[GRASS-SVN] r70727 - in grass/trunk/lib/python/temporal: . testsuite
svn_grass at osgeo.org
Sat Mar 4 23:35:59 PST 2017
Author: huhabla
Date: 2017-03-04 23:35:58 -0800 (Sat, 04 Mar 2017)
New Revision: 70727
grass/trunk/lib/python/temporal/register.py
grass/trunk/lib/python/temporal/testsuite/test_register_function.py
temporal framework: Fixed empty map removal in register object function
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2017-03-05 04:26:39 UTC (rev 70726)
+++ grass/trunk/lib/python/temporal/register.py 2017-03-05 07:35:58 UTC (rev 70727)
@@ -32,7 +32,7 @@
def register_maps_in_space_time_dataset(
type, name, maps=None, file=None, start=None,
end=None, unit=None, increment=None, dbif=None,
- interval=False, fs="|", update_cmd_list=True):
+ interval=False, fs="|", update_cmd_list=True):
"""Use this method to register maps in space time datasets.
Additionally a start time string and an increment string can be
@@ -483,10 +483,15 @@
# In case of a empty map continue, do not register empty maps
if delete_empty:
- if map_layer.metadata.get_min() is None and \
- map_layer.metadata.get_max() is None:
- empty_maps.append(map_layer)
- continue
+ if type in ["raster", "raster_3d"]:
+ if map_layer.metadata.get_min() is None and \
+ map_layer.metadata.get_max() is None:
+ empty_maps.append(map_layer)
+ continue
+ if type == "vector":
+ if map_layer.metadata.get_number_of_primitives() == 0:
+ continue
start, end = map_layer.get_temporal_extent_as_tuple()
id = map_layer.get_id()
@@ -507,11 +512,9 @@
g_remove = pymod.Module("g.remove", flags='f', quiet=True,
run_=False, finish_=True)
- # Remove empty maps
+ # Remove empty maps and unregister them from the temporal database
if len(empty_maps) > 0:
for map in empty_maps:
- if map.is_in_db(dbif):
- map.delete(dbif)
mod = copy.deepcopy(g_remove)
if map.get_name():
if map.get_type() == "raster":
@@ -521,6 +524,8 @@
if map.get_type() == "vector":
mod(type='vector', name=map.get_name())
mod.run()
+ if map.is_in_db(dbif):
+ map.delete(dbif)
if connected:
dbif.close()
Modified: grass/trunk/lib/python/temporal/testsuite/test_register_function.py
--- grass/trunk/lib/python/temporal/testsuite/test_register_function.py 2017-03-05 04:26:39 UTC (rev 70726)
+++ grass/trunk/lib/python/temporal/testsuite/test_register_function.py 2017-03-05 07:35:58 UTC (rev 70727)
@@ -15,7 +15,7 @@
import datetime
import os
-class TestRegisterFunctions(TestCase):
+class TestRasterRegisterFunctions(TestCase):
@classmethod
def setUpClass(cls):
@@ -42,6 +42,8 @@
expression="register_map_1 = 1")
self.runModule("r.mapcalc", overwrite=True, quiet=True,
expression="register_map_2 = 2")
+ self.runModule("r.mapcalc", overwrite=True, quiet=True,
+ expression="register_map_null = null()")
self.strds_abs = tgis.open_new_stds(name="register_test_abs", type="strds", temporaltype="absolute",
title="Test strds", descr="Test strds", semantic="field",
@@ -53,8 +55,10 @@
def tearDown(self):
"""Remove maps from temporal database
- self.runModule("t.unregister", maps="register_map_1,register_map_2", quiet=True)
- self.runModule("g.remove", flags='f', type="raster", name="register_map_1,register_map_2", quiet=True)
+ self.runModule("t.unregister", type="raster", maps="register_map_1,register_map_2",
