[GRASS-SVN] r71171 - grass-addons/grass7/vector/v.kriging
Thu Jun 8 03:32:50 PDT 2017
Author: evas
Date: 2017-06-08 03:32:49 -0700 (Thu, 08 Jun 2017)
New Revision: 71171
   grass-addons/grass7/vector/v.kriging/Makefile
   grass-addons/grass7/vector/v.kriging/geostat.c
   grass-addons/grass7/vector/v.kriging/getval.c
   grass-addons/grass7/vector/v.kriging/local_proto.h
   grass-addons/grass7/vector/v.kriging/main.c
   grass-addons/grass7/vector/v.kriging/quantile.c
   grass-addons/grass7/vector/v.kriging/spatial_index.c
   grass-addons/grass7/vector/v.kriging/utils.c
   grass-addons/grass7/vector/v.kriging/utils_kriging.c
   grass-addons/grass7/vector/v.kriging/utils_raster.c
   grass-addons/grass7/vector/v.kriging/utils_write.c
   grass-addons/grass7/vector/v.kriging/v.kriging.html
v.kriging: optimized kriging algorithm (2D and 3D); added pdf with preliminary case studies
Modified: grass-addons/grass7/vector/v.kriging/Makefile
--- grass-addons/grass7/vector/v.kriging/Makefile	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/Makefile	2017-06-08 10:32:49 UTC (rev 71171)
@@ -1,12 +1,12 @@
-MODULE_TOPDIR = ../..
+MODULE_TOPDIR = ../../../..
 PGM = v.kriging
 LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(GMATHLIB) $(IOSTREAMLIB) $(MATHLIB) $(RTREELIB) $(RASTER3DLIB) $(RASTERLIB)
 DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP) $(GMATHDEP) $(IOSTREAMDEP) $(RTREEDEP) $(RASTER3DDEP) $(RASTERDEP)
 EXTRA_INC = $(VECT_INC) $(PROJINC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
-include $(MODULE_TOPDIR)/include/Make/Module.make
+include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Modified: grass-addons/grass7/vector/v.kriging/geostat.c
--- grass-addons/grass7/vector/v.kriging/geostat.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/geostat.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -7,15 +7,18 @@
     // Variogram properties
     struct parameters *var_pars;
+    int direction;
     double max_dist, max_dist_vert;     // max distance of interpolated points
     double radius, radius_vert; // radius of interpolation in the horizontal plane
     switch (type) {
     case 0:                    // horizontal variogram
         var_pars = &pars->hz;   // 0: horizontal variogram
+        direction = 12;
         break;
-    case 1:                    // vertica variogram
-        var_pars = &pars->vert; // 1: vertical variogram
+    case 1:                    // vertical variogram
+        var_pars = &pars->vert; // 1: vertical variogram
+        direction = 3;
         break;
     case 2:                    // bivariate variogram
         var_pars = &pars->fin;
@@ -28,6 +31,7 @@
         var_pars = &pars->fin;  // default: final variogram
         max_dist = max_dist_vert = var_pars->max_dist;
         radius = radius_vert = SQUARE(max_dist);
+        direction = 0;
         break;
@@ -73,7 +77,7 @@
     int nrows = nLag;
     int ncols = type == 2 ? nLag_vert : 1;
-    struct write *report = &xD->report;
+    struct write *report = xD->report;
     // Variogram processing variables
     int s;                      // index of horizontal segment
@@ -133,11 +137,7 @@
     // control initialization:
     if (dr == NULL || search == NULL || var_pars->h == NULL ||
         (type == 2 && var_pars->vert == NULL)) {
-        if (xD->report.write2file == TRUE) {    // close report file
-            fprintf(xD->report.fp,
-                    "Error (see standard output). Process killed...");
-            fclose(xD->report.fp);
+        report_error(xD->report);
         G_fatal_error(_("Memory allocation failed..."));
@@ -146,11 +146,7 @@
     gamma_M = G_matrix_init(nrows, ncols, nrows);       // temporal matrix (vector) of gammas
     if (c_M == NULL || gamma_M == NULL) {
@@ -180,9 +176,9 @@
         for (s = 0; s < nrows; s++) {   // for each horizontal lag (isotrophy!!!)...
             *h = (s + 1) * lag; // lag distance
-            r = &pnts->r[0];    // pointer to the input coordinates
             // for every bs cycle ...
+            r = &pnts->r[0];    // pointer to the input coordinates
             i_vals = &vals[0];  // pointer to input values to be interpolated
             gamma_lag = 0.;     // gamma in dir direction and h distance
             cpls = 0.;          // count of couples in dir direction and h distance
@@ -206,13 +202,13 @@
                 n_vals = list->n_values;        // # of input values located on NN
                 if (n_vals > 0) {
-                    correct_indices(list, r, pnts, var_pars);
+                    correct_indices(direction, list, r, pnts, var_pars);
                     ii = &list->value[0];       // indices of these input values (note: increased by 1)
                     j_vals = &vals[*ii];        // pointer to input values
                     for (j = 1; j < n_vals; j++) {      // for each point within overlapping rectangle
                         if (*ii > i) {  // use the points just once
-                            coord_diff(i, *ii, pnts_r, dr);     // compute coordinate differences
+                            coord_diff(i, *ii, pnts_r, dr);     // compute coordinate differences
                             if (type == 1) {    // vertical variogram:
@@ -221,15 +217,12 @@
                             else {      // hz / aniso / bivar variogram:
                                 tv = atan2(*(dr + 1), *dr);     // bearing
-                                if (tv < 0.) {
-                                    tv += 2. * PI;
-                            ddir1 = dir - tv;   // difference between bearing and azimuth
-                            ddir2 = (dir + PI) - tv;
+                            ddir1 = tv - dir;   // difference between bearing and azimuth
+                            ddir2 = tv + (PI - dir);    // reverse
-                            if (fabs(ddir1) <= td || fabs(ddir2) <= td) {       // angle test: compare the diff with critical value
+                            if (fabsf(ddir1) <= td || fabsf(ddir2) <= td) {     // angle test: compare the diff with critical value
                                 // test squared distance: vertical variogram => 0., ...
                                 rv = type == 1 ? 0. : radius_hz_diff(dr);       // ... otherwise horizontal distance
@@ -237,9 +230,11 @@
                                     rv += SQUARE(*(dr + 2));    // consider also vertical direction
-                                rvh = sqrt(rv) - *h;    // the difference between distance and lag
-                                if (rv <= radius && fabs(rvh) <= lag) { // distance test: compare the distance with critical value and find out if the j-point is located within i-lag
-                                    if (type == 2) {    // vertical test for bivariate variogram:
+                                rvh = *h - sqrt(rv);    // the difference between distance and lag
+                                // distance test: compare the distance with critical value: find out if the j-point is located within i-lag
+                                if (rv <= radius && 0. <= rvh && rvh <= lag) {  // 0. <= rvh && rvh <= lag
+                                    // vertical test for bivariate variogram:
+                                    if (type == 2) {
                                         rvh = *(dr + 2) - *vert;        // compare vertical
                                         if (fabs(rvh) <= lag_vert) {    // elevation test: vertical lag
@@ -248,7 +243,7 @@
                                         else {
                                             goto end;
+                                    }   // end if: type == 2
                                   delta_V:
                                     dv = *j_vals - *i_vals;     // difference of values located on pair of points i, j
                                     gamma_lag += SQUARE(dv);    // sum of squared differences
@@ -262,16 +257,12 @@
                     }           // end j for loop: points within overlapping rectangles
                 }               // end test: n_vals > 0
                 else {
-                    if (report->name) { // close report file
-                        fprintf(report->fp,
-                        fclose(report->fp);
+                    report_error(report);
                     G_fatal_error(_("This point does not have neighbours in given radius..."));
                 r += 3;         // go to the next search point
                 i_vals++;       // and to its value
+                G_free_ilist(list);     // free list memory
             }                   // end for loop i: variogram computation for each i-th search point
             if (isnan(gamma_lag) || cpls == 0.0) {      // empty lags:
@@ -289,6 +280,7 @@
             h++;
             c++;
             gamma++;
+            //G_fatal_error(_("end 1st loop"));
         }                       // end for loop s
         if (type == 2) {        // vertical variogram:
@@ -297,11 +289,7 @@
     }                           // end for loop b
     if (err0 == nLag) {         // todo> kedy nie je riesitelny teoreticky variogram?
-        if (report->write2file == TRUE) {       // close report file
         G_fatal_error(_("Unable to compute experimental variogram..."));
     }                           // end error
@@ -315,26 +303,32 @@
         sill(var_pars);         // compute sill
-    if (report->write2file == TRUE) {   // report file available:
+    if (report->name) {         // report file available:
         write2file_variogram_E(xD, var_pars, c_M);      // write to file
     write_temporary2file(xD, var_pars);
-    G_free_ilist(list);         // free list memory
     G_matrix_free(c_M);
     G_matrix_free(gamma_M);
 /* theoretical variogram */
-void T_variogram(int type, int i3, struct opts opt,
-                 struct parameters *var_pars, struct write *report)
+void T_variogram(int type, struct opts opt,
+                 struct parameters *var_pars, struct int_par *xD)
+    int i3 = xD->i3;
+    struct write *report;
+    report = xD->report;
     char *variogram;
     // report
+        report->fp = fopen(report->name, "a");
         time(&report->now);     // write down time of start
+        // just for the beginning of the phase => type 0 or 2
         if (type != 1) {
             fprintf(report->fp,
                     "\nComputation of theoretical variogram started on %s\n",
@@ -347,27 +341,34 @@
     var_pars->const_val = 0;    // input values are not constants
     switch (type) {
-    case 0:                    // horizontal variogram
-        if (i3 == TRUE) {       // 3D interpolation (middle phase)
+        // horizontal variogram
+    case 0:
+        // 3D interpolation (middle phase)
+        if (i3 == TRUE) {
             variogram = opt.function_var_hz->answer;    // function type available:
             var_pars->function = set_function(variogram, report);
-            if (strcmp(variogram, "linear") != 0 && strcmp(variogram, "parabolic") != 0) {      // nonlinear or not parabolic
+            // nonlinear or not parabolic
+            if (strcmp(variogram, "linear") != 0) {
                 var_pars->nugget = atof(opt.nugget_hz->answer);
                 var_pars->h_range = atof(opt.range_hz->answer);
                 if (opt.sill_hz->answer) {
                     var_pars->sill = atof(opt.sill_hz->answer);
-            else {              // function type not available:
+            // function type not available:
+            else {
                 LMS_variogram(var_pars, report);
-        else {                  // 2D interpolation (final phase)
+        // 2D interpolation (final phase)
+        else {
             variogram = opt.function_var_final->answer; // function type available:
                 var_pars->nugget = atof(opt.nugget_final->answer);
                 var_pars->h_range = atof(opt.range_final->answer);
                 if (opt.sill_final->answer) {
@@ -379,7 +380,8 @@
+        if (report->name && strcmp(variogram, "linear") != 0) {
             fprintf(report->fp, "Parameters of horizontal variogram:\n");
             fprintf(report->fp, "Nugget effect: %f\n", var_pars->nugget);
             fprintf(report->fp, "Sill:          %f\n", var_pars->sill);
@@ -387,23 +389,28 @@
         break;
-    case 1:                    // vertical variogram
+        // vertical variogram
+    case 1:
         var_pars->nugget = atof(opt.nugget_vert->answer);
         var_pars->h_range = atof(opt.range_vert->answer);
         if (opt.sill_vert->answer) {
             var_pars->sill = atof(opt.sill_vert->answer);
         variogram = opt.function_var_vert->answer;
             fprintf(report->fp, "Parameters of vertical variogram:\n");
             fprintf(report->fp, "Range:         %f\n", var_pars->h_range);
         break;
-    case 2:                    // bivariate variogram (just final phase)
+        // bivariate variogram (just final phase)
+    case 2:
         if (!(opt.function_var_final->answer && opt.function_var_final_vert->answer) || strcmp(opt.function_var_final->answer, "linear") == 0) {        // planar function:
             var_pars->function = 5;     // planar variogram (3D)
@@ -448,21 +455,22 @@
-        plot_var(i3, TRUE, var_pars);   // Plot variogram using gnuplot
+        plot_var(xD, TRUE, var_pars);   // Plot variogram using gnuplot
         break;
     case 3:                    // univariate (just final phase)
-        if (strcmp(variogram, "linear") != 0 && strcmp(variogram, "parabolic") != 0) {  // nonlinear and not parabolic variogram:
+        // nonlinear and not parabolic variogram:
                 var_pars->sill = atof(opt.sill_final->answer);
                 if (i3 == TRUE) {       // 3D interpolation:
                     fprintf(report->fp,
                             "Parameters of anisotropic variogram:\n");
@@ -475,6 +483,7 @@
+        // linear variogram:
         else {                  // linear or parabolic variogram
@@ -482,7 +491,7 @@
     if (type != 2) {
-        plot_var(i3, FALSE, var_pars);  // Plot variogram using gnuplot
+        plot_var(xD, FALSE, var_pars);  // Plot variogram using gnuplot
@@ -490,12 +499,10 @@
                       struct points *pnts, struct var_par *pars,
                       struct output *out)
-    G_fatal_error(_("Interpolating values is currently under maintenance (optimization). Theoretical variogram of your data has been computed."));
     // Local variables
     int i3 = xD->i3;
-    double *vals = pnts->invals;        // values to be used for interpolation
-    struct write *crossvalid = &xD->crossvalid;
+    struct write *crossvalid = xD->crossvalid;
     struct parameters *var_par = &pars->fin;
     int type = var_par->type;
@@ -508,30 +515,37 @@
     unsigned int percents = 50; // counter
     unsigned int row, col, dep; // indices of cells/voxels
-    double rslt_OK;             // interpolated value located on r0
+    int resample;
+    struct krig_pars krig;
+    int add_trend = (out->trend[0] == 0. && out->trend[1] == 0. &&
+                     out->trend[2] == 0. &&
+                     out->trend[3] == 0.) ? FALSE : TRUE;
     pnts->max_dist = var_par->lag;
-    struct ilist *list;
+    struct ilist *list, *list_new;
-    double *r0;                 // xyz coordinates of cell/voxel centre
-    mat_struct *GM;
-    mat_struct *GM_sub;         // submatrix of selected points
-    mat_struct *GM_Inv;         // inverted GM (GM_sub) matrix
-    mat_struct *g0;             // diffences between known and unknown values = theor_var(dist)
-    mat_struct *w0;             // weights of values located on the input points
+    double *r0, rslt, trend_val;        // xyz coordinates of cell/voxel centre
     // Cell/voxel center coords (location of interpolated value)
     r0 = (double *)G_malloc(3 * sizeof(double));
-    if (report->write2file) {   // report file available:
+    int *row_init, *row0, count, next = 1, total, complete, new_matrix =
+        0, setup, mat_row;
+    row_init = (int *)G_malloc(reg->ncols * sizeof(int));
+    row0 = &row_init[0];
+    int i, ndeps = reg->ndeps, nrows = reg->nrows, ncols = reg->ncols;
+    krig.rslt = G_matrix_init(nrows * ndeps, ncols, nrows * ndeps);
+    krig.first = TRUE;
         time(&report->now);
         fprintf(report->fp, "Interpolating values started on %s\n\n",
                 ctime(&report->now));
         fflush(report->fp);
-    G_message(_("Interpolating unknown values..."));
-    G_fatal_error(_("... is currently under maintenance (optimization). Theoretical variogram of your data has been computed."));
     if (percents) {
         G_percent_reset();
@@ -542,111 +556,252 @@
         goto constant_voxel_centre;
-    GM = set_up_G(pnts, var_par, &xD->report);  // set up matrix of dissimilarities of input points
-    var_par->GM = G_matrix_copy(GM);    // copy matrix because of cross validation
+    set_up_G(pnts, var_par, xD->report, &krig); // set up matrix of dissimilarities of input points
+    var_par->GM = G_matrix_copy(krig.GM);       // copy matrix because of cross validation
     // perform cross validation...
