[GRASS-SVN] r70740 - grass/trunk/vector/v.support
svn_grass at osgeo.org
Fri Mar 10 22:11:28 PST 2017
Author: hcho
Date: 2017-03-10 22:11:28 -0800 (Fri, 10 Mar 2017)
New Revision: 70740
grass/trunk/vector/v.support/main.c
v.support: Add -h to replace command line
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c 2017-03-11 05:06:28 UTC (rev 70739)
+++ grass/trunk/vector/v.support/main.c 2017-03-11 06:11:28 UTC (rev 70740)
@@ -7,7 +7,7 @@
* PURPOSE: updates metadata of vector map
- * COPYRIGHT: (C) 2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 2007, 2017 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -29,7 +29,7 @@
struct GModule *module;
struct Option *map, *organization, *date, *person, *map_name, *map_date,
*scale, *comment, *zone, *thresh, *cmdhist;
- struct Flag *r_flag;
+ struct Flag *r_flag, *h_flag;
/* initialize GIS environment */
G_gisinit(argv[0]);
@@ -121,6 +121,10 @@
r_flag->key = 'r';
r_flag->description = _("Replace comment instead of appending it");
+ h_flag = G_define_flag();
+ h_flag->key = 'h';
+ h_flag->description = _("Replace command line instead of appending it");
/* options and flags parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -178,16 +182,21 @@
/* Open history file for modification */
sprintf(buf, "%s/%s", GV_DIRECTORY, Map.name);
- Map.hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
+ if (h_flag->answer)
+ Map.hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
+ else
+ Map.hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
if (Map.hist_fp == NULL) {
G_warning(_("Unable to open history file for vector map <%s>"),
Vect_get_full_name(&Map));
Vect_close(&Map);
exit(EXIT_FAILURE);
- G_fseek(Map.hist_fp, (long)0, SEEK_END);
- Vect_hist_write(&Map,
- "---------------------------------------------------------------------------------\n");
+ if (!h_flag->answer) {
+ G_fseek(Map.hist_fp, (long)0, SEEK_END);
+ Vect_hist_write(&Map,
+ "---------------------------------------------------------------------------------\n");
Vect_hist_write(&Map, "COMMAND: ");
Vect_hist_write(&Map, cmdhist->answer);
Vect_hist_write(&Map, "\n");
