[GRASS-SVN] r71231 - in grass/trunk/vector: v.lidar.correction v.lidar.edgedetection v.outlier v.surf.bspline
svn_grass at osgeo.org
Mon Jun 26 11:21:16 PDT 2017
Author: mmetz
Date: 2017-06-26 11:21:16 -0700 (Mon, 26 Jun 2017)
New Revision: 71231
grass/trunk/vector/v.lidar.correction/main.c
grass/trunk/vector/v.lidar.edgedetection/main.c
grass/trunk/vector/v.outlier/main.c
grass/trunk/vector/v.surf.bspline/main.c
lidar vector modules: fix ns_step/ew_step option descriptions, remove shadowed variables, fix G_free() usage
Modified: grass/trunk/vector/v.lidar.correction/main.c
--- grass/trunk/vector/v.lidar.correction/main.c 2017-06-26 18:18:49 UTC (rev 71230)
+++ grass/trunk/vector/v.lidar.correction/main.c 2017-06-26 18:21:16 UTC (rev 71231)
@@ -96,18 +96,18 @@
stepE_opt->key = "ew_step";
stepE_opt->type = TYPE_DOUBLE;
stepE_opt->required = NO;
- stepE_opt->answer = "25";
- stepE_opt->description =
- _("Length of each spline step (pixels) in the east-west direction");
+ stepE_opt->label =
+ _("Length of each spline step in the east-west direction");
+ stepE_opt->description = _("Default: 25 * east-west resolution");
stepE_opt->guisection = _("Settings");
stepN_opt = G_define_option();
stepN_opt->key = "ns_step";
stepN_opt->type = TYPE_DOUBLE;
stepN_opt->required = NO;
- stepN_opt->answer = "25";
- stepN_opt->description =
- _("Length of each spline step (pixels) in the north-south direction");
+ stepN_opt->label =
+ _("Length of each spline step in the north-south direction");
+ stepN_opt->description = _("Default: 25 * north-south resolution");
stepN_opt->guisection = _("Settings");
lambda_f_opt = G_define_option();
@@ -141,8 +141,13 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- stepN = atof(stepN_opt->answer);
- stepE = atof(stepE_opt->answer);
+ G_get_set_window(&original_reg);
+ stepN = 25 * original_reg.ns_res;
+ if (stepN_opt->answer)
+ stepN = atof(stepN_opt->answer);
+ stepE = 25 * original_reg.ew_res;
+ if (stepE_opt->answer)
+ stepE = atof(stepE_opt->answer);
lambda = atof(lambda_f_opt->answer);
HighThresh = atof(Thresh_A_opt->answer);
LowThresh = atof(Thresh_B_opt->answer);
@@ -246,7 +251,6 @@
driver = db_start_driver_open_database(dvr, db);
/* Setting regions and boxes */
- G_get_set_window(&original_reg);
G_get_set_window(&elaboration_reg);
Vect_region_box(&elaboration_reg, &overlap_box);
Vect_region_box(&elaboration_reg, &general_box);
@@ -369,7 +373,7 @@
nparameters = nsplx * nsply;
/* Mean calculation */
- G_important_message(_("Performing mean calculation..."));
+ G_verbose_message(_("Performing mean calculation..."));
mean = P_Mean_Calc(&elaboration_reg, observ, npoints);
/*Least Squares system */
@@ -413,7 +417,7 @@
G_free_vector(Q);
G_free_matrix(obsVect);
- G_important_message( _("Correction and creation of terrain vector..."));
+ G_verbose_message( _("Correction and creation of terrain vector..."));
P_Sparse_Correction(&In, &Out, &Terrain, &elaboration_reg,
general_box, overlap_box, obsVect_all, lcat,
parVect, lineVect, stepN, stepE,
Modified: grass/trunk/vector/v.lidar.edgedetection/main.c
--- grass/trunk/vector/v.lidar.edgedetection/main.c 2017-06-26 18:18:49 UTC (rev 71230)
+++ grass/trunk/vector/v.lidar.edgedetection/main.c 2017-06-26 18:21:16 UTC (rev 71231)
@@ -93,18 +93,18 @@
- stepE_opt->answer = "4";
+ stepE_opt->description = _("Default: 4 * east-west resolution");