-    if (crossvalid->write2file) {       // ... if desired
-        crossvalidation(xD, pnts, var_par);
+    if (crossvalid->name) {     // ... if desired
+        crossvalidation(xD, pnts, var_par, reg);
+    G_message(_("Interpolating unknown values..."));
   constant_voxel_centre:
-    for (dep = 0; dep < reg->ndeps; dep++) {
-        if (xD->i3 == TRUE) {
-            if (percents) {
-                G_percent(dep, reg->ndeps, 1);
+    count = 0;
+    col = row = dep = 0;
+    total = ndeps * nrows * ncols;
+    while (count <= total) {
+        if (percents) {
+            G_percent(count, total, 1);
+        if (var_par->const_val == 1) {  // constant input values
+            goto constant_voxel_val;
+        // coordinates of output point (center of the pixel / voxel)
+        if (next < 2) {
+            cell_centre(col, row, dep, xD, reg, r0, var_par);
+            // initial subsample
+            if (col == 0 && row == 0 && dep == 0) {
+                list = list_NN(xD, r0, pnts, max_dist, max_dist_vert);
+                make_subsamples(xD, list, r0, dep * nrows + row, col, pnts,
+                                var_par, &krig);
+            // lists to compare
+            else if (krig.new == FALSE) {
+                list_new = list_NN(xD, r0, pnts, max_dist, max_dist_vert);
+                next = compare_NN(list, list_new, krig.modified);
-        for (row = 0; row < reg->nrows; row++) {
-            if (xD->i3 == FALSE) {
-                if (percents) {
-                    G_percent(row, reg->nrows, 1);
+        if (next > 0) {
+            rslt = interpolate(xD, list, r0, pnts, var_par, &krig);
+            if (add_trend == TRUE) {
+                trend_val = trend(r0, out, var_par->function, xD);
+                rslt += trend_val;
-            //#pragma omp parallel for private(col, r0, GM, GM_Inv, g0, w0, rslt_OK)
-            for (col = 0; col < reg->ncols; col++) {
+            mat_row = dep * nrows + row;
-                if (var_par->const_val == 1) {  // constant input values
-                    goto constant_voxel_val;
+            setup = G_matrix_set_element(krig.rslt, mat_row, col, rslt);
-                cell_centre(col, row, dep, xD, reg, r0, var_par);       // coords of output point
+            if (G_matrix_get_element(krig.rslt, 0, 0) == 0. && (row != 0))
+                G_fatal_error(_("%d %d %d   %d %f %f"), dep, row, col,
+                              mat_row, G_matrix_get_element(krig.rslt, 0, 0),
+                              krig.rslt->vals[(dep * nrows + row) * ncols +
+                                              col]);
-                // add cell centre to the R-tree
-                list = G_new_ilist();   // create list of overlapping rectangles
+            if (setup < 0) {
+                G_fatal_error(_("The value %f was not written to the cell %d %d %d"),
+                              rslt, dep, row, col);
+            count++;
+            krig.new = FALSE;
-                if (i3 == TRUE) {       // 3D kriging:
-                    list =
-                        find_NNs_within(3, r0, pnts, max_dist, max_dist_vert);
+            next = next == 2 ? 1 : next;        // mark it as coincident
+            // Create output
+          constant_voxel_val:
+            if (var_par->const_val == 1) {      // constant input values:
+                rslt = (double)*pnts->invals;   // setup input as output
+        }                       // end if next > 0
+        // go to the next cell point:
+        switch (next) {
+            // the cell was not interpolated:
+        case 0:
+            // new column:
+            if (row == 0 || row == *row0) {
+                Vect_reset_list(list);  // refresh list
+                Vect_list_append_list(list, list_new);  // add new list
+                G_free_ilist(list_new); // free list memory
+                krig.modified = 1;
+                krig.new = TRUE;
+                next = 2;       // interpolate using new subsample
+                G_matrix_free(krig.GM_Inv);     // free old matrix
+                new_matrix++;   // counter of skipped matrices
+                                var_par, &krig);
+            // the same column:
+            else {
+                *row0 = row;    // save row index to continue
+                // general cells:
+                if (col < ncols - 1) {
+                    col++;      // go to the next row
+                    row0++;     // go to the col index in the next row
+                    while (*row0 == nrows) {
+                        else {
+                            krig.first = FALSE;
+                            col = 0;
-                else {          // 2D kriging:
-                    list =
-                        find_NNs_within(2, r0, pnts, max_dist, max_dist_vert);
+                // last column:
+                else {
+                    col = 0;    // start new sampling
+                    row0 = &row_init[0];        // from the beginning;
-                if (list->n_values > 1) {       // positive # of selected points:
-                    correct_indices(list, r0, pnts, var_par);
+                    // skip full cols:
+                    while (*row0 == nrows) {    // full row
+                            row0++;     // to test if it is completed
+                    }           // end while: full row
+                }               // end else: last column
+            }                   // end else: the same column
-                    GM_sub = submatrix(list, GM, report);       // make submatrix for selected points
-                    GM_Inv = G_matrix_inverse(GM_sub);  // invert submatrix
-                    G_matrix_free(GM_sub);
+            row = krig.first == TRUE ? 0 : *row0;       // setup starting cell
+            break;              // count does not rise
-                    g0 = set_up_g0(xD, pnts, list, r0, var_par);        // Diffs inputs - unknowns (incl. cond. 1))
-                    w0 = G_matrix_product(GM_Inv, g0);  // Vector of weights, condition SUM(w) = 1 in last row
+            // the cell was interpolated -> examine the next one
+        case 1:
+            // save index to continue:
+            row++;              // continue in the row
-                    G_matrix_free(GM_Inv);
-                    G_matrix_free(g0);
+            // last row (full column):
+            if (row == nrows) {
+                *row0 = row;    // save the number to distinguish full columns
-                    rslt_OK = result(pnts, list, w0);   // Estimated cell/voxel value rslt_OK = w x inputs
-                    G_matrix_free(w0);
-                else if (list->n_values == 1) {
-                    rslt_OK = vals[list->value[0] - 1]; // Estimated cell/voxel value rslt_OK = w x inputs
-                else if (list->n_values == 0) {
-                    G_fatal_error(_("This point does not have neighbours in given radius..."));
-                }               // end else: error
+                // the last column
+                if (col == ncols - 1) {
+                    // start from the beginning
+                    col = 0;
+                    // skip full columns
+                            col++;
+                            row0++;
+                        else {
+                            if (i3 == FALSE || dep == ndeps - 1) {
+                                if (dep > 1) {
+                                    G_message(_("Vertical level %d has been processed..."),
+                                              dep + 1);
+                                goto accomplished;
+                            else {
+                                dep++;  // next vertical level
+                                col = 0;        // the first column
-                // Create output
-              constant_voxel_val:
-                if (var_par->const_val == 1) {  // constant input values:
-                    rslt_OK = (double)*vals;    // setup input as output
+                                // refresh rows
+                                new_vertical(row_init, ncols);  // row0 = 0
+                                row = *row0;
-                // write output to the (3D) raster layer
-                if (write2layer(xD, reg, out, col, row, dep, rslt_OK) == 0) {
-                        fclose(report->fp);     // close report file
-                    G_fatal_error(_("Error writing result into output layer..."));
-            }                   // end col
-        }                       // end row
-    }                           // end dep
+                                next =
+                                    new_sample(xD, list, list_new, pnts, dep,
+                                               row, col, r0, max_dist,
+                                               max_dist_vert, reg, var_par,
+                                               &krig, &new_matrix);
+                                goto new_dep;
+                            }   // end else: complete level
+                    }           // end if: *row0 == nrows
+                }               // end if: last column
+                else {
+                    col++;
+                    row0++;     // read starting row
+                    complete = 0;
+                            col++;
+                            row0++;
+                            complete++;
+                        else {
+                            col = 0;
+                            complete = 0;
+                        if (complete == ncols - 1) {
+                                if (dep > 1) {
+                                              dep + 1);
+                            else {
+                                // refresh rows
+                                row = *row0;
+                                next =
+                                goto new_dep;
+                        }       // if: complete == ncols - 1
+                    }           // while: *row0 == nrows
+                }               // else: general row
+            }                   // end else: go to the new column
+            break;
+        }                       // end switch next
+      new_dep:
+        if (row == 0 && col == 0) {
+            G_message(_("Vertical level %d has been processed..."), dep);
+    }                           // end while
+  accomplished:
+    G_message(_("# of points: %d   # of matrices: %d   diff: %d"), total,
+              new_matrix, total - new_matrix);
+    // write output to the (3D) raster layer
+    write2layer(xD, reg, out, krig.rslt);
         fprintf(report->fp,
                 "\n************************************************\n\n");
         time(&report->now);
         fprintf(report->fp, "v.kriging completed on %s", ctime(&report->now));
         fclose(report->fp);
-    switch (xD->i3) {
-    case TRUE:
-        Rast3d_close(out->fd_3d);       // Close 3D raster map
-        break;
-    case FALSE:
-        Rast_close(out->fd_2d); // Close 2D raster map
-        break;
Modified: grass-addons/grass7/vector/v.kriging/getval.c
--- grass-addons/grass7/vector/v.kriging/getval.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/getval.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -7,8 +7,7 @@
 /* get array of values from attribute column (function based on part of v.buffer2 (Radim Blazek, Rosen Matev)) */
 double *get_col_values(struct Map_info *map, struct int_par *xD,
-                       struct points *pnts, int field, const char *column,
-                       int detrend)
+                       struct points *pnts, int field, const char *column)
     struct select *in_reg = &pnts->in_reg;
@@ -35,10 +34,10 @@
     db_CatValArray_init(&cvarr);        /* array of categories and values initialised */
     Fi = Vect_get_field(map, field);    /* info about call of DB */
     if (Fi == NULL) {
-        if (save == 1 && xD->report.write2file == TRUE) {       // close report file
+        if (save == 1 && xD->report->name) {    // close report file
+            fprintf(xD->report->fp,
+            fclose(xD->report->fp);
         G_fatal_error(_("Database connection not defined for layer %d"),
                       field);
@@ -46,10 +45,10 @@
     Driver = db_start_driver_open_database(Fi->driver, Fi->database);   /* started connection to DB */
     if (Driver == NULL) {
         G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
                       Fi->database, Fi->driver);
@@ -64,20 +63,20 @@
         db_select_CatValArray(Driver, Fi->table, Fi->key, column, NULL,
                               &cvarr);
     if (nrec < 0) {
         G_fatal_error(_("Unable to select data from table <%s>"), Fi->table);
     ctype = cvarr.ctype;
     if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE) {
         G_fatal_error(_("Column must be numeric"));
@@ -116,65 +115,11 @@
-    if (detrend == 1) {
-        double *x, *y, *z;
-        x = (double *)G_malloc(n * sizeof(double));
-        y = (double *)G_malloc(n * sizeof(double));
-        z = (double *)G_malloc(n * sizeof(double));
-        mat_struct *A, *gR, *T, *res;
-        x = &pnts->r[0];
-        y = &pnts->r[1];
-        z = &pnts->r[2];
-        vals = &values[0];
-        // Number of columns of design matrix A
-        A = G_matrix_init(n, 2, n);     // initialise design matrix, normal grav: 7
-        gR = G_matrix_init(n, 1, n);    // initialise vector of observations
-        for (i = 0; i < n; i++) {
-            G_matrix_set_element(A, i, 0, *x);
-            G_matrix_set_element(A, i, 1, *y);
-            G_matrix_set_element(gR, i, 0, *vals);
-            x += 3;
