[GRASS-SVN] r70724 - grass-addons/grass7/imagery/i.superpixels.slic
svn_grass at osgeo.org
Fri Mar 3 12:23:56 PST 2017
Author: mmetz
Date: 2017-03-03 12:23:56 -0800 (Fri, 03 Mar 2017)
New Revision: 70724
grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
i.superpixels.slic: update manual
Modified: grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
--- grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html 2017-03-03 16:31:14 UTC (rev 70723)
+++ grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html 2017-03-03 20:23:56 UTC (rev 70724)
@@ -12,6 +12,14 @@
the most important parameter of the module. A reasonable value should
be determined for small test regions before applying the module to a
large region.
+<p>
+The resultant number of superpixels will most often be larger than the
+initial number of superpixels because the initial number of superpixels
+is used to create seeds and SLIC assigns pixels to seeds. Pixels
+assigned to the same seed are usually not connected. The final
+number of superpixels is the number of clumps, also known as
+connected components, objects, regions, or blobs. The final number of
+superpixels can be reduced with the <b>minsize</b> option.
<h2>NOTES</h2>
@@ -22,7 +30,8 @@
These bands can be either spectral bands of imagery, or any other
pseudo-bands relevant to the analysis at hand (NDVI, texture,
precipitation, etc). All band values are normalized to a common 0-1 scale
-to ensure comparability in the spectral distance calculations.
+to ensure comparability in the spectral distance calculations.
+Therefore results will not be identical with the original implementation.
<h4>Iterations</h4>
In each iteration, the assignment of pixels to superpixels and the
@@ -33,10 +42,17 @@
if convergence is reached, but it can take 1000 or more iterations
until convergence is reached.
-<h4>Minimum clump size</h4>
+<h4>Minimum segment size</h4>
If a minimum segment size of 2 or larger is given with the <b>minsize</b>
parameter, segments with a smaller pixel count will be merged with
their most similar neighbor.
+<p>
+In the original implementation of Achanta et al., a minimum segment
+size is internally determined, and segments smaller than this minimum
+segment size are merged with an arbitrarily chosen neigbour. Therefore
+results will not be identical with the original implementation, even if
+a minimum segment size identical to the minimum segment size internally
+determined in the original implementation of Achanta et al. is used.
<h4>Creating seeds for <em>i.segment</em></h4>
If the purpose is to create seeds for <em>i.segment</em>, a small number
