[GRASS-SVN] r70720 - grass-addons/grass7/imagery/i.image.bathymetry
svn_grass at osgeo.org
Thu Mar 2 05:10:58 PST 2017
Author: vinayocu
Date: 2017-03-02 05:10:58 -0800 (Thu, 02 Mar 2017)
New Revision: 70720
grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.html
grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.py
added new parameter for area to be estimated
Modified: grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.html
--- grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.html 2017-03-01 21:21:12 UTC (rev 70719)
+++ grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.html 2017-03-02 13:10:58 UTC (rev 70720)
@@ -27,11 +27,14 @@
survey can be used as reference depth for calibration. The calibration
depth points provided by the user are used to ditermine the Area of
Interest, therefore it is suggested to provide calibration depth points
-in order to cover user's estimation region boundary.
+in order to cover user's estimation region boundary. In addition, an
+optional parameter is also available to provide a polygon vector
+file for user's to ditermine the area to be estimated (see first
+example).
<br><br>
- The tide height at the time of reference depth collection and
-satellite imagery capture should be normalized if it is not. An option
-is available in the module to provide tide hieght at the tide of image
+The tide height at the time of reference depth collection and satellite
+imagery capture should be normalized if it is not. An option is
+available in the module to provide tide hieght at the tide of image
captured and the module will correct the reference depth accordingly.
This option asuumes that the reference depth given is corrected zero
tide height. The tide lower than zero can be added as negative value.
@@ -58,7 +61,7 @@
i.image.bathymetry blue_band='B2' green_band='B3' red_band='B4'
nir_band='B8' band_for_correction='B11'
calibration_points='Calibration_points' calibration_column='Z'
-depth_estimate='output'
+depth_estimate='output' area_of_interest='AOI'
</pre></div>
<br>
If SWIR band is not available near-infrared band can be used as
Modified: grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.py
--- grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.py 2017-03-01 21:21:12 UTC (rev 70719)
+++ grass-addons/grass7/imagery/i.image.bathymetry/i.image.bathymetry.py 2017-03-02 13:10:58 UTC (rev 70720)
@@ -44,6 +44,10 @@
#% key: calibration_points
#%required: yes
#%end
+#%option G_OPT_V_INPUT
+#% key: area_of_interest
+#%required: no
+#%end
#%option G_OPT_R_INPUT
#% key: additional_band1
#%required: no
@@ -71,26 +75,23 @@
#%required: no
#%description: Tide correction to the time of satellite image capture
#%end
-#%option
+#%option G_OPT_DB_COLUMN
#% key: calibration_column
-#%type: string
-#%multiple: no
#%required: yes
#%description: Name of the column which stores depth values
#%end
#%flag
#%key: f
-#% description: select if only want to run Fixed-GWR model
+#%description: select if only want to run Fixed-GWR model
#%end
#%flag
#%key: b
-#% description: select kernel function as bi-square
+#%description: select kernel function as bi-square
#%end
import atexit
import grass.script as g
from grass.pygrass.raster import RasterRow
-from grass.pygrass.modules import Module
import subprocess
import os
crctd_lst = []
@@ -104,6 +105,7 @@
NIR = options['nir_band']
SWIR = options['band_for_correction']
Calibration_points = options['calibration_points']
+ Area_of_interest = options['area_of_interest']
Additional_band1 = options['additional_band1']
Additional_band2 = options['additional_band2']
Additional_band3 = options['additional_band3']
@@ -113,7 +115,7 @@
calibration_column = options['calibration_column']
bisquare = flags['b']
fixed_GWR = flags['f']
res = g.parse_command('g.region', raster=Green, flags='g')
g.run_command('v.to.rast', input=Calibration_points, type='point',
use='attr', attribute_column=calibration_column,
@@ -171,34 +173,40 @@
tmp_coe = g.parse_command('r.regression.line', mapx=SWIR,
mapy=str(i), flags='g')