-            y += 3;
-            z += 3;
-            vals++;
-        T = LSM(A, gR);         // Least Square Method
-        res = G_matrix_product(A, T);
-        FILE *fp;
-        x = &pnts->r[0];
-        y = &pnts->r[1];
-        z = &pnts->r[2];
-        fp = fopen("trend.txt", "w");
-        double *resid;
-        resid = &res->vals[0];
-            *vals = *vals - *resid;
-            fprintf(fp, "%f %f %f %f\n", *x, *y, *z, *vals);
-            x += 3;
-            y += 3;
-            z += 3;
-            vals++;
-            resid++;
-        fclose(fp);
-        //G_debug(0,"a=%f b=%f c=%f d=%f", T->vals[0], T->vals[1], T->vals[2], T->vals[3]);
-        pnts->trend = T;
+    if (xD->phase == 0 && xD->report->name) {
+        write2file_values(xD->report, column);
+        test_normality(n, values, xD->report);
-    if (xD->report.write2file && xD->phase == 0) {
-        write2file_values(&xD->report, column);
-        test_normality(n, values, &xD->report);
     db_CatValArray_free(&cvarr);        // free memory of the array of categories and values
     return values;
@@ -227,7 +172,7 @@
     // Get 3rd coordinate of 2D points from attribute column -> 3D interpolation
     if (xD->v3 == FALSE && zcol != NULL) {
-        z_attr = get_col_values(map, NULL, point, field, zcol, FALSE);
+        z_attr = get_col_values(map, NULL, point, field, zcol);
     nskipped = 0;               // # of skipped elements (lines, areas)
@@ -236,7 +181,7 @@
     while (TRUE) {
         type = Vect_read_next_line(map, Points, NULL);
         if (type == -1) {
+            if (report->name) { // close report file
                 fprintf(report->fp,
                 fclose(report->fp);
@@ -254,7 +199,7 @@
         if (isnan(Points->x[0]) || isnan(Points->y[0]) || isnan(Points->z[0])) {
                 fprintf(report->fp,
                 fclose(report->fp);
@@ -277,11 +222,7 @@
                         *rz = Points->z[0];     // set up z coordinate
                         if (*rz != Points->z[0]) {
                             G_fatal_error(_("Error reading input coordinates z..."));
@@ -356,7 +297,7 @@
     Vect_destroy_line_struct(Points);
     if (n_in_reg == 0) {
             fprintf(report->fp,
             fclose(report->fp);
@@ -368,7 +309,7 @@
         G_message(_("Unused points: %d (out of region)"), out_reg);
-    if (xD->report.write2file == TRUE && xD->phase == 0) {      // initial phase:
+    if (xD->phase == 0 && xD->report->name) {   // initial phase:
         write2file_vector(xD, point);   // describe properties
@@ -395,10 +336,10 @@
         Rast3d_get_window(&reg->reg_3d);        /* stores the current default window in region */
         if (reg->reg_3d.bottom == 0 &&
             (reg->reg_3d.tb_res == 0 || reg->reg_3d.depths == 0)) {
+            if (xD->report->name) {     // close report file
             G_fatal_error
                 ("To process 3D interpolation, please set 3D region settings.");
@@ -425,54 +366,55 @@
     FILE *fp;
-    int j, nLag_vert;
-    double lag_vert, max_dist_vert;
-    double *v_elm, *g_elm;
-    double sill_hz, sill_vert;
-    fp = fopen(file_name, "r");
+    fp = fopen(file_name, "r"); // open file
     if (fp == NULL) {
         G_fatal_error(_("Temporary file <%s> is missing, please repeat an initial phase..."),
                       file_name);
-    else {                      // file exists:
-        int i, type;
-        int nLag;
-        double lag, max_dist, td_hz, sill;
-        double *h_elm, *gamma;
-        int file, file_length;
+    // file exists:
+    else {
+        int i, type;            // index, type of variogram
+        int nLag;               // # of bins
+        double lag, max_dist, td_hz, sill;      // size of the bin, maximum horizontal distance
+        double *h, *h_elm, *gamma;      // elements of horizontal bins and gamma matrices
+        int file, file_length;  // type of file (9/8), length of the filename
-        for (i = 0; i < 2; i++) {
-            if (fscanf(fp, "%d", &file_length) == 0) {  // filename length
+        int j, nLag_vert;       // index and # of vertical bins
+        double lag_vert, max_dist_vert; // size of the lag and maximum vertical distance
+        double *v_elm, *g_elm;  // elements of vertical bins and gamma matrices
+        double sill_hz, sill_vert;      // horizontal and vertical sill
+        // check filename length (1st variable in the file)
+        if (fscanf(fp, "%d", &file_length) == 0) {
+            G_fatal_error(_("Nothing to scan..."));
+        // valid filename
+        if (file_length > 3) {
+            // read file code (Y/N report)
+            if (fscanf(fp, "%d", &file) == 0) {
-            if (file_length > 3) {
-                if (fscanf(fp, "%d", &file) == 0) {
+            // read report name
+            if (file == 9) {    // report
+                xD->report->name =
+                    (char *)G_malloc((file_length + 1) * sizeof(char));
+                if (fscanf(fp, "%s", xD->report->name) == 0) {  // filename
-                if (file == 9) {        // filetype code (9 - report, 8 - crossval)
-                    xD->report.name =
-                        (char *)G_malloc(file_length * sizeof(char));
-                    if (fscanf(fp, "%s", xD->report.name) == 0) {       // filename
-                        G_fatal_error(_("Nothing to scan..."));
-                    continue;
+                // middle / final phase: check if file does not exist
+                if (access(xD->report->name, F_OK) != 0) {
+                    G_fatal_error(_("Report file does not exist; please check the name or repeat initial phase..."));
-                else if (file == 8) {
-                    xD->crossvalid.name =
-                    if (fscanf(fp, "%s", xD->crossvalid.name) == 0) {
-                    continue;
+                xD->report->fp = fopen(xD->report->name, "a");
-            else {
-                type = file_length;
-                goto no_file;
+        else {
+            type = file_length;
+            goto no_file;
         }                       // todo: test without report and crossval
         if (fscanf(fp, "%d", &type) == 0) {     // read type
@@ -480,9 +422,9 @@
       no_file:
         switch (type) {
+        case 2:
             var_par->type = type;
             if (fscanf
                 (fp, "%d %lf %lf %d %lf %lf %lf", &nLag_vert, &lag_vert,
@@ -536,26 +478,42 @@
             break;
         default:
-            if (type == 3) {    // anisotropic variogram:
-                if (fscanf(fp, "%lf", &xD->aniso_ratio) == 0) { // anisotropic ratio
+            // anisotropic variogram:
+            if (type == 3) {
+                // anisotropic ratio
+                if (fscanf(fp, "%lf", &xD->aniso_ratio) == 0) {
+            // distance settings
             if (fscanf(fp, "%d %lf %lf", &nLag, &lag, &max_dist) < 3) {
+            // angular settings
             if (type != 1) {
                 if (fscanf(fp, "%lf", &td_hz) == 0) {
-            var_par->h = (double *)G_malloc(nLag * sizeof(double));
-            h_elm = &var_par->h[0];
+            // empirical variogram:
+            h = (double *)G_malloc(nLag * sizeof(double));
+            // control initialization:
+            if (h == NULL) {
+                G_fatal_error(_("Memory allocation failed..."));
+            h_elm = &h[0];
             var_par->gamma = G_matrix_init(nLag, 1, nLag);
+            if (var_par->gamma == NULL) {
             gamma = &var_par->gamma->vals[0];
             for (i = 0; i < nLag; i++) {
@@ -573,6 +531,10 @@
             break;
+        var_par->h = (double *)G_malloc(nLag * sizeof(double));
+        memcpy(var_par->h, h, nLag * sizeof(double));
+        G_free(h);
         if (type != 2) {
             var_par->nLag = nLag;
Modified: grass-addons/grass7/vector/v.kriging/local_proto.h
--- grass-addons/grass7/vector/v.kriging/local_proto.h	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/local_proto.h	2017-06-08 10:32:49 UTC (rev 71171)
@@ -38,161 +38,185 @@
 struct opts
-  struct Option *input, *output, *phase, *report, *crossvalid, *function_var_hz, *function_var_vert, *function_var_final, *function_var_final_vert, *form_file, *field, *intpl, *zcol, *var_dir_hz, *var_dir_vert, *nL, *nZ, *td_hz, *td_vert, *nugget_hz, *nugget_vert, *nugget_final, *nugget_final_vert, *sill_hz, *sill_vert, *sill_final, *sill_final_vert, *range_hz, *range_vert, *range_final, *range_final_vert;
+    struct Option *input, *output, *phase, *report, *crossvalid,
+        *function_var_hz, *function_var_vert, *function_var_final,
+        *function_var_final_vert, *form_file, *field, *intpl, *zcol, *trend_a,
+        *trend_b, *trend_c, *trend_d, *var_dir_hz, *var_dir_vert, *maxL,
+        *maxZ, *nL, *nZ, *td_hz, *td_vert, *nugget_hz, *nugget_vert,
+        *nugget_final, *nugget_final_vert, *sill_hz, *sill_vert, *sill_final,
+        *sill_final_vert, *range_hz, *range_vert, *range_final,
+        *range_final_vert;
 struct flgs
-  struct Flag *d23; /* 2D/3D interpolation */
-  struct Flag *bivariate;
-  struct Flag *univariate;
-  struct Flag *detrend;
+    struct Flag *d23;           /* 2D/3D interpolation */
+    struct Flag *bivariate;
+    struct Flag *univariate;
+    struct Flag *detrend;
 struct select
-  int n;        // # of selected
-  int out;      // # of the others
-  int total;    // total number
-  int *indices; // indices of selected
+    int n;                      // # of selected
+    int out;                    // # of the others
+    int total;                  // total number
+    int *indices;               // indices of selected
-struct points   // inputs
+struct points                   // inputs
-  int n;                    // number of points
-  double *r;                // triples of coordinates (e.g. x0 y0 z0... xn yn zn)
-  struct RTree *R_tree;     // spatial index
-  struct RTree *Rtree_hz;   // spatial index
-  struct RTree *Rtree_vert; // spatial index
-  double *r_min;            // min coords
-  double *r_max;            // max coords
-  double max_dist;          // maximum distance
-  double center[3];         // center
-  double *invals;           // values to be interpolated
-  struct select in_reg;     // points in region
-  mat_struct *trend;
+    int n;                      // number of points
+    double *r;                  // triples of coordinates (e.g. x0 y0 z0... xn yn zn)
+    struct RTree *R_tree;       // spatial index
+    struct RTree *Rtree_hz;     // spatial index
+    struct RTree *Rtree_vert;   // spatial index
+    double *r_min;              // min coords
+    double *r_max;              // max coords
+    double max_dist;            // maximum distance
+    double center[3];           // center
+    double *invals;             // values to be interpolated
+    struct select in_reg;       // points in region
+    mat_struct *trend;
 struct bivar
-  int vert;
-  char *variogram;
+    int vert;
+    char *variogram;
-  double *h;
-  double max_dist;
-  int nLag;
-  double lag;
+    double *h;
+    double max_dist;
+    int nLag;
+    double lag;
-  int function;
-  double sill;
-  double nugget;
-  double h_range;
+    int function;
+    double sill;
+    double nugget;
+    double h_range;
 struct parameters
-  int function;         // variogram function: lin, exp, spher, Gauss, bivar
-  int type;             // variogram type: hz / vert / aniso / bivar
-  int const_val;
-  double dir;           // azimuth for variogram computing
-  double td;            // maximum azimuth
+    int function;               // variogram function: lin, exp, spher, Gauss, bivar
+    int type;                   // variogram type: hz / vert / aniso / bivar
+    int const_val;
+    double dir;                 // azimuth for variogram computing
+    double td;                  // maximum azimuth
-  double radius;        // radius (squared maximum distance)
-  double max_dist;      // maximum distance - hz / aniso
-  double max_dist_vert; // maximum distance - vert
+    double radius;              // radius (squared maximum distance)
+    double max_dist;            // maximum distance - hz / aniso
+    double max_dist_vert;       // maximum distance - vert
-  int nLag;             // number of lags - hz / aniso
-  double lag;           // lag size
+    int nLag;                   // number of lags - hz / aniso
+    double lag;                 // lag size
-  int nLag_vert;        // number of lags - vert
-  double lag_vert;      // lag size
+    int nLag_vert;              // number of lags - vert
+    double lag_vert;            // lag size
-  double *h;            // lag distance from search point - hz / aniso
-  double *vert;         // lag distance from search point - vert
+    double *h;                  // lag distance from search point - hz / aniso
+    double *vert;               // lag distance from search point - vert
-  int gamma_n;          // # of dissimilarities between input points
-  mat_struct *gamma;    // experimental variogram matrix
-  double gamma_sum;     // sum of gamma values
+    int gamma_n;                // # of dissimilarities between input points
+    mat_struct *gamma;          // experimental variogram matrix
+    double gamma_sum;           // sum of gamma values
-  double nugget;
-  double sill;
-  double part_sill;
-  double h_range;
+    double nugget;
+    double sill;
+    double part_sill;
+    double h_range;
-  struct bivar horizontal; // horizontal variogram properties
-  struct bivar vertical;   // vertical variogram properties
+    struct bivar horizontal;    // horizontal variogram properties
