[GRASS-SVN] r71213 - grass/trunk/lib/python/ctypes/ctypesgencore/parser
svn_grass at osgeo.org
Sat Jun 24 02:35:35 PDT 2017
Author: neteler
Date: 2017-06-24 02:35:35 -0700 (Sat, 24 Jun 2017)
New Revision: 71213
grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
python ctypesgencore: partial revert of r71196 - float1.diff (trac #3331)
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py 2017-06-23 06:55:26 UTC (rev 71212)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py 2017-06-24 09:35:35 UTC (rev 71213)
@@ -3,6 +3,6 @@
_lexreflags = 0
_lexliterals = ''
_lexstateinfo = {'INITIAL': 'inclusive', 'DEFINE': 'exclusive'}
-_lexstatere = {'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:0[0-7]+)|(?:[1-9][0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INIT
IAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, Non
e]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:0[0-7]+)|(?:[1-9][0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
+_lexstatere = {'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|
(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_
int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
_lexstateignore = {'INITIAL': ' \t\x0b\x0c\r', 'DEFINE': ' \t\x0b\x0c\r'}
_lexstateerrorf = {'INITIAL': 't_INITIAL_error', 'DEFINE': 't_DEFINE_error'}
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2017-06-23 06:55:26 UTC (rev 71212)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2017-06-24 09:35:35 UTC (rev 71213)
@@ -240,7 +240,7 @@
return t
-INT_LITERAL = sub(r"(?P<p1>(?:0x{H}+)|(?:0[0-7]+)|(?:[1-9]{D}+))(?P<suf>{IS})")
+INT_LITERAL = sub(r"(?P<p1>(?:0x{H}+)|(?:{D}+))(?P<suf>{IS})")
@TOKEN(INT_LITERAL)
