[GRASS-SVN] r70751 - in grass/branches/releasebranch_7_2/scripts: r.import v.import
svn_grass at osgeo.org
Sun Mar 12 07:35:11 PDT 2017
Author: neteler
Date: 2017-03-12 07:35:11 -0700 (Sun, 12 Mar 2017)
New Revision: 70751
grass/branches/releasebranch_7_2/scripts/r.import/r.import.html
grass/branches/releasebranch_7_2/scripts/v.import/v.import.html
r.import/v.import manual: explain -o projection override flag
Modified: grass/branches/releasebranch_7_2/scripts/r.import/r.import.html
--- grass/branches/releasebranch_7_2/scripts/r.import/r.import.html 2017-03-12 14:33:33 UTC (rev 70750)
+++ grass/branches/releasebranch_7_2/scripts/r.import/r.import.html 2017-03-12 14:35:11 UTC (rev 70751)
@@ -9,6 +9,17 @@
<h2>NOTES</h2>
+<em>r.import</em> checks the projection metadata of the dataset to be
+imported against the current location's projection. If not identical a
+related error message is shown.
+<br>
+To override this projection check (i.e. to use current location's projection)
+by assuming that the dataset has the same projection as the current location
+the <b>-o</b> flag can be used. This is also useful when geodata to be
+imported do not contain any projection metadata at all. The user must be
+sure that the projection is identical in order to avoid to introduce data
+errors.
<h3>Resolution</h3>
<em>r.import</em> reports the estimated target resolution for each
Modified: grass/branches/releasebranch_7_2/scripts/v.import/v.import.html
--- grass/branches/releasebranch_7_2/scripts/v.import/v.import.html 2017-03-12 14:33:33 UTC (rev 70750)
+++ grass/branches/releasebranch_7_2/scripts/v.import/v.import.html 2017-03-12 14:35:11 UTC (rev 70751)
@@ -24,6 +24,17 @@
<h2>NOTES</h2>
+<em>v.import</em> checks the projection metadata of the dataset to be
+<br>
+errors.
<h3>Topology cleaning</h3>
When importing polygons, non-topological polygons are converted to