+    struct bivar vertical;      // vertical variogram properties
-  mat_struct *A;           // plan matrix
-  mat_struct *T;           // coefficients of theoretical variogram
-  mat_struct *GM;          // GM = theor_var(dist: input, output points)
+    mat_struct *A;              // plan matrix
+    mat_struct *T;              // coefficients of theoretical variogram
+    mat_struct *GM;             // GM = theor_var(dist: input, output points)
-  char *name;              // name of input vector layer
-  char term[12];           // output format - gnuplot terminal
-  char ext[4];             // output format - file format
+    char *name;                 // name of input vector layer
+    char term[12];              // output format - gnuplot terminal
+    char ext[4];                // output format - file format
-struct var_par // parameters of experimental variogram
+struct var_par                  // parameters of experimental variogram
-  struct parameters hz;
-  struct parameters vert;
-  struct parameters fin;
+    struct parameters hz;
+    struct parameters vert;
+    struct parameters fin;
-  //double Lmax;   // maximal length in horizontal direction
-  //double dzmax;  // maximal elevation difference
-  //double radius; // radius for kd-tree
+struct krig_pars                // parameters of ordinary kriging
+    int new;
+    int first;
+    int modified;
+    mat_struct *GM;
+    mat_struct *GM_Inv;         // inverted GM (GM_sub) matrix
+    mat_struct *rslt;
 struct write
-  int write2file; // write to file or not
-  char *name; // filename
-  FILE *fp;
-  time_t now;
+    char *name;                 // filename
+    FILE *fp;
+    time_t now;
-struct int_par // Interpolation settings
+struct int_par                  // Interpolation settings
-  int i3; // TRUE = 3D interpolation, FALSE = 2D interpolation (user sets by flag)
-  char v3; // TRUE = 3D layer, FALSE = 2D layer (according to Vect_is_3d())
-  int phase;
-  int bivar;
-  int univar;
-  double aniso_ratio;
-  int const_val;
-  struct write report;
-  struct write crossvalid;
+    int i3;                     // TRUE = 3D interpolation, FALSE = 2D interpolation (user sets by flag)
+    char v3;                    // TRUE = 3D layer, FALSE = 2D layer (according to Vect_is_3d())
+    int phase;
+    int bivar;
+    int univar;
+    double aniso_ratio;
+    int const_val;
+    struct write *crossvalid;
-struct reg_par // Region settings -> output extent and resolution
+struct reg_par                  // Region settings -> output extent and resolution
-  struct Cell_head reg_2d; // region for 2D interpolation
-  RASTER3D_Region reg_3d;  // region for 3D interpolation
-  double west;		   // region.west
-  double east;		   // region.east
-  double north;		   // region.north
-  double south;		   // region.south
-  double bot;		   // region.bottom
-  double top;		   // region.top
-  double ew_res;	   // east-west resolution
-  double ns_res;	   // north-south resolution
-  double bt_res;	   // bottom-top resolution
-  int nrows;		   // # of rows
-  int ncols;		   // # of cols
-  int ndeps;		   // # of deps
-  int nrcd;		   // # of cells
+    struct Cell_head reg_2d;    // region for 2D interpolation
+    RASTER3D_Region reg_3d;     // region for 3D interpolation
+    double west;                // region.west
+    double east;                // region.east
+    double north;               // region.north
+    double south;               // region.south
+    double bot;                 // region.bottom
+    double top;                 // region.top
+    double ew_res;              // east-west resolution
+    double ns_res;              // north-south resolution
+    double bt_res;              // bottom-top resolution
+    int nrows;                  // # of rows
+    int ncols;                  // # of cols
+    int ndeps;                  // # of deps
+    int nrcd;                   // # of cells
+struct trend
+    double a;
+    double b;
+    double c;
+    double d;
 struct output
-  DCELL *dcell;
-  int fd_2d;
-  RASTER3D_Map *fd_3d;
-  char *name;		// name of output 2D/3D raster
+    DCELL *dcell;
+    int fd_2d;
+    RASTER3D_Map *fd_3d;
+    char *name;                 // name of output 2D/3D raster
+    int add_trend;
+    double trend[4];
-double *get_col_values(struct Map_info *, struct int_par *, struct points *, int, const char *, int);
+double *get_col_values(struct Map_info *, struct int_par *, struct points *,
+                       int, const char *);
 void test_normality(int, double *, struct write *);
-void read_points(struct Map_info *, struct reg_par *, struct points *, struct int_par *, const char *, int, struct write *);
+void read_points(struct Map_info *, struct reg_par *, struct points *,
+                 struct int_par *, const char *, int, struct write *);
 double min(double *, struct points *);
 double max(double *, struct points *);
@@ -202,31 +226,38 @@
 struct ilist *find_n_NNs(int, int, struct points *, int);
 double sum_NN(int, int, struct ilist *, struct points *);
-void correct_indices(struct ilist *, double *, struct points *, struct parameters *);
+void correct_indices(int, struct ilist *, double *, struct points *,
+                     struct parameters *);
 int cmpVals(const void *, const void *);
 void coord_diff(int, int, double *, double *);
 double distance_diff(double *);
 double radius_hz_diff(double *);
 double zenith_angle(double *);
 void triple(double, double, double, double *);
-double lag_size(int, struct points *, struct parameters *, struct write *);
+double lag_size(int, int, struct points *, struct parameters *,
+                struct write *);
 int lag_number(double, double *);
 void optimize(double *, int *, double);
-void variogram_restricts(struct int_par *, struct points *, struct parameters *);
+void variogram_restricts(struct int_par *, struct points *,
 void geometric_anisotropy(struct int_par *, struct points *);
-double find_intersect_x(double *, double *, double *, double *, struct write *);
-double find_intersect_y(double *, double *, double *, double *, double , struct write *);
+double find_intersect_x(double *, double *, double *, double *,
+                        struct write *);
+double find_intersect_y(double *, double *, double *, double *, double,
+                        struct write *);
 mat_struct *LSM(mat_struct *, mat_struct *);
-mat_struct *nonlin_LMS(int , double *, double *);
+mat_struct *nonlin_LMS(int, double *, double *);
 void E_variogram(int, struct int_par *, struct points *, struct var_par *);
-void T_variogram(int, int, struct opts, struct parameters *, struct write *);
-void ordinary_kriging(struct int_par *, struct reg_par *, struct points *, struct var_par *, struct output *);
+void T_variogram(int, struct opts, struct parameters *, struct int_par *);
+void ordinary_kriging(struct int_par *, struct reg_par *, struct points *,
+                      struct var_par *, struct output *);
 void LMS_variogram(struct parameters *, struct write *);
 double bivar_sill(int, mat_struct *);
 void sill(struct parameters *);
-void sill_compare(struct int_par *, struct flgs *, struct var_par *, struct points *);
+void sill_compare(struct int_par *, struct flgs *, struct var_par *,
+                  struct points *);
 int set_function(char *, struct write *);
 double RBF(double *);
 double linear(double, double, double);
@@ -236,29 +267,53 @@
 double variogram_fction(struct parameters *, double *);
 void set_gnuplot(char *, struct parameters *);
 void plot_experimental_variogram(struct int_par *, struct parameters *);
-void plot_var(int, int, struct parameters *);
+void plot_var(struct int_par *, int, struct parameters *);
+void new_vertical(int *, int);
 void variogram_type(int, char *);
 void write2file_basics(struct int_par *, struct opts *);
 void write2file_vector(struct int_par *, struct points *);
 void write2file_values(struct write *, const char *);
 void write2file_varSetsIntro(int, struct write *);
 void write2file_varSets(struct write *, struct parameters *);
-void write2file_variogram_E(struct int_par *, struct parameters *, mat_struct *);
+void write2file_variogram_E(struct int_par *, struct parameters *,
+                            mat_struct *);
 void write2file_variogram_T(struct write *);
 void write_temporary2file(struct int_par *, struct parameters *);
+void report_error(struct write *);
 void read_tmp_vals(const char *, struct parameters *, struct int_par *);
-mat_struct *set_up_G(struct points *, struct parameters *, struct write *);
-mat_struct *set_up_g0(struct int_par *, struct points *, struct ilist *, double *, struct parameters *);
+void set_up_G(struct points *, struct parameters *, struct write *,
+              struct krig_pars *);
+mat_struct *set_up_g0(struct int_par *, struct points *, struct ilist *,
+                      double *, struct parameters *);
 mat_struct *submatrix(struct ilist *, mat_struct *, struct write *);
-double result(struct points *, struct ilist *,  mat_struct *);
+double result(struct points *, struct ilist *, mat_struct *);
-void crossvalidation(struct int_par *, struct points *, struct parameters *);
-void cell_centre(unsigned int, unsigned int, unsigned int, struct int_par *, struct reg_par *, double *, struct parameters *);
+double find_center(double, double);
+void adjacent_cell(int, double *, struct reg_par *, double *);
+void crossvalidation(struct int_par *, struct points *, struct parameters *,
+                     struct reg_par *);
+void cell_centre(unsigned int, unsigned int, unsigned int, struct int_par *,
+                 struct reg_par *, double *, struct parameters *);
+struct ilist *list_NN(struct int_par *, double *, struct points *, double,
+                      double);
+int compare_NN(struct ilist *, struct ilist *, int);
+void make_subsamples(struct int_par *, struct ilist *, double *, int, int,
+                     struct points *, struct parameters *,
+double interpolate(struct int_par *, struct ilist *, double *,
+                   struct points *, struct parameters *, struct krig_pars *);
+double trend(double *, struct output *, int, struct int_par *);
+int new_sample(struct int_par *, struct ilist *, struct ilist *,
+               struct points *, int, int, int, double *, double, double,
+               struct reg_par *, struct parameters *, struct krig_pars *,
+               int *);
 void get_region_pars(struct int_par *, struct reg_par *);
 void open_layer(struct int_par *, struct reg_par *, struct output *);
-int write2layer(struct int_par *, struct reg_par *, struct output *, unsigned int, unsigned int, unsigned int, double);
+void write2layer(struct int_par *, struct reg_par *, struct output *,
+                 mat_struct *);
 double get_quantile(int);
 void get_slot_counts(int, double *);
Modified: grass-addons/grass7/vector/v.kriging/main.c
--- grass-addons/grass7/vector/v.kriging/main.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/main.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -41,6 +41,13 @@
     // Geostatistical parameters
     struct int_par xD;          // 2D/3D interpolation for 2D/3D vector layer
+    xD.report = (struct write *)G_malloc(sizeof(struct write));
+    struct write *report = xD.report;
+    xD.crossvalid = (struct write *)G_malloc(sizeof(struct write));
+    struct write *crossvalid = xD.crossvalid;
     struct var_par var_pars;    // Variogram (experimental and theoretical)
     // Outputs
@@ -140,8 +147,40 @@
     flg.detrend = G_define_flag();
     flg.detrend->key = 't';
     flg.detrend->description = _("Eliminate trend if variogram is parabolic");
-    flg.detrend->guisection = _("Initial");
+    flg.detrend->guisection = _("Final");
+    opt.trend_a = G_define_option();
+    opt.trend_a->key = "atrend";
+    opt.trend_a->type = TYPE_DOUBLE;
+    opt.trend_a->required = NO;
+    opt.trend_a->answer = "0.0";
+    opt.trend_a->description = _("Trend: f(x,y,z) = a*x + b*y + c*z + d");
+    opt.trend_a->guisection = _("Final");
+    opt.trend_b = G_define_option();
+    opt.trend_b->key = "btrend";
+    opt.trend_b->type = TYPE_DOUBLE;
+    opt.trend_b->required = NO;
+    opt.trend_b->answer = "0.0";
+    opt.trend_b->description = _("Trend: f(x,y,z) = a*x + b*y + c*z + d");
+    opt.trend_b->guisection = _("Final");
+    opt.trend_c = G_define_option();
+    opt.trend_c->key = "ctrend";
+    opt.trend_c->type = TYPE_DOUBLE;
+    opt.trend_c->required = NO;
+    opt.trend_c->answer = "0.0";
+    opt.trend_c->description = _("Trend: f(x,y,z) = a*x + b*y + c*z + d");
+    opt.trend_c->guisection = _("Final");
+    opt.trend_d = G_define_option();
+    opt.trend_d->key = "dtrend";
+    opt.trend_d->type = TYPE_DOUBLE;
+    opt.trend_d->required = NO;
+    opt.trend_d->answer = "0.0";
+    opt.trend_d->description = _("Trend: f(x,y,z) = a*x + b*y + c*z + d");
+    opt.trend_d->guisection = _("Final");
     opt.form_file = G_define_option();  // Variogram plot - various output formats
     opt.form_file->key = "fileformat";
     opt.form_file->options = "cdr,dxf,eps,tex,pdf,png,svg";
@@ -180,6 +219,21 @@
         _("Zenith angle of variogram computing (isotrophic)");
     opt.var_dir_vert->guisection = _("Initial");
+    opt.maxL = G_define_option();
+    opt.maxL->key = "lmax";
+    opt.maxL->type = TYPE_DOUBLE;
+    opt.maxL->required = NO;
+    opt.maxL->description = _("Maximum distance in horizontal direction");
+    opt.maxL->guisection = _("Initial");
+    opt.maxZ = G_define_option();
+    opt.maxZ->key = "vmax";
+    opt.maxZ->type = TYPE_DOUBLE;
+    opt.maxZ->required = NO;
+    opt.maxZ->description =
+        _("Maximum distance in horizontal direction (only for 3D variogram)");
