[GRASS-SVN] r71304 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Sat Jul 22 09:25:37 PDT 2017
Author: wenzeslaus
Date: 2017-07-22 09:25:37 -0700 (Sat, 22 Jul 2017)
New Revision: 71304
grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
wxGUI/mapdisp: make the test code work with current API (no MeasureController, GUI not on path)
Modified: grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
--- grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2017-07-22 15:50:52 UTC (rev 71303)
+++ grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2017-07-22 16:25:37 UTC (rev 71304)
@@ -55,6 +55,9 @@
import grass.script as grass
+from grass.script.setup import set_gui_path
+set_gui_path()
from core.utils import _
from core.settings import UserSettings
from core.globalvar import CheckWxVersion
@@ -194,11 +197,6 @@
window.ZoomToWind()
- from mapdisp.frame import MeasureController
- self.measureController = MeasureController(giface)
- self.measureController.StartMeasurement()
- self._listenToAllMapWindowSignals(window)
self.frame.Show()
def testMapWindowDistance(self, giface, map_):
