[GRASS-SVN] r71206 - grass-addons/grass7/raster/r.mblend
svn_grass at osgeo.org
Thu Jun 22 02:57:00 PDT 2017
Author: Lads
Date: 2017-06-22 02:57:00 -0700 (Thu, 22 Jun 2017)
New Revision: 71206
grass-addons/grass7/raster/r.mblend/r.mblend.py
Release v1.1
Modified: grass-addons/grass7/raster/r.mblend/r.mblend.py
--- grass-addons/grass7/raster/r.mblend/r.mblend.py 2017-06-22 07:01:40 UTC (rev 71205)
+++ grass-addons/grass7/raster/r.mblend/r.mblend.py 2017-06-22 09:57:00 UTC (rev 71206)
@@ -55,11 +55,13 @@
import os
import atexit
+import math
from time import gmtime, strftime
import grass.script as gscript
index = 0
far_edge_value = '0'
+d_max = None
TMP_MAPS = []
WEIGHT_MAX = 10000
COL_VALUE = 'value'
@@ -79,10 +81,18 @@
while len(TMP_MAPS) > 0:
gscript.run_command('g.remove', type='all', name=TMP_MAPS.pop(),
flags='f', quiet=True)
+def compute_d_max(region):
+ global d_max
+ print("Region:\n" + str(region))
+ d_max = math.sqrt(math.pow(region['w'] - region['e'], 2) -
+ math.pow(region['n'] - region['s'], 2)) / 100
def main():
global far_edge_value
+ global d_max
options, flags = gscript.parser()
high = options['high']
@@ -122,6 +132,8 @@
cell_side = region['nsres']
else:
cell_side = region['ewres']
+ compute_d_max(region)
# Make cell size compatible
low_res_inter = getTemporaryIdentifier()
@@ -151,13 +163,20 @@
output=interpol_area, operator='not')
# Compute difference between the two rasters and vectorise to points
+ interpol_area_buff = getTemporaryIdentifier()
diff = getTemporaryIdentifier()
- diff_points = getTemporaryIdentifier()
+ diff_points_edge = getTemporaryIdentifier()
gscript.mapcalc(diff + ' = ' + high + ' - ' + low_res_inter)
+ gscript.message(_("[r.mblend] Computing buffer around interpolation area"))
+ gscript.run_command('v.buffer', input=interpol_area,
+ output=interpol_area_buff, type='area',
+ distance=cell_side)
gscript.message(_("[r.mblend] Vectorising differences between input" +
" rasters"))
- gscript.run_command('r.to.vect', input=diff, output=diff_points,
+ gscript.run_command('r.mask', vector=interpol_area_buff)
+ gscript.run_command('r.to.vect', input=diff, output=diff_points_edge,
type='point')
+ gscript.run_command('r.mask', flags='r')
# Compute average of the differences if flag -a was passed
if use_average_differences:
@@ -170,23 +189,11 @@
far_edge_value = vector[1]
p.wait()
- # Obtain edge points of the high resolution raster
- interpol_area_buff = getTemporaryIdentifier()
- diff_points_edge = getTemporaryIdentifier()
- # 1. buffer around area of interest - pixel size must be known
- gscript.message(_("[r.mblend] Computing buffer around interpolation area"))
- gscript.run_command('v.buffer', input=interpol_area,
- output=interpol_area_buff, type='area',
- distance=cell_side)
- # 2. get the points along the edge
- gscript.message(_("[r.mblend] Selecting points along the near edge"))
- gscript.run_command('v.select', ainput=diff_points,
- binput=interpol_area_buff, output=diff_points_edge,
- operator='overlap')
# Get points in low resolution farther away from high resolution raster
dist_high = getTemporaryIdentifier()
weights = getTemporaryIdentifier()
+ interpol_area_points = getTemporaryIdentifier()
+ pre_interpol_area_points = getTemporaryIdentifier()
weight_points = getTemporaryIdentifier()
interpol_area_in_buff = getTemporaryIdentifier()
weight_points_all_edges = getTemporaryIdentifier()
@@ -199,41 +206,47 @@