+ quiet=True)
+ self.runModule("g.remove", flags='f', type="raster", name="register_map_1,register_map_2",
+ quiet=True)
self.strds_abs.delete()
self.strds_rel.delete()
@@ -148,6 +152,7 @@
ciface = tgis.get_tgis_c_library_interface()
+ # Set the timestamp as relative time
ciface.write_raster_timestamp("register_map_1", tgis.get_current_mapset(), "1 day")
tgis.register_maps_in_space_time_dataset(type="raster", name=self.strds_abs.get_name(),
@@ -168,40 +173,70 @@
def test_absolute_time_1(self):
"""Test the registration of maps with absolute time
+ using register_maps_in_space_time_dataset() and register_map_object_list()
tgis.register_maps_in_space_time_dataset(type="raster", name=None,
start="2001-01-01", increment="1 day", interval=True)
- map = tgis.RasterDataset("register_map_1@" + tgis.get_current_mapset())
- map.select()
- start, end = map.get_absolute_time()
+ map_1 = tgis.RasterDataset("register_map_1@" + tgis.get_current_mapset())
+ map_1.select()
+ start, end = map_1.get_absolute_time()
self.assertEqual(start, datetime.datetime(2001, 1, 1))
self.assertEqual(end, datetime.datetime(2001, 1, 2))
- map = tgis.RasterDataset("register_map_2@" + tgis.get_current_mapset())
- map.select()
+ map_2 = tgis.RasterDataset("register_map_2@" + tgis.get_current_mapset())
+ map_2.select()
+ start, end = map_2.get_absolute_time()
self.assertEqual(start, datetime.datetime(2001, 1, 2))
self.assertEqual(end, datetime.datetime(2001, 1, 3))
+ map_list = [map_1, map_2]
+ tgis.register_map_object_list(type="raster", map_list=map_list,
+ output_stds=self.strds_abs,
+ delete_empty=False)
+ self.strds_abs.select()
+ start, end = self.strds_abs.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual(end, datetime.datetime(2001, 1, 3))
def test_absolute_time_2(self):
+ using register_maps_in_space_time_dataset() and register_map_object_list() with empty map deletion
- maps="register_map_1,register_map_2",
+ maps="register_map_1,register_map_2,register_map_null",
start="2001-01-01 10:30:01", increment="8 hours", interval=False)
- map.select()
+ map_1.select()
self.assertEqual(start, datetime.datetime(2001, 1, 1, 10, 30, 1))
- map.select()
+ map_2.select()
self.assertEqual(start, datetime.datetime(2001, 1, 1, 18, 30, 1))
+ map_3 = tgis.RasterDataset("register_map_null@" + tgis.get_current_mapset())
+ map_3.select()
+ start, end = map_3.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 2, 02, 30, 1))
+ map_list = [map_1, map_2, map_3]
+ delete_empty=True)
+ self.assertEqual(start, datetime.datetime(2001, 1, 1, 10, 30, 1))
+ self.assertEqual(end, datetime.datetime(2001, 1, 1, 18, 30, 1))
+ map_3 = tgis.VectorDataset("register_map_null@" + tgis.get_current_mapset())
+ self.assertEqual(map_3.map_exists(), False)
def test_absolute_time_3(self):
"""Test the registration of maps with absolute time.
The timestamps are set using the C-Interface beforehand, so that the register function needs
@@ -329,7 +364,7 @@
self.assertEqual(unit, "seconds")
def test_relative_time_3(self):
- """Test the registration of maps with relative time. The timetsamps are set beforhand using
+ """Test the registration of maps with relative time. The timetsamps are set beforehand using
the C-interface.