- stepN_opt->answer = "4";
+ stepN_opt->description = _("Default: 4 * north-south resolution");
lambdaB_opt = G_define_option();
@@ -159,8 +159,14 @@
exit(EXIT_FAILURE);
line_out_counter = 1;
+ stepN = 4 * original_reg.ns_res;
+ stepE = 4 * original_reg.ew_res;
lambda_F = atof(lambdaF_opt->answer);
lambda_B = atof(lambdaB_opt->answer);
grad_H = atof(gradH_opt->answer);
@@ -271,7 +277,6 @@
@@ -415,7 +420,7 @@
G_free(observ);
- G_important_message(_("Performing bilinear interpolation..."));
+ G_verbose_message(_("Performing bilinear interpolation..."));
normalDefBilin(N, TN, Q, obsVect, stepE, stepN, nsplx,
nsply, elaboration_reg.west,
elaboration_reg.south, npoints, nparameters,
@@ -432,7 +437,7 @@
N = G_alloc_matrix(nparameters, BW); /* Normal matrix */
parVect_bicub = G_alloc_vector(nparameters); /* Bicubic parameters vector */
- G_important_message(_("Performing bicubic interpolation..."));
+ G_verbose_message(_("Performing bicubic interpolation..."));
normalDefBicubic(N, TN, Q, obsVect, stepE, stepN, nsplx,
@@ -444,7 +449,7 @@
G_free_vector(TN);
G_free_vector(Q);
- G_important_message(_("Point classification..."));
+ G_verbose_message(_("Point classification..."));
classification(&Out, elaboration_reg, general_box,
overlap_box, obsVect, parVect_bilin,
parVect_bicub, mean, alpha, grad_H, grad_L,
Modified: grass/trunk/vector/v.outlier/main.c
--- grass/trunk/vector/v.outlier/main.c 2017-06-26 18:18:49 UTC (rev 71230)
+++ grass/trunk/vector/v.outlier/main.c 2017-06-26 18:21:16 UTC (rev 71231)
@@ -98,18 +98,18 @@
- stepE_opt->answer = "10";
+ stepE_opt->description = _("Default: 10 * east-west resolution");
- stepN_opt->answer = "10";
+ stepN_opt->description = _("Default: 10 * north-south resolution");
@@ -148,8 +148,13 @@
if (!(dvr = G_getenv_nofatal2("DB_DRIVER", G_VAR_MAPSET)))
G_fatal_error(_("Unable to read name of driver"));
+ stepN = 10 * original_reg.ns_res;
+ stepE = 10 * original_reg.ew_res;
Thres_Outlier = atof(Thres_O_opt->answer);
@@ -268,7 +273,6 @@
@@ -351,8 +355,6 @@
subregion++;
if (nsubregions > 1)
G_message(_("Processing subregion %d of %d..."), subregion, nsubregions);
- else /* v.outlier -e will report mean point distance: */
- G_warning(_("No subregions found! Check values for 'ew_step' and 'ns_step' parameters"));
P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims,
GENERAL_COLUMN);
Modified: grass/trunk/vector/v.surf.bspline/main.c
--- grass/trunk/vector/v.surf.bspline/main.c 2017-06-26 18:18:49 UTC (rev 71230)
+++ grass/trunk/vector/v.surf.bspline/main.c 2017-06-26 18:21:16 UTC (rev 71231)
@@ -144,18 +144,18 @@
type_opt = G_define_option();
@@ -214,8 +214,13 @@
else
bilin = P_BICUBIC;
flag_auxiliar = FALSE;
@@ -435,7 +440,6 @@
G_debug(1, "Interpolation: Setting regions and boxes");
- G_get_window(&original_reg);
G_get_window(&elaboration_reg);
Vect_region_box(&original_reg, &original_box);
@@ -487,8 +491,8 @@
G_percent(row, nrows, 2);
if (mask_opt->answer) {
- int row, col, maskfd;
- DCELL dval, *drastbuf;
+ int col, maskfd;
+ DCELL dval;
char mask_val;
G_message(_("Load masking map"));
@@ -504,7 +508,6 @@
G_fatal_error(_("Can not initialize temporary file"));
maskfd = Rast_open_old(mask_opt->answer, "");
- drastbuf = Rast_allocate_buf(DCELL_TYPE);
for (row = 0; row < nrows; row++) {
@@ -521,11 +524,11 @@
- G_free(drastbuf);
Rast_close(maskfd);
have_mask = 1;
+ G_free(drastbuf);
