[GRASS-SVN] r70733 - grass/trunk/tools
svn_grass at osgeo.org
Sun Mar 5 20:31:32 PST 2017
Author: wenzeslaus
Date: 2017-03-05 20:31:32 -0800 (Sun, 05 Mar 2017)
New Revision: 70733
grass/trunk/tools/thumbnails.py
clean up color table thumbnail code, PEP8, some Pylint (follows r70725 and r70732)
Modified: grass/trunk/tools/thumbnails.py
--- grass/trunk/tools/thumbnails.py 2017-03-06 04:27:28 UTC (rev 70732)
+++ grass/trunk/tools/thumbnails.py 2017-03-06 04:31:32 UTC (rev 70733)
@@ -1,12 +1,13 @@
#!/usr/bin/env python
-# thumbnails.py: Create thumbnail sample images of the various GRASS color rules
+# thumbnails.py: Create thumbnail images of the GRASS color tables
-# AUTHOR: Python version by Glynn Clements
+# AUTHOR: Vaclav Petras (non-PPM version using r.mapcalc)
+# Glynn Clements (Python version)
# Earlier Bourne script version by Hamish Bowman,
# http://grasswiki.osgeo.org/wiki/Talk:Color_tables
-# (C) 2009-2013 by the GRASS Development Team
+# (C) 2009-2017 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
@@ -14,99 +15,23 @@
import sys
import os
-import shutil
import atexit
-import string
-import array
import grass.script as grass
-tmp_img = None
tmp_grad_abs = None
tmp_grad_rel = None
-height = 15
-width = 85
def cleanup():
- if tmp_img:
- grass.try_remove(tmp_img)
if tmp_grad_rel:
- grass.run_command('g.remove', flags = 'f', type = 'raster',
- name = tmp_grad_rel, quiet = True)
+ grass.run_command('g.remove', flags='f', type='raster',
+ name=tmp_grad_rel, quiet=True)
if tmp_grad_abs:
- name = tmp_grad_abs, quiet = True)
+ name=tmp_grad_abs, quiet=True)
-# def rotate(src, dst):
-# grass.call(["convert", "-rotate", "90", src, dst])
-def read_ppm(src):
- fh = open(src, "rb")
- text = fh.read()
- fh.close()
- i = 0
- j = text.find('\n', i)
- if text[i:j] != 'P6':
- raise IOError
- i = j + 1
- w, h = text[i:j].split()
- if int(w) != width or int(h) != height:
- raise IOError
- i = j + 1
- maxval = text[i:j]
- if int(maxval) != 255:
- raise IOError
- i = j + 1
- return array.array('B', text[i:])
-def write_ppm(dst, data):
- w = height
- h = width
- fh = open(dst, "wb")
- fh.write("P6\n%d %d\n%d\n" % (w, h, 255))
- data.tofile(fh)
- fh.close()
-def rotate_ppm(srcd):
- dstd = array.array('B', len(srcd) * '\0')
- for y in xrange(height):
- for x in xrange(width):
- for c in xrange(3):
- dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
- return dstd
-def flip_ppm(srcd):
- stride = width * 3
- dy = (height - 1 - y)
- dstd[dy * stride:(dy + 1) * stride] = srcd[y * stride:(y + 1) * stride]
- return dstd
-def ppmtopng(dst, src):
- if grass.find_program("g.ppmtopng", '--help'):
- grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
- elif grass.find_program("pnmtopng"):
- fh = open(dst, 'wb')
- grass.call(["pnmtopng", src], stdout = fh)
- fh.close()
- elif grass.find_program("convert"):
- grass.call(["convert", src, dst])
- else:
- grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
-# TODO: this code is not used and can be moved to some lib function or
-# separate module if useful
-def convert_and_rotate(src, dst, flip = False):
- ppm = read_ppm(src)
- if flip:
- ppm = flip_ppm(ppm)
- ppm = rotate_ppm(ppm)
- write_ppm(tmp_img, ppm)
- ppmtopng(dst, tmp_img)
def make_gradient(path):
fh = open(path)
text = fh.read()
@@ -122,7 +47,8 @@
# skip empty lines
continue
records.append(line.split())
- records = [record for record in records if record[0] != 'nv' and record[0] != 'default']
+ records = [record for record in records
+ if record[0] != 'nv' and record[0] != 'default']
relative = False
absolute = False
for record in records:
@@ -152,19 +78,25 @@
# alternatively, only simpler expression would suffice if frames
# are used to render raster and then the borders
grass.mapcalc("$grad = if(col() > 2 && col() < ncols() - 1,"
- " float($min) + (col() - 3) * (float($max) - float($min)) / (ncols() - 2),"
+ " float($min) + (col() - 3) * "
+ " (float($max) - float($min)) / (ncols() - 2),"
" null())",
- grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
+ grad=tmp_grad_abs, min=minval, max=maxval, quiet=True)
else:
grad = tmp_grad_rel
return grad
-def make_image(output_dir, table, grad):
- grass.run_command("r.colors", map = grad, color = table, quiet = True)
+def make_image(output_dir, table, grad, height, width):
+ outfile = os.path.join(output_dir, "colortables", "%s.png" % table)
+ os.environ['GRASS_RENDER_FILE'] = outfile
+ grass.run_command("r.colors", map=grad, color=table, quiet=True)
grass.run_command("d.rast", map=grad, quiet=True)
if 1:
- grass.write_command("d.graph", quiet=True, flags='m', stdin="""width 1
+ grass.write_command("d.graph", quiet=True, flags='m', stdin="""
+ width 1
color {outcolor}
polyline
{x1} {y1}
@@ -182,12 +114,14 @@
""".format(x1=1, x2=width, y1=0, y2=height - 1,
x3=2, x4=width - 1, y3=1, y4=height - 2,
outcolor='white', incolor='black'))
- outfile = os.path.join(output_dir, "colortables", "%s.png" % table)
- shutil.move(tmp_img, outfile)
def main():
global tmp_img, tmp_grad_abs, tmp_grad_rel
+ height = 15
+ width = 85
os.environ['GRASS_OVERWRITE'] = '1'
color_dir = os.path.join(os.environ['GISBASE'], "etc", "colors")
@@ -199,12 +133,10 @@
pid = os.getpid()
tmp_grad_abs = "tmp_grad_abs_%d" % pid
tmp_grad_rel = "tmp_grad_rel_%d" % pid
- tmp_img = grass.tempfile() + ".png"
os.environ['GRASS_RENDER_WIDTH'] = '%d' % width
os.environ['GRASS_RENDER_HEIGHT'] = '%d' % height
- os.environ['GRASS_RENDER_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
- os.environ['GRASS_RENDER_FILE'] = tmp_img
+ os.environ['GRASS_RENDER_FRAME'] = '%f,%f,%f,%f' % (0, height, 0, width)
os.environ['GRASS_RENDER_TRUECOLOR'] = 'TRUE'
# for multiple d commands (requires to delete/move image each time)
os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
@@ -225,18 +157,20 @@
" float(col()), null())", grad=tmp_grad_rel, quiet=True)
for table in os.listdir(color_dir):
path = os.path.join(color_dir, table)
grad = make_gradient(path)
- make_image(output_dir, table, grad)
+ make_image(output_dir, table, grad,
+ height=height, width=width)
" col(), null())", grad=tmp_grad_abs, quiet=True)
for table in ['grey.eq', 'grey.log', 'random']:
- make_image(output_dir, table, tmp_grad_abs)
+ make_image(output_dir, table, tmp_grad_abs,
if __name__ == "__main__":
atexit.register(cleanup)
main()