gscript.message(_("[r.mblend] Rescaling distance to [0,10000] interval"))
gscript.run_command('r.rescale', input=dist_high, output=weights,
to='0,' + str(WEIGHT_MAX))
- # 3. Vectorise distances to points
- gscript.message(_("[r.mblend] Vectorising distances to points"))
- gscript.run_command('r.to.vect', input=weights, output=weight_points,
- type='point')
- # 4. Create inner buffer to interpolation area
- gscript.message(_("[r.mblend] Computing inner buffer to" +
- " interpolation area"))
- output=interpol_area_in_buff, type='area',
- distance='-' + str(cell_side))
- # 5. Select points at the border
- gscript.message(_("[r.mblend] Selecting all points around inner buffer"))
- gscript.run_command('v.select', ainput=weight_points,
- binput=interpol_area_in_buff,
- output=weight_points_all_edges, operator='disjoint')
- # 6. Select those with higher weights
+ # 3. Extract points from interpolation area border
+ gscript.message(_("[r.mblend] Extract points from interpolation area " +
+ "boundary"))
+ gscript.run_command('v.to.points', input=interpol_area,
+ output=pre_interpol_area_points, type='boundary',
+ dmax=d_max, layer='-1')
+ gscript.message(_("[r.mblend] Copying features to layer 1"))
+ gscript.run_command('v.category', input=pre_interpol_area_points,
+ output=interpol_area_points, option='chlayer',
+ layer='2,1')
+ gscript.message(_("[r.mblend] Linking attribute table to layer 1"))
+ gscript.run_command('v.db.connect', map=interpol_area_points,
+ table=interpol_area_points, layer='1', flags='o')
+ # 4. Query distances to interpolation area points
+ gscript.message(_("[r.mblend] Querying distances raster"))
+ gscript.run_command('v.what.rast', map=interpol_area_points,
+ raster=weights, column=COL_VALUE)
+ # 5. Select those with higher weights
cut_off = str(far_edge / 100 * WEIGHT_MAX)
gscript.message(_("[r.mblend] Selecting far edge points (using cut-off" +
" percentage)"))
- gscript.run_command('v.extract', input=weight_points_all_edges,
+ gscript.run_command('v.extract', input=interpol_area_points,
output=weight_points_edge,
where=COL_VALUE + '>' + cut_off)
# Merge the two point edges and set low res edge to zero
points_edges = getTemporaryIdentifier()
+ gscript.message(_("[r.mblend] Dropping extra column from far edge"))
+ gscript.run_command('v.db.dropcolumn', map=weight_points_edge, layer='1',
+ columns='along')
gscript.message(_("[r.mblend] Setting far edge weights to zero"))
gscript.run_command('v.db.update', map=weight_points_edge,
column=COL_VALUE, value=far_edge_value)
gscript.message(_("[r.mblend] Patching the two edges"))
gscript.run_command('v.patch',
- input=weight_points_edge + ',' + diff_points_edge,
+ input=diff_points_edge + ',' + weight_points_edge,
output=points_edges, flags='e')
- # Interpolate stitching raster
+ # Interpolate smoothing raster
smoothing = getTemporaryIdentifier()
+ interpol_area_rst = getTemporaryIdentifier()
# Consign region to interpolation area
gscript.run_command('g.region', vector=interpol_area_buff)
gscript.message(_("[r.mblend] Interpolating smoothing surface. This" +
@@ -251,7 +264,7 @@
# Add both rasters
try:
gscript.message(_("[r.mblend] Joining result into a single raster"))
- gscript.run_command('r.patch', input=smooth_low_res + ',' + high,
+ gscript.run_command('r.patch', input=high + ',' + smooth_low_res,
output=output)
except Exception, ex:
gscript.error(_("[r.mblend] ERROR: Failed to create smoothed raster."))
