5);
+ myState.nRand = (gcell_count)(count * percentage / 100.0 + .5);
else {
if (targets > count) {
if (myState.use_nulls)
- G_fatal_error(_("There aren't [%ld] cells in the current region"),
+ G_fatal_error(_("There aren't [%llu] cells in the current region"),
targets);
else
- G_fatal_error(_("There aren't [%ld] non-NULL cells in the current region"),
+ G_fatal_error(_("There aren't [%llu] non-NULL cells in the current region"),
targets);
+#else
+ if (myState.use_nulls)
+ G_fatal_error(_("There aren't [%lu] cells in the current region"),
+ targets);
+ else
+ G_fatal_error(_("There aren't [%lu] non-NULL cells in the current region"),
+ targets);
+#endif
if (targets <= 0)
Modified: grass/branches/releasebranch_7_2/raster/r.random/random.c
--- grass/branches/releasebranch_7_2/raster/r.random/random.c 2017-07-22 11:59:19 UTC (rev 71294)
+++ grass/branches/releasebranch_7_2/raster/r.random/random.c 2017-07-22 12:20:36 UTC (rev 71295)
@@ -16,8 +16,8 @@
int execute_random(struct rr_state *theState)
- long nt;
- long nc;
+ gcell_count nt;
+ gcell_count nc;
struct Cell_head window;
int nrows, ncols, row, col;
int infd, cinfd, outfd;
@@ -240,8 +240,13 @@
if (nt > 0)
- G_warning(_("Only [%ld] random points created"),
+ G_warning(_("Only [%llu] random points created"),
theState->nRand - nt);
+#else
+ G_warning(_("Only [%lu] random points created"),
+ theState->nRand - nt);
+#endif
/* close files */
Rast_close(infd);
Modified: grass/branches/releasebranch_7_2/raster/r.random/support.c
--- grass/branches/releasebranch_7_2/raster/r.random/support.c 2017-07-22 11:59:19 UTC (rev 71294)
+++ grass/branches/releasebranch_7_2/raster/r.random/support.c 2017-07-22 12:20:36 UTC (rev 71295)
@@ -48,7 +48,11 @@
else
Rast_format_history(
&hist, HIST_DATSRC_2,
- "%ld random points on the base map <%s>",
+ "%llu random points on the base map <%s>",
+#else
+ "%lu random points on the base map <%s>",
+#endif
theState->nRand, theState->inraster);
Rast_command_history(&hist);