+    opt.maxZ->guisection = _("Initial");
     opt.nL = G_define_option();
     opt.nL->key = "lpieces";
     opt.nL->type = TYPE_INTEGER;
@@ -316,39 +370,30 @@
     // Open report file if desired
-    if (opt.report->answer) {
-        xD.report.write2file = TRUE;
-        xD.report.name = opt.report->answer;
+    if (xD.phase == 0) {
+        if (opt.report->answer) {
+            report->name = opt.report->answer;
-        // initial phase: check if the file exists
-        if (xD.phase == 0 && access(xD.report.name, F_OK) != -1) {
-            G_fatal_error(_("Report file exists; please set up different name..."));
+            // initial phase: check if the file exists
+            if (access(report->name, F_OK) != -1) {
+                G_fatal_error(_("Report file exists; please set up different name..."));
-        // middle / final phase: check if file does not exist
-        if (xD.phase != 0 && access(xD.report.name, F_OK) != 0) {
-            G_fatal_error(_("Report file does not exist; please check the name or repeat initial phase..."));
+            time(&report->now);
+            fprintf(report->fp, "v.kriging started on %s\n\n",
+                    ctime(&report->now));
+            G_message(_("Report is being written to %s..."), report->name);
-        xD.report.fp = fopen(xD.report.name, "a");
-        time(&xD.report.now);
-        fprintf(xD.report.fp, "v.kriging started on %s\n\n",
-                ctime(&xD.report.now));
-        G_message(_("Report is being written to %s..."), xD.report.name);
+        else {
+            G_warning(_("The name of report file missing..."));
-    else {
-        xD.report.write2file = FALSE;
-        G_warning(_("The name of report file missing..."));
-    if (opt.crossvalid->answer) {
-        xD.crossvalid.write2file = TRUE;
-        xD.crossvalid.name = opt.crossvalid->answer;
-        xD.crossvalid.fp = fopen(xD.crossvalid.name, "w");
+    if (xD.phase == 2 && opt.crossvalid->answer) {
+        crossvalid->name = opt.crossvalid->answer;
+        crossvalid->fp = fopen(crossvalid->name, "w");
-    else {
-        xD.crossvalid.write2file = FALSE;
     var_pars.hz.name = var_pars.vert.name = var_pars.fin.name = opt.input->answer;      // set name of variogram
     var_pars.hz.dir = opt.var_dir_hz->answer ? DEG2RAD(atof(opt.var_dir_hz->answer)) : 0.;      // Azimuth
@@ -357,14 +402,43 @@
     var_pars.hz.td = DEG2RAD(atof(opt.td_hz->answer));  // Angle of variogram processing
-    if (opt.nL->answer) {       // Test if nL have been set up (optional)
-        var_pars.hz.nLag = atoi(opt.nL->answer);
-        if (var_pars.hz.nLag < 1) {     // Invalid value
-            G_message(_("Number of horizontal pieces must be at least 1. Default value will be used..."));
-            var_pars.hz.nLag = 20;
+        if (opt.maxL->answer) { // Test if nL have been set up (optional)
+            var_pars.hz.max_dist = atoi(opt.maxL->answer);
+            if (var_pars.hz.max_dist < 0.) {    // Invalid value
+                G_fatal_error(_("Maximum distance must be positive..."));
+        else {
+            var_pars.hz.max_dist = -1.;
+        if (opt.maxZ->answer) { // Test if nL have been set up (optional)
+            var_pars.vert.max_dist = atoi(opt.maxZ->answer);
+            if (var_pars.vert.max_dist < 0.) {  // Invalid value
+        else {
+            var_pars.vert.max_dist = -1.;
+        if (opt.nL->answer) {   // Test if nL have been set up (optional)
+            var_pars.hz.nLag = atoi(opt.nL->answer);
+            if (var_pars.hz.nLag < 1) { // Invalid value
+                G_message(_("Number of horizontal pieces must be at least 1. Default value will be used..."));
+                var_pars.hz.nLag = 20;
+        else {
+            var_pars.hz.nLag = -1.;
     if (opt.form_file->answer) {        // Plotting variogram
         set_gnuplot(opt.form_file->answer, &var_pars.hz);
         set_gnuplot(opt.form_file->answer, &var_pars.vert);
@@ -379,9 +453,9 @@
     xD.bivar = flg.bivariate->answer == TRUE ? TRUE : FALSE;
     xD.univar = flg.univariate->answer == TRUE ? TRUE : FALSE;
     if (xD.bivar == TRUE && xD.univar == TRUE) {
-        if (xD.report.write2file == TRUE) {
-            fclose(xD.report.fp);
-            remove(xD.report.name);
+            fclose(report->fp);
+            remove(report->name);
         G_fatal_error(_("You should mark either univariate, or bivariate variogram, not both of them..."));
     }                           // error
@@ -390,9 +464,9 @@
     Vect_set_open_level(2);     // Open input vector map
     if (0 > Vect_open_old2(&map, opt.input->answer, "", opt.field->answer)) {
+        if (xD.phase == 0 && report->name) {
         G_fatal_error(_("Unable to open vector map <%s>"), opt.input->answer);
     }                           // error
@@ -414,46 +488,51 @@
     if (xD.i3 == TRUE) {        // 3D interpolation:
         if (xD.v3 == FALSE) {   // 2D input:
             if (!opt.zcol->answer) {    // zcolumn not available:
-                if (xD.report.write2file == TRUE) {     // close report file
                 G_fatal_error(_("To process 3D interpolation based on 2D input, please set attribute column containing z coordinates or switch to 2D interpolation."));
         }                       // end if zcol == NULL
         // 3D or 2,5D input
-        if (opt.nZ->answer) {   // Test if nZ have been set up (optional)
-            if (var_pars.vert.nLag < 1) {       // Invalid value
-                G_message(_("Number of vertical pieces must be at least 1. Default value will be used..."));
+            if (opt.nZ->answer) {       // Test if nZ have been set up (optional)
+                if (var_pars.vert.nLag < 1) {   // Invalid value
+                    G_message(_("Number of vertical pieces must be at least 1. Default value will be used..."));
+                else {
+                    var_pars.vert.nLag = atof(opt.nZ->answer);
+            }                   // end if nZ->answer
             else {
-                var_pars.vert.nLag = atof(opt.nZ->answer);
+                var_pars.vert.nLag = -1.;
-        }                       // end if nZ->answer
     }                           // end if 3D interpolation
     else {                      // 2D interpolation:
         var_pars.vert.nLag = -1;        // abs will be used in next steps
         if (xD.v3 == TRUE) {
             G_fatal_error(_("2D interpolation based on 3D input has been temporarily disabled. Please select another option..."));
     field = Vect_get_field_number(&map, opt.field->answer);
         write2file_basics(&xD, &opt);
     /* Get... */
     get_region_pars(&xD, &reg); // ... region parameters
-    read_points(&map, &reg, &pnts, &xD, opt.zcol->answer, field, &xD.report);   // ... coordinates of points
-    pnts.invals = get_col_values(&map, &xD, &pnts, field, opt.intpl->answer, flg.detrend->answer);      // ... values for interpolation
+    read_points(&map, &reg, &pnts, &xD, opt.zcol->answer, field, report);       // ... coordinates of points
+    pnts.invals = get_col_values(&map, &xD, &pnts, field, opt.intpl->answer);   // ... values for interpolation
     /* Estimate 2D/3D variogram */
     switch (xD.phase) {
@@ -474,7 +553,7 @@
         E_variogram(0, &xD, &pnts, &var_pars);  // horizontal variogram (for both 2D and 3D interpolation)
-        if (xD.report.write2file == FALSE) {
+        if (!report->name) {
             G_message(_("\nExperimental variogram of your data has been computed. To continue interpolation performance, please repeat initial phase with non-empty <report> parameter..."));
@@ -490,11 +569,13 @@
         goto end;
     case 1:
-        read_tmp_vals("variogram_hz_tmp.txt", &var_pars.hz, &xD);       // read properties of horizontal variogram from temp file
-        read_tmp_vals("variogram_vert_tmp.txt", &var_pars.vert, &xD);   // read properties of vertical variogram from temp file
+        // read properties of variogram from temporary file
+        read_tmp_vals("variogram_hz_tmp.txt", &var_pars.hz, &xD);       // horizontal
+        read_tmp_vals("variogram_vert_tmp.txt", &var_pars.vert, &xD);   // vertical
-        T_variogram(0, TRUE, opt, &var_pars.hz, &xD.report);    // compute theoretical variogram - hz
-        T_variogram(1, TRUE, opt, &var_pars.vert, &xD.report);  // compute theoretical variogram - vert
+        // compute theoretical variogram
+        T_variogram(0, opt, &var_pars.hz, &xD); // horizontal
+        T_variogram(1, opt, &var_pars.vert, &xD);       // vertical
         /* compare range of hz and vert variogram:
            - if the difference is greater than 5% -> bivariate variogram
@@ -513,14 +594,28 @@
     case 2:                    // final phase:
         // Module should crash if:
         if (!opt.output->answer) {      // output name not available:
-            if (xD.report.write2file == TRUE) { // report file available:
             G_fatal_error(_("Please set up name of output layer..."));
+        if (opt.trend_a->answer) {
+            out.trend[0] = atof(opt.trend_a->answer);
+            out.trend[1] = atof(opt.trend_b->answer);
+            out.trend[2] = atof(opt.trend_c->answer);
+            out.trend[3] = atof(opt.trend_d->answer);
+        /*// read trend
+           out.add_trend = flg.detrend->answer;
+           if (out.add_trend == TRUE) {
+           out.trend = G_matrix_init();
+           out.trend->vals = get_col_values(&map, &xD, &pnts, field, opt.trend->answer); // trend
         // read properties of final variogram from temp file
         if (xD.i3 == TRUE) {    // 3D kriging:
             read_tmp_vals("variogram_final_tmp.txt", &var_pars.fin, &xD);
@@ -537,10 +632,10 @@
                  opt.function_var_final_vert->answer) &&
                 (opt.function_var_final->answer ||
                  opt.function_var_final_vert->answer)) {
                 G_fatal_error(_("If you wish to specify components of bivariate variogram please set up function type for both of them..."));
@@ -548,76 +643,86 @@
             // if both of the function types are set up:
             if (opt.function_var_final->answer &&
                 opt.function_var_final_vert->answer) {
-                if (!opt.nugget_final->answer) {        // horizontal nugget effect should not be missing
+                // horizontal nugget effect should not be missing
+                if (!opt.nugget_final->answer) {
                     G_fatal_error(_("Please set up nugget effect of horizontal component of bivariate variogram..."));
-                if (!opt.nugget_final_vert->answer) {   // vertical nugget effect should not be missing
+                // vertical nugget effect should not be missing
+                if (!opt.nugget_final_vert->answer) {
                     G_fatal_error(_("Please set up nugget effect of vertical component of bivariate variogram..."));
-                if (!opt.range_final->answer) { // horizontal range should not be missing
+                // horizontal range should not be missing
+                if (!opt.range_final->answer) {
                     G_fatal_error(_("Please set up range of horizontal component of bivariate variogram..."));
-                if (!opt.range_final_vert->answer) {    // vertical range should not be missing
+                // vertical range should not be missing
+                if (!opt.range_final_vert->answer) {
                     G_fatal_error(_("Please set up range of vertical component of bivariate variogram..."));
-        else {                  // univariate variogram
+        // univariate variogram
+        else {
             if (xD.i3 == TRUE && (strcmp(opt.function_var_final->answer, "linear") != 0 && strcmp(opt.function_var_final->answer, "parabolic") != 0)) { // anisotropic 3D:
                 if (opt.function_var_final_vert->answer || atof(opt.nugget_final_vert->answer) != 0. || opt.range_final_vert->answer) { // vertical settings available:
                     G_fatal_error(_("Not necessary to set up vertical components properties. Anisotropic variogram will be used..."));
                 }               // end if vert settings available
             }                   // end if 3D
-            if (!opt.function_var_final->answer) {      // missing function
+            // missing function
+            if (!opt.function_var_final->answer) {
                 opt.function_var_final->answer = "linear";
                 G_message(_("Linear variogram will be computed..."));
-            if (strcmp(opt.function_var_final->answer, "linear") != 0 && strcmp(opt.function_var_final->answer, "parabolic") != 0) {    // nonlinear and not parabolic:
+            // nonlinear and not parabolic:
+            if (strcmp(opt.function_var_final->answer, "linear") != 0 &&
+                strcmp(opt.function_var_final->answer, "parabolic") != 0) {
                 if (!opt.nugget_final->answer) {        // missing horizontal nugget effect
                     G_fatal_error(_("Please set up nugget effect..."));
                 }               // end if nugget missing
-                if (!opt.range_final->answer) { // missing horizontal range:
+                // missing horizontal range:
                     G_fatal_error(_("Please set up range..."));
                 }               // end if range missing
-                if (opt.sill_final->answer) {   // missing horizontal range:
+                if (opt.sill_final->answer) {
                     var_pars.fin.sill = atof(opt.sill_final->answer);
                 }               // end if sill has been changed by the user
