[GRASS-SVN] r71314 - in grass/trunk/scripts/v.rast.stats: . testsuite
svn_grass at osgeo.org
Mon Jul 24 23:12:37 PDT 2017
Author: lucadelu
Date: 2017-07-24 23:12:37 -0700 (Mon, 24 Jul 2017)
New Revision: 71314
grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats.py: added flag -d; added tests for this new function
Modified: grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
--- grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py 2017-07-25 05:38:25 UTC (rev 71313)
+++ grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py 2017-07-25 06:12:37 UTC (rev 71314)
@@ -4,6 +4,8 @@
from grass.gunittest.case import TestCase
from grass.gunittest.gmodules import SimpleModule
+from grass.pygrass.vector import VectorTopo
+from grass.pygrass.vector.geometry import Line
class TestRastStats(TestCase):
@@ -23,6 +25,7 @@
self.runModule("g.remove", flags='f', type="raster", name="map_a")
self.runModule("g.remove", flags='f', type="raster", name="map_b")
self.runModule("g.remove", flags='f', type="raster", name="zone_map")
+ self.runModule("g.remove", flags='f', type="raster", name="test_line")
def setUp(self):
"""Create input data
@@ -34,6 +37,16 @@
overwrite=True)
self.runModule("r.to.vect", input="zone_map", output="zone_map",
type="area", overwrite=True)
+ cols = [(u'cat', 'INTEGER PRIMARY KEY'), (u'name', 'VARCHAR(20)')]
+ vt = VectorTopo('test_line')
+ vt.open('w', tab_cols=cols)
+ line1 = Line([(1, 1), (2, 1), (2, 2)])
+ line2 = Line([(10, 20), (15, 22), (20, 32), (30, 40)])
+ vt.write(line1, ('first',))
+ vt.write(line2, ('second',))
+ vt.table.conn.commit()
+ vt.close()
def test_1(self):
# Output of v.rast.stats
@@ -51,6 +64,35 @@
self.assertLooksLike(univar_string, v_db_select.outputs.stdout)
+ def test_line_d(self):
+ output_str = """cat|name|a_median|a_number|a_range
+1|first|192|3|1
+2|second|181|41|6
+ self.assertModule("v.rast.stats", map="test_line", raster="map_a",
+ method=["median", "number", "range"], flags="dc",
+ column_prefix="a")
+ v_db_select = SimpleModule("v.db.select", map="test_line")
+ self.runModule(v_db_select)
+ self.assertLooksLike(output_str, v_db_select.outputs.stdout)
+ def test_line(self):
+1|first|192|5|2
+2|second|181|27|5
+ method=["median", "number", "range"], flags="c",
class TestRastStatsFails(TestCase):
def test_error_handling_a(self):
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2017-07-25 05:38:25 UTC (rev 71313)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2017-07-25 06:12:37 UTC (rev 71314)
@@ -31,6 +31,11 @@
#% key: c
#% description: Continue if upload column(s) already exist
#%end
+#%flag
+#% key: d
+#% label: Create densified lines (default: thin lines)
+#% description: All cells touched by the line will be set, not only those on the render path
+#%end
#%option G_OPT_V_MAP
#%end
#%option G_OPT_V_FIELD
@@ -131,8 +136,14 @@
grass.message(_("Preprocessing input data..."))
try:
- grass.run_command('v.to.rast', input=vector, layer=layer, output=rastertmp,
- use='cat', quiet=True)
+ nlines = grass.vector_info_topo(vector)['lines']
+ # Create densified lines rather than thin lines
+ if flags['d'] and nlines > 0:
+ grass.run_command('v.to.rast', input=vector, layer=layer, output=rastertmp,
+ use='cat', flags='d', quiet=True)
+ else:
+ use='cat', quiet=True)
except CalledModuleError:
grass.fatal(_("An error occurred while converting vector to raster"))