g.message("Deep water ditermination for %s" % i)
- g.run_command('r.mask', vector='tmp_buffer', overwrite=True)
- g.run_command('g.region', vector=Calibration_points)
- g.mapcalc(exp="{tmp_crctd}=log({tmp_band}-{a}-{b}*{SWIR})"
- .format(tmp_crctd='tmp_crctd' + str(j),
+ if Area_of_interest:
+ g.run_command('r.mask', vector=Area_of_interest, overwrite=True)
+ g.run_command('g.region', vector=Area_of_interest)
+ else:
+ g.run_command('r.mask', vector='tmp_buffer', overwrite=True)
+ g.run_command('g.region', vector=Calibration_points)
+ g.mapcalc(exp="{tmp_crct}=log({tmp_band}-{a}-{b}*{SWIR})"
+ .format(tmp_crct='tmp_crct' + str(j),
tmp_band=str(i), a=float(tmp_coe['a']),
b=float(tmp_coe['b']), SWIR=SWIR),
- overwrite=True)
+ overwrite=True)
g.run_command('r.mask', raster='tmp_water', overwrite=True)
- g.mapcalc("{tmp_crctd} = ({tmp_crctd} * 1)"
- .format(tmp_crctd='tmp_crctd' + str(j)))
+ g.mapcalc("{tmp_crctd} = ({tmp_crct} * 1)"
+ .format(tmp_crct='tmp_crct'+str(j), tmp_crctd='tmp_crctd' + str(j)))
except:
g.message("Cannot find deep water pixels")
- g.mapcalc("{tmp_crctd} = log({tmp_band}-{SWIR})"
- .format(tmp_crctd='tmp_crctd' + str(j), tmp_band=str(i),
- SWIR=SWIR),
- overwrite=True)
+ else:
+ tmp_band=str(i), a=float(tmp_coe['a']),
+ b=float(tmp_coe['b']), SWIR=SWIR),
+ overwrite=True)
crctd_lst.append('tmp_crctd' + str(j))
- try:
- Module('r.gwr')
- except:
- g.run_command('g.extension', extension='r.gwr')
if fixed_GWR:
+ if not g.find_program('r.gwr', '--help'):
+ g.run_command('g.extension', extension='r.gwr')
if bisquare:
g.message("Calculating optimal bandwidth using bisqare kernel...")
bw = g.parse_command('r.gwr', mapx=crctd_lst,
@@ -219,9 +227,12 @@
estimates='tmp_bathymetry',
bandwidth=int(bw['estimate']))
else:
+ global r
+ global predict
try:
# For GWmodel in R
- r_file = open('crctd.R', 'w')
+ r = g.tempfile()
+ r_file = open(r, 'w')
libs = ['GWmodel', 'data.table', 'rgrass7', 'rgdal', 'raster']
for i in libs:
install = 'if(!is.element("%s", installed.packages()[,1])){\n' % i
@@ -248,7 +259,7 @@
r_file.write('grass_file = readRAST("tmp_crctd%s")\n' % j)
r_file.write('raster_file = raster(grass_file)\n')
r_file.write('frame_pred%s = as.data.frame(raster_file, na.rm = TRUE,'
- 'xy = TRUE)\n' % j)
+ 'xy = TRUE)\n' % j)
pred_file = 'frame_pred_green=data.frame(frame_pred%s)\n' % Green_new
pred_file += 'pred=merge(pred, frame_pred%s)\n' % j
r_file.write(pred_file)
@@ -279,6 +290,7 @@
'(Rapid_ref.sdf))\n'
r_file.write(ref_file)
l = []
+ predict = g.read_command("g.tempfile", pid=os.getpid()).strip() + '.txt'
# Join the corrected bands in to a string
le = len(crctd_lst)
for i in crctd_lst:
@@ -320,16 +332,19 @@
r_file.write(ref_fla)
ref_fil = 'Sp_frame = as.data.frame(GWR_Rapid_pred.sdf$SDF)\n'
r_file.write(ref_fil)
- r_file.write('write.table(Sp_frame, quote=FALSE, sep=",",' \
- '"prediction.txt")\n')
+ export = 'write.table(Sp_frame, quote=FALSE, sep=",",' \
+ '"%s")\n' % predict
+ r_file.write(export)
r_file.close()
- subprocess.check_call(['Rscript', 'crctd.R'], shell=False)
- g.run_command('r.in.xyz', input='prediction.txt',
+ subprocess.check_call(['Rscript', r], shell=False)
+ g.run_command('r.in.xyz', input=predict,
output='tmp_bathymetry', skip=1, separator=",",
x=(int(le) + 5), y=(int(le) + 6), z=(int(le) + 3),
overwrite=True)
except subprocess.CalledProcessError:
g.message("Integer outflow... ")
if bisquare:
g.message("Running Fixed-GWR using bisqare kernel...")
@@ -341,10 +356,6 @@
else:
g.message("Running Fixed-GWR using gaussian kernel...")
- try:
- Module('r.gwr')
- except:
mapy='tmp_Calibration_points', flags='ge')
g.run_command('r.gwr', mapx=crctd_lst,
@@ -361,12 +372,12 @@
def cleanup():
- g.run_command('g.remove', type='raster', pattern='MASK', flags='f')
+ g.run_command('g.remove', type='raster', name='MASK', flags='f')
g.run_command('g.remove', type='all', pattern='*tmp*', flags='f')
try:
- os.remove('crctd.R')
- os.remove('prediction.txt')
- except OSError:
+ g.try_remove(predict)
+ g.try_remove(r)
+ except:
pass
if __name__ == '__main__':
