[GRASS-SVN] r71228 - grass/trunk/raster/r.resamp.bspline
svn_grass at osgeo.org
Mon Jun 26 11:07:54 PDT 2017
Author: mmetz
Date: 2017-06-26 11:07:54 -0700 (Mon, 26 Jun 2017)
New Revision: 71228
grass/trunk/raster/r.resamp.bspline/main.c
r.resamp.bspline: bugfix, remove unused variables, avoid Segment_[get|put}_row()
Modified: grass/trunk/raster/r.resamp.bspline/main.c
--- grass/trunk/raster/r.resamp.bspline/main.c 2017-06-26 18:05:12 UTC (rev 71227)
+++ grass/trunk/raster/r.resamp.bspline/main.c 2017-06-26 18:07:54 UTC (rev 71228)
@@ -38,7 +38,6 @@
double N_extension, E_extension, edgeE, edgeN;
double stepN, stepE;
- const char *inrast, *outrast;
char title[64];
int dim_vect, nparameters, BW;
@@ -157,9 +156,6 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- inrast = in_opt->answer;
- outrast = out_opt->answer;
if (!strcmp(method_opt->answer, "bilinear"))
interp_method = P_BILINEAR;
else
@@ -241,6 +237,18 @@
nsubregions = nsubregion_row * nsubregion_col;
+ if (G_projection() == PROJECTION_LL) {
+ /* try to shift source window to overlap with destination window */
+ while (src_reg.west >= dest_reg.east && src_reg.east - 360.0 > dest_reg.west) {
+ src_reg.east -= 360.0;
+ src_reg.west -= 360.0;
+ while (src_reg.east <= dest_reg.west && src_reg.west + 360.0 < dest_reg.east) {
+ src_reg.east += 360.0;
+ src_reg.west += 360.0;
G_debug(1, "-------------------------------------");
G_debug(1, "source north %f", src_reg.north);
G_debug(1, "source south %f", src_reg.south);
@@ -249,19 +257,19 @@
/* adjust source window */
- if (1) {
double north = dest_reg.north + 2 * dims.edge_h;
double south = dest_reg.south - 2 * dims.edge_h;
int r0 = (int)(floor(Rast_northing_to_row(north, &src_reg)) - 0.5);
- int r1 = (int)(floor(Rast_northing_to_row(south, &src_reg)) + 0.5);
+ int r1 = (int)(ceil(Rast_northing_to_row(south, &src_reg)) + 0.5);
double east = dest_reg.east + 2 * dims.edge_v;
double west = dest_reg.west - 2 * dims.edge_v;
- /* NOTE: Rast_easting_to_col() is broken because of G_adjust_easting() */
+ /* do not use Rast_easting_to_col() because of G_adjust_easting() */
- int c0 = (int)floor(Rast_easting_to_col(east, &src_reg) + 0.5);
+ int c0 = (int)ceil(Rast_easting_to_col(east, &src_reg) + 0.5);
int c1 = (int)floor(Rast_easting_to_col(west, &src_reg) + 0.5);
- int c0 = (int)(floor(((east - src_reg.west) / src_reg.ew_res)) + 0.5);
+ int c0 = (int)(ceil(((east - src_reg.west) / src_reg.ew_res)) + 0.5);
int c1 = (int)(floor(((west - src_reg.west) / src_reg.ew_res)) - 0.5);
src_reg.north -= src_reg.ns_res * (r0);
@@ -320,8 +328,6 @@
if (1) {
int got_one = 0;
for (row = 0; row < nrows; row++) {
- DCELL dval;
G_percent(row, nrows, 9);
Rast_get_d_row_nomask(inrastfd, drastbuf, row);
@@ -331,8 +337,9 @@
if (!Rast_is_d_null_value(&dval)) {
got_one++;
+ if (Segment_put(&in_seg, &dval, row, col) < 0)
+ G_fatal_error(_("Can not write to temp file"));;
- Segment_put_row(&in_seg, drastbuf, row);
if (!got_one)
@@ -441,7 +448,8 @@
else
null_count++;
- Segment_put(&mask_seg, &mask_val, row, col);
+ if (Segment_put(&mask_seg, &mask_val, row, col) < 0)
@@ -472,11 +480,13 @@
/* initialize output */
G_message(_("Initializing output..."));
- drastbuf = Rast_allocate_buf(DCELL_TYPE);
- Rast_set_d_null_value(drastbuf, ncols);
+ Rast_set_d_null_value(&dval, 1);
- G_percent(row, nrows, 9);
- Segment_put_row(&out_seg, drastbuf, row);
+ G_percent(row, nrows, 2);
+ for (col = 0; col < ncols; col++) {
+ if (Segment_put(&out_seg, &dval, row, col) < 0)
@@ -742,14 +752,13 @@
int nonulls = 0;
- Segment_flush(&out_seg);
drastbuf = Rast_allocate_d_buf();
for (row = 0; row < dest_reg.rows; row++) {
G_percent(row, dest_reg.rows, 9);
- Segment_get_row(&out_seg, drastbuf, row);
for (col = 0; col < dest_reg.cols; col++) {
- dval = drastbuf[col];
+ Segment_get(&out_seg, &dval, row, col);
+ drastbuf[col] = dval;
nonulls++;