@@ -354,6 +389,209 @@
+class TestVectorRegisterFunctions(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ os.putenv("GRASS_OVERWRITE", "1")
+ # Use always the current mapset as temporal database
+ cls.runModule("g.gisenv", set="TGIS_USE_CURRENT_MAPSET=1")
+ tgis.init()
+ cls.use_temp_region()
+ cls.runModule('g.region', n=80.0, s=0.0, e=120.0, w=0.0,
+ t=1.0, b=0.0, res=10.0)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.del_temp_region()
+ def setUp(self):
+ """Create the test maps and the space time raster datasets
+ self.runModule("v.random", overwrite=True, quiet=True,
+ output="register_map_1", npoints=5, seed=1)
+ output="register_map_2", npoints=5, seed=1)
+ self.runModule("r.to.vect", overwrite=True, quiet=True,
+ input="register_map_null", type="point",
+ output="register_map_empty")
+ self.stvds_abs = tgis.open_new_stds(name="register_test_abs", type="stvds", temporaltype="absolute",
+ title="Test stvds", descr="Test stvds", semantic="field",
+ overwrite=True)
+ self.stvds_rel = tgis.open_new_stds(name="register_test_rel", type="stvds", temporaltype="relative",
+ overwrite=True)
+ def tearDown(self):
+ """Remove maps from temporal database
+ self.runModule("t.unregister", type="vector", maps="register_map_1,register_map_2", quiet=True)
+ self.runModule("g.remove", flags='f', type="vector", name="register_map_1,register_map_2", quiet=True)
+ self.stvds_abs.delete()
+ self.stvds_rel.delete()
+ def test_absolute_time_stvds_1(self):
+ """Test the registration of maps with absolute time in a
+ space time raster dataset
+ tgis.register_maps_in_space_time_dataset(type="vector", name=self.stvds_abs.get_name(),
+ maps="register_map_1,register_map_2",
+ start="2001-01-01", increment="1 day", interval=True)
+ map = tgis.VectorDataset("register_map_1@" + tgis.get_current_mapset())
+ map.select()
+ start, end = map.get_absolute_time()
+ self.assertEqual(end, datetime.datetime(2001, 1, 2))
+ map = tgis.VectorDataset("register_map_2@" + tgis.get_current_mapset())
+ map.select()
+ self.assertEqual(start, datetime.datetime(2001, 1, 2))
+ self.stvds_abs.select()
+ start, end = self.stvds_abs.get_absolute_time()
+ def test_absolute_time_stvds_2(self):
+ space time raster dataset.
+ The timestamps are set using the C-Interface beforehand, so that the register function needs
+ to read the timetsamp from the map metadata.
+ ciface = tgis.get_tgis_c_library_interface()
+ ciface.write_vector_timestamp("register_map_1", tgis.get_current_mapset(), "1 Jan 2001/2 Jan 2001")
+ ciface.write_vector_timestamp("register_map_2", tgis.get_current_mapset(), "2 Jan 2001/3 Jan 2001")
+ maps="register_map_1,register_map_2")
+ map.select()
+ map.select()
+ def test_absolute_time_stvds_3(self):
+ space time raster dataset. The timestamps are set via method arguments and with the
+ c-interface. The timestamps of the method arguments should overwrite the
+ time stamps set via the C-interface.
+ maps="register_map_1",
+ start="2001-02-01", increment="1 day",
+ interval=True)
+ map.select()
+ self.assertEqual(start, datetime.datetime(2001, 2, 1))
+ self.assertEqual(end, datetime.datetime(2001, 2, 2))
+ def test_absolute_time_1(self):
+ """Register vector maps in the temporal database and in addition in a stvds using the object method
+ :return:
+ tgis.register_maps_in_space_time_dataset(type="vector", name=None,
+ map_1 = tgis.VectorDataset("register_map_1@" + tgis.get_current_mapset())
+ map_1.select()
+ map_2 = tgis.VectorDataset("register_map_2@" + tgis.get_current_mapset())
+ map_2.select()
+ tgis.register_map_object_list(type="vector", map_list=map_list,
+ output_stds=self.stvds_abs,
+ def test_absolute_time_2(self):
+ in a stvds using the object method deleting empty maps
+ :return:
+ maps="register_map_1,register_map_2,register_map_empty",
+ map_1.select()
+ map_2.select()
+ map_3 = tgis.VectorDataset("register_map_empty@" + tgis.get_current_mapset())
+ map_3.select()
+ self.assertEqual(start, datetime.datetime(2001, 1, 3))
+ self.assertEqual(end, datetime.datetime(2001, 1, 4))
class TestRegisterFails(TestCase):
def test_error_handling_1(self):