             }                   // end nonlinear and not parabolic variogram
@@ -625,11 +730,13 @@
         out.name = opt.output->answer;  // Output layer name
-        if (var_pars.fin.type == 3) {   // if variogram is anisotropic:
+        // if variogram is anisotropic:
+        if (var_pars.fin.type == 3) {
             geometric_anisotropy(&xD, &pnts);   // exaggerate z coord and rebuild the spatial index
-        T_variogram(var_pars.fin.type, xD.i3, opt, &var_pars.fin, &xD.report);  // compute theoretical variogram
+        T_variogram(var_pars.fin.type, opt, &var_pars.fin, &xD);
         break;
Modified: grass-addons/grass7/vector/v.kriging/quantile.c
--- grass-addons/grass7/vector/v.kriging/quantile.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/quantile.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -178,7 +178,7 @@
         *quantile = v;
         prev_v = v;
-        if (report != NULL && report->write2file == TRUE)
+        if (report != NULL && report->name)
             fprintf(report->fp, "%f:%f:%f\n", prev_v, v, quants[quant]);
Modified: grass-addons/grass7/vector/v.kriging/spatial_index.c
--- grass-addons/grass7/vector/v.kriging/spatial_index.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/spatial_index.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -75,8 +75,8 @@
         NN_sum = list->n_values;
         if (NN_sum < 2) {
-            G_warning(_("Point \"x=%f y=%f z=%f\" has less than 2 neighbours in its closest surrounding. The perimeter of the surrounding will be increased to include more neighbouring points"),
-                      *r, *(r + 1), *(r + 2));
+            /*G_fatal_error(_("Point \"x=%f y=%f z=%f\" has less than 2 neighbours in its closest surrounding. The perimeter of the surrounding will be increased to include more neighbouring points. If this warning appears regularly, please check your region settings."),
+             *r, *(r + 1), *(r + 2));*/
             max_dist += dist_step;
             max_dist_vert += dist_step_vert;
@@ -112,7 +112,7 @@
     // check spherical (circular) surrounding
-    list = find_NNs_within(dim, search, pnts, sqrt(2.) * max_dist, -1);
+    list = find_NNs_within(dim, search, pnts, max_dist, -1);
     return list;
Modified: grass-addons/grass7/vector/v.kriging/utils.c
--- grass-addons/grass7/vector/v.kriging/utils.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/utils.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -16,51 +16,6 @@
         return 0;
-void correct_indices(struct ilist *list, double *r0, struct points *pnts,
-                     struct parameters *var_pars)
-    int i;
-    int n = list->n_values;
-    int *vals = list->value;
-    double dx, dy, dz;
-    int type = var_pars->type;
-    int n_new = 0;              // # of effective indices (not identical points, nor too far)
-    int *newvals, *save;        // effective indices
-    newvals = (int *)G_malloc(n * sizeof(int));
-    save = &newvals[0];
-    double *r, sqDist_i;
-        *vals -= 1;
-        r = &pnts->r[3 * *vals];
-        dx = *r - *r0;
-        dy = *(r + 1) - *(r0 + 1);
-        dz = *(r + 2) - *(r0 + 2);
-        sqDist_i = SQUARE(dx) + SQUARE(dy) + SQUARE(dz);
-        if (type != 2 && (n == 1 || (sqDist_i != 0.))) {
-            *save = *vals;
-            n_new++;
-            save++;
-        vals++;
-    if (type != 2 && n_new < n) {
-        list->n_values = n_new;
-        list->value = (int *)G_realloc(list->value, n_new * sizeof(int));
-        memcpy(list->value, newvals, n_new * sizeof(int));
-    G_free(newvals);
-    return;
 // make coordinate triples xyz
 void triple(double x, double y, double z, double *triple)
@@ -97,7 +52,7 @@
 // compute horizontal radius from coordinate differences
-double radius_hz_diff(double *dr)
+double radius_hz_diff(double dr[3])
     double rds;
@@ -106,6 +61,25 @@
     return rds;
+double squared_distance(int direction, double *dr)
+    double d;
+    switch (direction) {
+    case 12:                   // horizontal
+        d = SQUARE(dr[0]) + SQUARE(dr[1]);
+        break;
+    case 3:                    // vertical
+        d = SQUARE(dr[2]);
+        break;
+    case 0:                    // all
+        d = SQUARE(dr[0]) + SQUARE(dr[1]) + SQUARE(dr[2]);
+        break;
+    return d;
 // compute zenith angle
 double zenith_angle(double dr[3])
@@ -116,8 +90,66 @@
     return zenith;
+void correct_indices(int direction, struct ilist *list, double *r0,
+                     struct points *pnts, struct parameters *var_pars)
+    int i;
+    int n = list->n_values;
+    int *vals = list->value;
+    double dr[3];
+    int type = var_pars->type;
+    double max_dist = var_pars->max_dist;
+    int skip = FALSE;           // do not skip relevant points
+    int n_new = 0;              // # of effective indices (not identical points, nor too far)
+    int *newvals, *save;        // effective indices
+    // values of the new list (if necesary)
+    newvals = (int *)G_malloc(n * sizeof(int));
+    save = &newvals[0];
+    double *r, sqDist_i;
+    for (i = 0; i < n; i++) {
+        *vals -= 1;             // decrease value by 1
+        r = &pnts->r[3 * *vals];        // find point coordinates
+        // coordinate differences
+        *dr = *r - *r0;
+        *(dr + 1) = *(r + 1) - *(r0 + 1);
+        *(dr + 2) = *(r + 2) - *(r0 + 2);
+        // compute squared distance
+        sqDist_i = squared_distance(direction, dr);
+        // compare with maximum
+        skip = sqDist_i <= max_dist ? FALSE : TRUE;
+        // if:
+        // - univariate variogram with only one non-zero value or
+        // - the distance (circular) does not exceed max_dist
+        if (type != 2 && (n == 1 || (sqDist_i != 0.)) || skip == FALSE) {
+            *save = *vals;
+            n_new++;
+            save++;
+            skip = FALSE;
+        vals++;
+    if (type != 2 && n_new < n) {
+        list->n_values = n_new;
+        list->value = (int *)G_realloc(list->value, n_new * sizeof(int));
+        memcpy(list->value, newvals, n_new * sizeof(int));
+    G_free(newvals);
+    return;
 // compute size of the lag
-double lag_size(int direction, struct points *pnts,
+double lag_size(int i3, int direction, struct points *pnts,
     // local variables
@@ -168,7 +200,7 @@
                 coord_diff(i, (*j_vals - 1), pnts->r, dr);      // compute coordinate differences
                 switch (direction) {    // and count those which equal to zero
-                    if (dr[0] == 0. && dr[1] == 0.) {
+                    if (i3 == FALSE && (dr[0] == 0. && dr[1] == 0.)) {
                         add_ident++;
                     break;
@@ -188,16 +220,12 @@
         }                       //end if: n_vals > 0
         else {
             G_fatal_error(_("Error: There are no nearest neighbours of point %d..."),
                           i);
         }                       // end error
-        perc5 = (int)round(0.05 * n) + add_ident;       // set up 5% increased by number of identical points
+        perc5 = (int)ceil(0.05 * n) + add_ident;        // set up 5% increased by number of identical points
         coord_diff(i, perc5, pnts->r, dr);      // coordinate differences of search point and 5%th NN
         switch (direction) {    // compute squared distance for particular direction
@@ -216,13 +244,12 @@
             d_min = MIN(d_min, dist2);
         r += 3;                 // go to next search point
     }                           // end i for loop: distance of i-th search pt and 5%-th NN
     lagNN = sqrt(d_min);
     return lagNN;
@@ -296,7 +323,7 @@
 void variogram_restricts(struct int_par *xD, struct points *pnts,
-    struct write *report = &xD->report;
+    struct write *report = xD->report;
     double *min, *max;          // extend
     double dr[3];               // coordinate differences
@@ -308,6 +335,7 @@
     // Find extent
     G_message(_("Computing %s variogram properties..."), type);
     min = &pnts->r_min[0];      // set up pointer to minimum xyz
     max = &pnts->r_max[0];      // set up pointer to maximum xyz
@@ -317,16 +345,26 @@
     switch (var_pars->type) {
-        var_pars->max_dist = dr[2];     // zmax - zmin
+        if (var_pars->max_dist == -1.) {
+            var_pars->max_dist = dr[2]; // zmax - zmin
         var_pars->radius = SQUARE(var_pars->max_dist);  // anisotropic distance (todo: try also dz)
         break;
     default:
-        var_pars->radius = radius_hz_diff(dr) / 9.;     // horizontal radius (1/9)
-        var_pars->max_dist = sqrt(var_pars->radius);    // 1/3 max horizontal dist (Surfer, Golden SW)
+            var_pars->radius = radius_hz_diff(dr) / 9.; // horizontal radius (1/9)
+            var_pars->max_dist = sqrt(var_pars->radius);        // 1/3 max horizontal dist (Surfer, Golden SW)
+        else {
+            var_pars->radius = SQUARE(var_pars->max_dist);
         break;
+    if (var_pars->max_dist <= 0.) {
+        G_fatal_error(_("Maximum distance must be greater than 0."));
-    if (report->write2file == TRUE) {   // report name available:
+    if (report->name) {         // report name available:
         write2file_varSetsIntro(var_pars->type, report);        // describe properties
@@ -345,27 +383,42 @@
     if (var_pars->type == 2) {  // bivariate variogram
         // horizontal direction:
-        var_pars->lag = lag_size(12, pnts, var_pars, report);   // lag distance
-        var_pars->nLag = lag_number(var_pars->lag, &var_pars->max_dist);        // number of lags
-        optimize(&var_pars->lag, &var_pars->nLag, var_pars->max_dist);
-        var_pars->max_dist = var_pars->nLag * var_pars->lag;    // maximum distance
+        if (var_pars->nLag == -1) {
+            var_pars->lag = lag_size(xD->i3, 12, pnts, var_pars, report);       // lag distance
+            var_pars->nLag = lag_number(var_pars->lag, &var_pars->max_dist);    // number of lags
+            optimize(&var_pars->lag, &var_pars->nLag, var_pars->max_dist);
+            var_pars->max_dist = var_pars->nLag * var_pars->lag;        // maximum distance
+        else {
+            var_pars->lag = var_pars->max_dist / var_pars->nLag;        // lag size
         // vertical direction
-        var_pars->lag_vert = lag_size(3, pnts, var_pars, report);       // lag distance
-        var_pars->nLag_vert = lag_number(var_pars->lag_vert, &var_pars->max_dist_vert); // # of lags
-        optimize(&var_pars->lag_vert, &var_pars->nLag_vert,
-                 var_pars->max_dist_vert);
-        var_pars->max_dist_vert = var_pars->nLag_vert * var_pars->lag_vert;     // max distance
+        if (var_pars->nLag_vert == -1) {
+            var_pars->lag_vert = lag_size(xD->i3, 3, pnts, var_pars, report);   // lag distance
+            var_pars->nLag_vert = lag_number(var_pars->lag_vert, &var_pars->max_dist_vert);     // # of lags
+            optimize(&var_pars->lag_vert, &var_pars->nLag_vert,
+                     var_pars->max_dist_vert);
+            var_pars->max_dist_vert = var_pars->nLag_vert * var_pars->lag_vert; // max distance
+        else {
+            var_pars->lag_vert = var_pars->max_dist_vert / var_pars->nLag_vert; // lag size
     else {                      // univariate variograms (hz / vert / aniso)
-        var_pars->lag = lag_size(dimension, pnts, var_pars, report);    // lag size
-        var_pars->nLag = lag_number(var_pars->lag, &var_pars->max_dist);        // # of lags
+            var_pars->lag = lag_size(xD->i3, dimension, pnts, var_pars, report);        // lag size
+            var_pars->nLag = lag_number(var_pars->lag, &var_pars->max_dist);    // # of lags
+        else {
         write2file_varSets(report, var_pars);   // describe properties
@@ -376,10 +429,10 @@
     double ratio = xD->aniso_ratio;
     if (ratio <= 0.) {          // ratio is negative or zero:
-        if (xD->report.name) {  // close report file
-            fprintf(xD->report.fp,
                     "Error (see standard output). Process killed...");
-            fclose(xD->report.fp);
         G_fatal_error(_("Anisotropy ratio must be greater than zero..."));
@@ -446,11 +499,7 @@
         function = 5;
     else {
-        if (report->write2file == TRUE) {       // close report file
-            fprintf(report->fp,
-                    "Error (see standard output). Process killed...");
+        report_error(report);
         G_fatal_error(_("Set up correct name of variogram function..."));
@@ -508,6 +557,7 @@
     gp = fopen("dataE.dat", "w");       // open file to write experimental variogram (initial phase)
     if (access("dataE.dat", W_OK) < 0) {
+        report_error(xD->report);
         G_fatal_error(_("Something went wrong opening tmp file..."));
@@ -620,14 +670,16 @@
     fclose(gp);
-    if (xD->report.write2file == FALSE) {
+    if (!xD->report->name) {
         remove("dataE.dat");
 // plot experimental and theoretical variogram
-void plot_var(int i3, int bivar, struct parameters *var_pars)
+void plot_var(struct int_par *xD, int bivar, struct parameters *var_pars)
+    int i3 = xD->i3;
     int function;
     double nugget, nugget_h, nugget_v;
     double sill;
@@ -666,9 +718,11 @@
     if (type != 2) {            // univariate variogram
         if (gp == NULL) {
             G_fatal_error(_("Error writing file"));
@@ -688,17 +742,20 @@
     else {                      // bivariate variogram
         gp = fopen("dataE.dat", "r");   // open file to read experimental variogram
         if (access("dataE.dat", F_OK) < 0) {
             G_fatal_error(_("You have probably deleted dataE.dat - process middle phase again, please."));
     if (fclose(gp) != 0) {
         G_fatal_error(_("Error closing file..."));
     /* Theoretical variogram */
