[GRASS-SVN] r71297 - grass/branches/releasebranch_7_2/raster/r.in.lidar
svn_grass at osgeo.org
Sat Jul 22 05:29:46 PDT 2017
Author: wenzeslaus
Date: 2017-07-22 05:29:46 -0700 (Sat, 22 Jul 2017)
New Revision: 71297
grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c
r.in.lidar: add input and file rules, G_option_required instead of suppress_required (backport r69383)
Modified: grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c
--- grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c 2017-07-22 12:23:47 UTC (rev 71296)
+++ grass/branches/releasebranch_7_2/raster/r.in.lidar/main.c 2017-07-22 12:29:46 UTC (rev 71297)
@@ -122,7 +122,7 @@
input_opt->guisection = _("Input");
output_opt = G_define_standard_option(G_OPT_R_OUTPUT);
- output_opt->required = YES;
+ output_opt->required = NO;
output_opt->guisection = _("Output");
file_list_opt = G_define_standard_option(G_OPT_F_INPUT);
@@ -274,7 +274,6 @@
print_flag->key = 'p';
print_flag->description =
_("Print LAS file info and exit");
- print_flag->suppress_required = YES;
extents_flag = G_define_flag();
extents_flag->key = 'e';
@@ -304,7 +303,6 @@
scan_flag = G_define_flag();
scan_flag->key = 's';
scan_flag->description = _("Scan data file for extent then exit");
- scan_flag->suppress_required = YES;
shell_style = G_define_flag();
shell_style->key = 'g';
@@ -340,7 +338,11 @@
" filtered out");
only_valid_flag->guisection = _("Selection");
+ G_option_required(input_opt, file_list_opt, NULL);
+ G_option_exclusive(input_opt, file_list_opt, NULL);
+ G_option_required(output_opt, print_flag, scan_flag, shell_style, NULL);
G_option_exclusive(intens_flag, intens_import_flag, NULL);
+ G_option_requires(base_rast_res_flag, base_raster_opt, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -462,6 +464,8 @@
class_filter_create_from_strings(&class_filter, class_opt->answers);
percent = atoi(percent_opt->answer);
+ /* TODO: we already used zscale */
+ /* TODO: we don't report intensity range */
if (zscale_opt->answer)
zscale = atof(zscale_opt->answer);
if (iscale_opt->answer)