     gp = fopen("dataT.dat", "w");       // open file to write theoretical variogram
     if (access("dataT.dat", W_OK) < 0) {
@@ -789,6 +846,7 @@
     if (fclose(gp) == EOF) {
@@ -925,3 +983,16 @@
     remove("dataT.dat");
+void new_vertical(int *row0, int n)
+    int i;
+    int *value;
+    value = &row0[0];
+        *value = 0;
+        value++;
Modified: grass-addons/grass7/vector/v.kriging/utils_kriging.c
--- grass-addons/grass7/vector/v.kriging/utils_kriging.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/utils_kriging.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -45,7 +45,6 @@
                 switch (var_par->function) {    // function of theoretical variogram
                 case 0:        // linear variogram
                     G_matrix_set_element(var_par->A, nr, 0, *h);
-                    //G_matrix_set_element(var_par->A, nr, 1, 1.);
                     break;
                 case 1:        // parabolic variogram
                     G_matrix_set_element(var_par->A, nr, 0, SQUARE(*h));
@@ -73,7 +72,7 @@
     // Test of theoretical variogram estimation
     if (var_par->T->vals == NULL) {     // NULL values of theoretical variogram
             fprintf(report->fp,
             fclose(report->fp);
@@ -89,11 +88,17 @@
     // coefficients of theoretical variogram (linear)
     if (report->name) {
-        fprintf(report->fp, "Parameters of bivariate variogram:\n");
-        fprintf(report->fp, "Function: linear\n\n");
-        fprintf(report->fp, "gamma(h, vert) = %f * h + %f * vert + %f\n",
-                var_par->T->vals[0], var_par->T->vals[1],
-                var_par->T->vals[2]);
+        if (var_par->function == 5) {
+            fprintf(report->fp, "Parameters of bivariate variogram:\n");
+            fprintf(report->fp, "gamma(h, vert) = %f * h + %f * vert + %f\n",
+                    var_par->T->vals[0], var_par->T->vals[1],
+                    var_par->T->vals[2]);
+        else {
+            fprintf(report->fp, "Parameters of univariate variogram:\n");
+                    var_par->T->vals[0], var_par->T->vals[1]);
     }                           // end if: report
@@ -192,6 +197,7 @@
     else if (xD->univar == TRUE || (!flg->bivariate->answer && diff_sill <= diff_sill_05)) {    // geometric anisotropy
         var_par->fin.type = 3;  // variogram type: anisotropic
         var_par->fin.max_dist = var_par->hz.max_dist;   // maximum distance: hz
+        var_par->fin.nLag = var_par->hz.nLag;
         var_par->fin.td = var_par->hz.td;       // azimuth: hz
         xD->aniso_ratio = var_par->hz.h_range / var_par->vert.h_range;  // anisotropic ratio
         geometric_anisotropy(xD, pnts); // exaggerate z coords and build a new spatial index
@@ -315,8 +321,8 @@
 // set up elements of G matrix
-mat_struct *set_up_G(struct points *pnts, struct parameters *var_par,
-                     struct write *report)
+void set_up_G(struct points *pnts, struct parameters *var_par,
+              struct write *report, struct krig_pars *krig)
     // Local variables
     int n = pnts->n;            // # of input points
@@ -385,12 +391,13 @@
     }                           // end i loop
     free(dr);
-    return GM;
+    krig->GM = G_matrix_copy(GM);
 // make G submatrix for rellevant points
-mat_struct *submatrix(struct ilist * index, mat_struct * GM_all,
-                      struct write * report)
+mat_struct *submatrix(struct ilist *index, mat_struct * GM_all,
+                      struct write *report)
     // Local variables
     int n = index->n_values;    // # of selected points
@@ -506,7 +513,7 @@
         switch (i3) {
         case FALSE:
             // Cell value diffs estimation using linear variogram
-            dr[2] = 0.0;        // !!! optimalize - not to be necessary to use this line
+            dr[2] = 0.0;        // !!! optimize - not to be necessary to use this line
             break;
         case TRUE:
             dr[2] = *(r + 2) - *(r0 + 2);       // dz
@@ -571,7 +578,6 @@
     for (i = 0; i < n; i++) {   // for each input point:
         *vt = *vo;              // subval = selected original
         *wt = *wo;              // sub weight = selected original
-        //G_debug(0,"%f %f", *vt, *wt);
         // go to the next:
         if (n_ind == 0) {       // use all points:
@@ -594,9 +600,29 @@
     return rslt_OK->vals[0];
+// find center
+double find_center(double r, double res)
+    int n;
+    double center;
+    n = floor(r / res);
+    center = (n + 0.5) * res;
+    return center;
+// calculate a cell for validation
+void adjacent_cell(int i3, double *r, struct reg_par *reg, double *cell)
+    *cell = find_center(*r, reg->ew_res);
+    *(cell + 1) = find_center(*(r + 1), reg->ns_res);
+    *(cell + 2) = i3 == TRUE ? find_center(*(r + 2), reg->bt_res) : 0.;
 // validation
 void crossvalidation(struct int_par *xD, struct points *pnts,
-                     struct parameters *var_par)
+                     struct parameters *var_par, struct reg_par *reg)
     double *r = pnts->r;        // coordinates of points
@@ -607,7 +633,7 @@
     double ratio = type == 3 ? xD->aniso_ratio : 1.;    // anisotropic ratio
     mat_struct *GM = var_par->GM;       // GM = theor_var(distances)
-    int i;
+    int i, direction;
     int n_vals;
     double max_dist =
         type == 2 ? var_par->horizontal.max_dist : var_par->max_dist;
@@ -616,13 +642,23 @@
     double *search;             // coordinates of the search point
     struct ilist *list;
+    // coordinates of the adjacent cell
+    double *cell;
+    cell = (double *)G_malloc(3 * sizeof(double));
     mat_struct *GM_sub;
     mat_struct *GM_Inv, *g0, *w0;
     double rslt_OK;
-    struct write *crossvalid = &xD->crossvalid;
+    mat_struct *g0_cell, *w0_cell;
+    double rslt_OK_cell;
+    struct write *crossvalid = xD->crossvalid;
     double *normal, *absval, *norm, *av;
+    double *normal_cell, *absval_cell, *norm_cell, *av_cell;
     search = (double *)G_malloc(3 * sizeof(double));
     normal = (double *)G_malloc(n * sizeof(double));
@@ -630,50 +666,74 @@
     norm = &normal[0];
     av = &absval[0];
+    normal_cell = (double *)G_malloc(n * sizeof(double));
+    absval_cell = (double *)G_malloc(n * sizeof(double));
+    norm_cell = &normal_cell[0];
+    av_cell = &absval_cell[0];
     FILE *fp;
+    G_message(_("Crossvalidation..."));
     for (i = 0; i < n; i++) {   // for each input point [r0]:
         search = &pnts->r[3 * i];
         if (i3 == TRUE) {
             list = find_NNs_within(3, search, pnts, max_dist, max_dist_vert);
+            direction = 0;
         else {
             list = find_NNs_within(2, search, pnts, max_dist, max_dist_vert);
+            direction = 12;
         n_vals = list->n_values;        // # of overlapping rectangles
         if (n_vals > 0) {       // if positive:
-            correct_indices(list, r, pnts, var_par);
+            correct_indices(direction, list, r, pnts, var_par);
             GM_sub = submatrix(list, GM, &xD->report);  // create submatrix using indices
             GM_Inv = G_matrix_inverse(GM_sub);  // inverse matrix
+            // calculate cell
+            adjacent_cell(i3, r, reg, cell);
             g0 = set_up_g0(xD, pnts, list, r, var_par); // Diffs inputs - unknowns (incl. cond. 1))
+            g0_cell = set_up_g0(xD, pnts, list, cell, var_par); // Diffs inputs - unknowns (incl. cond. 1))
+            w0_cell = G_matrix_product(GM_Inv, g0_cell);        // Vector of weights, condition SUM(w) = 1 in last row
             G_matrix_free(g0);
+            G_matrix_free(g0_cell);
             G_matrix_free(w0);
-            //Create output
+            rslt_OK_cell = result(pnts, list, w0_cell); // Estimated cell/voxel value rslt_OK = w x inputs
+            G_matrix_free(w0_cell);
+            // Create output
             *norm = rslt_OK - *vals;    // differences between input and interpolated values
             *av = fabs(*norm);  // absolute values of the differences (quantile computation)
+            *norm_cell = rslt_OK_cell - *vals;  // differences between input and interpolated values
+            *av_cell = fabs(*norm_cell);        // absolute values of the differences (quantile computation)
             if (xD->i3 == TRUE) {       // 3D interpolation:
-                fprintf(fp, "%d %.3f %.3f %.2f %f %f %f\n", i, *r, *(r + 1),
-                        *(r + 2) / ratio, pnts->invals[i], rslt_OK, *norm);
+                fprintf(fp, "%d %.3f %.3f %.2f %f %f %f %f %f\n", i, *r,
+                        *(r + 1), *(r + 2) / ratio, pnts->invals[i], rslt_OK,
+                        *norm, rslt_OK_cell, *norm_cell);
-                fprintf(fp, "%d %.3f %.3f %f %f %f\n", i, *r, *(r + 1), *vals,
-                        rslt_OK, *norm);
+                fprintf(fp, "%d %.3f %.3f %f %f %f %f %f\n", i, *r, *(r + 1),
+                        *vals, rslt_OK, *norm, rslt_OK_cell, *norm_cell);
         }                       // end if: n_vals > 0
@@ -687,6 +747,8 @@
         vals++;
         norm++;
         av++;
+        norm_cell++;
+        av_cell++;
         G_free_ilist(list);     // free list memory
     }                           // end i for loop
@@ -696,15 +758,160 @@
               crossvalid->name);
     if (report->name) {
-        double quant95;
+        double quant95, quant95_cell;
+        report->fp = fopen(report->name, "a");
         fprintf(report->fp,
                 "\n************************************************\n");
         fprintf(report->fp, "*** Cross validation results ***\n");
         test_normality(n, normal, report);
+        test_normality(n, normal_cell, report);
-        fprintf(report->fp, "Quantile of absolute values\n");
+        fprintf(report->fp, "Quantile of absolute values (points)\n");
         quant95 = quantile(0.95, n, absval, report);
+        fprintf(report->fp, "Quantile of absolute values (cells)\n");
+        quant95_cell = quantile(0.95, n, absval_cell, report);
+struct ilist *list_NN(struct int_par *xD, double *r0, struct points *pnts,
+                      double max_dist, double max_dist_vert)
+    // local variables
+    int i3 = xD->i3;
+    struct ilist *list;
+    list = G_new_ilist();       // create list of overlapping rectangles
+    if (i3 == TRUE) {           // 3D kriging:
+        list = find_NNs_within(3, r0, pnts, max_dist, max_dist_vert);
+    else {                      // 2D kriging:
+        list = find_NNs_within(2, r0, pnts, max_dist, max_dist_vert);
+    return list;
+int compare_NN(struct ilist *list, struct ilist *list_new, int modified)
+    int n = list->n_values, n_new = list_new->n_values;
+    double *list_value = list->value;
+    double *list_new_value = list_new->value;
+    int i, next = 0;            // the samples are different
+    if (n == n_new) {
+            if (list_value[i] != list_new_value[i] - modified) {
+                goto change;    // they are indeed
+        next = 1;               // they are identical
+  change:
+    return next;
+void make_subsamples(struct int_par *xD, struct ilist *list, double *r0,
+                     int row, int col, struct points *pnts,
+                     struct parameters *var_par, struct krig_pars *krig)
+    // Local variables
+    int i3 = xD->i3;
+    double *vals = pnts->invals;
+    struct write *report = &xD->report;
+    int direction;
+    mat_struct *GM_sub;
+    direction = i3 == TRUE ? 0 : 12;
+    if (list->n_values > 1) {   // positive # of selected points:
+        correct_indices(direction, list, r0, pnts, var_par);
+        GM_sub = submatrix(list, krig->GM, report);     // make submatrix for selected points
+        krig->GM_Inv = G_matrix_inverse(GM_sub);        // invert submatrix
+        G_matrix_free(GM_sub);
+    else if (list->n_values == 1) {
+        G_matrix_set_element(krig->rslt, row, col, vals[list->value[0] - 1]);   // Estimated cell/voxel value rslt_OK = w x inputs
+    else if (list->n_values == 0) {
+        G_fatal_error(_("This point does not have neighbours in given radius..."));
+    }                           // end else: error
+    //G_free_ilist(list);     // free list memory
+double interpolate(struct int_par *xD, struct ilist *list, double *r0,
+                   struct points *pnts, struct parameters *var_par,
+                   struct krig_pars *krig)
+    double rslt;
+    mat_struct *g0, *w0;
+    g0 = set_up_g0(xD, pnts, list, r0, var_par);        // Diffs inputs - unknowns (incl. cond. 1))
+    w0 = G_matrix_product(krig->GM_Inv, g0);    // Vector of weights, condition SUM(w) = 1 in last row
+    G_matrix_free(g0);
+    rslt = result(pnts, list, w0);      // Estimated cell/voxel value rslt_OK = w x inputs
+    G_matrix_free(w0);
+    return rslt;
+double trend(double *r0, struct output *out, int function, struct int_par *xD)
+    int i3 = xD->i3;
+    double a, b, c, d, value;
+    double ratio;
+    ratio = i3 == FALSE || function == 5 ? 1. : xD->aniso_ratio;
+    a = out->trend[0];
+    b = out->trend[1];
+    c = out->trend[2];
+    d = out->trend[3];
+    value = a * *r0 + b * *(r0 + 1) + c * *(r0 + 2) / ratio + d;
+    return value;
+int new_sample(struct int_par *xD, struct ilist *list, struct ilist *list_new,
+               struct points *pnts, int dep, int row, int col, double *r0,
+               double max_dist, double max_dist_vert, struct reg_par *reg,
+               struct parameters *var_par, struct krig_pars *krig,
+               int *new_matrix)
+    int next;
+    // free memory
+    if (krig->modified == 0) {
+        G_free_ilist(list_new); // new list
+    G_matrix_free(krig->GM_Inv);        // old inverse matrix
+    // make new...
+    list = list_NN(xD, r0, pnts, max_dist, max_dist_vert);      //... list
+    cell_centre(col, row, dep, xD, reg, r0, var_par);
+    make_subsamples(xD, list, r0, dep * reg->nrows + row, col, pnts, var_par,
+                    krig);
+    // options:
+    krig->modified = 0;         // indices are not corrected
+    krig->new = TRUE;           //
+    krig->first = TRUE;         // new sample is being processed
+    *new_matrix++;              // counter of skipped matrices
+    next = 2;                   // interpolate using new subsample
+    return next;
Modified: grass-addons/grass7/vector/v.kriging/utils_raster.c
--- grass-addons/grass7/vector/v.kriging/utils_raster.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/utils_raster.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -10,58 +10,82 @@
         out->dcell = (DCELL *) Rast_allocate_buf(DCELL_TYPE);
         out->fd_2d = Rast_open_new(out->name, DCELL_TYPE);      /* open output raster */
         if (out->fd_2d < 0) {
-                fclose(report->fp);
             G_fatal_error(_("Unable to create 2D raster <%s>"), out->name);
     /* 3D Raster layer */
         out->fd_3d = (RASTER3D_Map *) Rast3d_open_cell_new(out->name, DCELL_TYPE, RASTER3D_USE_CACHE_XYZ, &reg->reg_3d);        // initialize pointer to 3D region
         if (out->fd_3d == NULL) {
             G_fatal_error(_("Unable to create 3D raster <%s>"), out->name);
-int write2layer(struct int_par *xD, struct reg_par *reg, struct output *out,
-                unsigned int col, unsigned int row, unsigned int dep,
-                double rslt_OK)
+void write2layer(struct int_par *xD, struct reg_par *reg, struct output *out,
+                 mat_struct * rslt)
     // Local variables
     int i3 = xD->i3;
+    int ndeps = reg->ndeps, nrows = reg->nrows, ncols = reg->ncols;
+    int col, row, dep;
     int pass = 0;               /* Number of processed cells */
+    double trend, value, r0[3];
+    int nulval = 0;
-    switch (i3) {
-    case FALSE:                /* set value to cell (2D) */
-        out->dcell[col] = (DCELL) (rslt_OK);
-        pass++;
-        if (col == reg->ncols - 1)
-            Rast_put_row(out->fd_2d, out->dcell, DCELL_TYPE);
-        break;
+    for (dep = 0; dep < ndeps; dep++) {
+        for (row = 0; row < nrows; row++) {
+            for (col = 0; col < ncols; col++) {
+                value = G_matrix_get_element(rslt, dep * nrows + row, col);
+                if (value == 0.) {
+                    nulval++;
-    case TRUE:                 /* set value to voxel (based on part of r3.gwflow (Soeren Gebbert)) */
-        if (Rast3d_put_double(out->fd_3d, col, row, dep, rslt_OK) == 0) {
+                switch (i3) {
+                case FALSE:    /* set value to cell (2D) */
+                    out->dcell[col] = (DCELL) (value);
+                    break;
+                case TRUE:     /* set value to voxel (based on part of r3.gwflow (Soeren Gebbert)) */
+                    if (Rast3d_put_double(out->fd_3d, col, row, dep, value) ==
+                        0) {
+                        G_fatal_error(_("Error writing cell (%d,%d,%d) with value %f."),
+                                      row, col, dep, value);
+                    break;
+                pass++;
+            }                   // end col
+            if (i3 == FALSE) {
+                Rast_put_row(out->fd_2d, out->dcell, DCELL_TYPE);
-            G_fatal_error(_("Error writing cell (%d,%d,%d) with value %f, nrows = %d"),
-                          row, col, dep, rslt_OK, reg->nrows);
+        }                       // end row
+    }                           // end dep
+    switch (i3) {
+    case TRUE:
+        if (!Rast3d_close(out->fd_3d)) {        // Close 3D raster map
+            G_fatal_error(_("Something went wrong with 3D raster: the pointer disappeared before closing..."));
-        pass++;
         break;
+    case FALSE:
+        Rast_close(out->fd_2d); // Close 2D raster map
+        break;
-    return pass;
+    if (nulval > 0) {
+        G_message(_("0 values: %d"), nulval);
+    if (pass != ndeps * ncols * nrows) {
+        G_fatal_error(_("The number of processed cells (%d) is smaller than total number of cells (%d)..."),
+                      pass, ndeps * ncols * nrows);
Modified: grass-addons/grass7/vector/v.kriging/utils_write.c
--- grass-addons/grass7/vector/v.kriging/utils_write.c	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/utils_write.c	2017-06-08 10:32:49 UTC (rev 71171)
@@ -20,8 +20,10 @@
 void write2file_basics(struct int_par *xD, struct opts *opt)
     fprintf(report->fp, "************************************************\n");
     fprintf(report->fp, "*** Input ***\n\n");
     fprintf(report->fp, "- vector layer: %s\n", opt->input->answer);
@@ -51,8 +53,10 @@
 void write2file_vector(struct int_par *xD, struct points *pnts)
     struct select in_reg = pnts->in_reg;
     fprintf(report->fp, "\n");
     fprintf(report->fp, "*** Input vector layer properties ***\n\n");
@@ -135,7 +139,7 @@
     double *h, *vert;
     double *c;
     double *gamma;
     char type[12];
@@ -234,24 +238,24 @@
     switch (type) {
     case 0:                    // horizontal variogram
         fp = fopen("variogram_hz_tmp.txt", "w");
-        if (xD->report.write2file) {    // write name of report file
-            file_length = strlen(xD->report.name);
+        if (xD->report->name) { // write name of report file
+            file_length = strlen(xD->report->name);
             if (file_length < 4) {      // 4 types of variogram
                 G_fatal_error(_("File name must contain more than 2 characters..."));   // todo: error
-            fprintf(fp, "%d 9 %s\n", file_length, xD->report.name);
+            fprintf(fp, "%d 9 %s\n", file_length, xD->report->name);
         fprintf(fp, "%d\n", var_pars->type);    // write # of lags
         break;
     case 1:                    // vertical variogram
         fp = fopen("variogram_vert_tmp.txt", "w");
-        if (xD->report.write2file == TRUE) {    // write name of report file
             if (file_length < 3) {
         fprintf(fp, "%d\n", var_pars->type);    // write type
         break;
@@ -259,12 +263,12 @@
     case 2:                    // bivariate variogram
         fp = fopen("variogram_final_tmp.txt", "w");
@@ -279,12 +283,12 @@
     case 3:                    // anisotropic variogram
-        if (xD->report.name) {  // write name of report file
                 G_fatal_error(_("File name must contain more than 4 characters..."));   // todo: error
         fprintf(fp, "%f\n", xD->aniso_ratio);   // write ratio of anisotropy
@@ -334,3 +338,11 @@
     fclose(fp);
+void report_error(struct write *report)
+    if (report->name) {         // close report file
+        fprintf(report->fp, "Error (see standard output). Process killed...");
Modified: grass-addons/grass7/vector/v.kriging/v.kriging.html
--- grass-addons/grass7/vector/v.kriging/v.kriging.html	2017-06-08 07:59:33 UTC (rev 71170)
+++ grass-addons/grass7/vector/v.kriging/v.kriging.html	2017-06-08 10:32:49 UTC (rev 71171)
@@ -45,7 +45,9 @@
 </pre></div>
 <p>
-Commands based on the <a href="http://grass.osgeo.org/download/sample-data/" target="_blank">dataset</a> of <b>Slovakia 3D precipitation</b> (<i>Mitasova and Hofierka, 2004</i>). Another examples of 3D interpolation are available in (<i>Stopkova, 2014</i>).
+Commands based on the <a href="http://grass.osgeo.org/download/sample-data/" target="_blank">dataset</a> of <b>Slovakia
+3D precipitation</b> (<i>Mitasova and Hofierka, 2004</i>). For more detailed information check <a href="v.kriging.pdf"
+target="_blank">case studies</a>. Another examples of 3D interpolation are available in (<i>Stopkova, 2014</i>).
 <div class="code"><pre>
 v.kriging phase=initial in=precip3d at PERMANENT ic=precip report=precip3d.txt file=png --o
@@ -71,7 +73,10 @@
   out=name crossval=crossval_file.txt -2
 </pre></div>
-<p> Commands based on 500 random points extracted from input points of Digital Elevation Model (DEM) <i>elev_lid792_randpts</i> from the <b>North Carolina <a href="http://grass.osgeo.org/download/sample-data/" target="_blank">dataset</a></b> (<i>Neteler and Mitasova, 2004</i>).
+<p> Commands based on 500 random points extracted from input points of Digital Elevation Model (DEM)
+<i>elev_lid792_randpts</i> from the <b>North Carolina
+<a href="http://grass.osgeo.org/download/sample-data/" target="_blank">dataset</a></b> (<i>Neteler and Mitasova, 2004</i>).
+See the <a href="v.kriging.pdf" target="_blank">case studies</a>.
 v.kriging phase=initial in=elev_lid792_selected ic=value azimuth=45. td=45. \
@@ -84,7 +89,6 @@
 <h2>TODO</h2>
 <ul>
-<li>final phase still needs <b>optimization</b></li>
 <li><b>anisotropy</b> in horizontal direction missing
 <li>current version is suitable just for <b>metric coordinate systems</b>
 <li>enable <b>mask usage</b>
@@ -92,6 +96,12 @@
 <li><b>2D interpolation from 3D input layer</b> needs to be rebuilt (especially in case that there are too many points located on identical horizontal coordinates with different elevation)
 </ul>
+<h2>Recommendations</h2>
+<ul>
+<li> In case of too much <i>warnings</i> about input points that have "<b>less than 2 neighbours in its closest surrounding</b>. The perimeter of the surrounding will be increased...", please consider shorter variogram range.
+<li> Save just figures with theoretical variogram (using <i>file=extension</i> in the middle and final phase). Experimental variograms are included in the theoretical variogram plot and separate "experimental" plots can be just temporal.
+</ul>
 <h2>REFERENCES</h2>
 <table>
