[GRASS-SVN] r70757 - grass-addons/grass7/raster/r.exdet
Wed Mar 15 06:22:32 PDT 2017
Author: pvanbosgeo
Date: 2017-03-15 06:22:32 -0700 (Wed, 15 Mar 2017)
New Revision: 70757
   grass-addons/grass7/raster/r.exdet/r.exdet.html
   grass-addons/grass7/raster/r.exdet/r.exdet.py
r.exdet addon: small changes in how temporary text files are handled
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.html
--- grass-addons/grass7/raster/r.exdet/r.exdet.html	2017-03-15 13:08:20 UTC (rev 70756)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.html	2017-03-15 13:22:32 UTC (rev 70757)
@@ -1,14 +1,14 @@
 <h2>DESCRIPTION</h2>
-Correlative species distribution models (SDMs) often involve some
-degree of projection into conditions non-analogous to those under
-which it has been calibrated. This projection into areas with novel
-environmental condtions is risky as it may be ecologically and
-statistically invalid. However, depending on the research question
-it may be difficult to avoid or indeed the objective of research to
-do so. An example is the prediction of potential distribution of
-species under future climates. The latter may include conditions
-hitherto not encountered in the area of interest. It is important to
+Correlative species distribution models (SDMs) often involve some
+degree of projection into conditions non-analogous to those under
+which it has been calibrated. This projection into areas with novel
+environmental condtions is risky as it may be ecologically and
+statistically invalid. However, depending on the research question
+it may be difficult to avoid or indeed the objective of research to
+do so. An example is the prediction of potential distribution of
+species under future climates. The latter may include conditions
+hitherto not encountered in the area of interest. It is important to
 identify such areas and to interpret model results with care.
 <p>The <em>r.exdet</em> function allows you to identify areas with
@@ -19,24 +19,24 @@
 the envirionmental variables (<i>NT2</i>: Type 2 novelty), which
 Mesgaran et al. call the multivariate combination novelty index.
-<p>The type 1 (<em>NT1</em>) similarity is similar to how the
-multi-environmental similarity messure (MESS) computes novel
-climates [3]. In both cases if a point is outside the range of a
-given covariate, it gets a negative value based on its distance to
-the minimum/maximum of that covariate. The difference is that the
-MESS is based on the most negative value amongst these covariates.
-The NT1 on the other hand is the sum of all these distances. The NT1
-thus accounts for all variables [2]. The <em>NT1</em> can have
-infinite negative values to zero where zero indicates no
+<p>The type 1 (<em>NT1</em>) similarity is similar to how the
+multi-environmental similarity messure (MESS) computes novel
+climates [3]. In both cases if a point is outside the range of a
+given covariate, it gets a negative value based on its distance to
+the minimum/maximum of that covariate. The difference is that the
+MESS is based on the most negative value amongst these covariates.
+The NT1 on the other hand is the sum of all these distances. The NT1
+thus accounts for all variables [2]. The <em>NT1</em> can have
+infinite negative values to zero where zero indicates no
 extrapolation beyond the univariate coverage of reference data.
-<p>The type 2 (<em>NT2</em>) similarity is based on the Mahalanobis
-distance and is used to identify areas where conditions are within
-the range of univariate variation but which exhibits novel
-combinations between covariates. <em>NT2</em> can range from zero up
-to infinite positive values. Values ranging from 0 to 1 indicate
-similarity (in terms of both univariate range and multivariate
-combination), with values closer to zero being more similar. Values
+<p>The type 2 (<em>NT2</em>) similarity is based on the Mahalanobis
+distance and is used to identify areas where conditions are within
+the range of univariate variation but which exhibits novel
+combinations between covariates. <em>NT2</em> can range from zero up
+to infinite positive values. Values ranging from 0 to 1 indicate
+similarity (in terms of both univariate range and multivariate
+combination), with values closer to zero being more similar. Values
 larger than one are indicative of novel combinations.[1]
 <p><em>r.exdet</em> can also compute the most influential covariate (
@@ -62,7 +62,7 @@
 by the mask.</li>
 <li>The user can provide a
 <a href="http://grass.osgeo.org/grass64/manuals/g.region.html">region</a>
-and a set of data layers describing the reference conditions.
+and a set of data layers describing the reference conditions.
 Conditions in the region defined by the user are compared to the
 conditions in the current computational region.</li>
 </ul>
@@ -77,22 +77,22 @@
 <h2>EXAMPLES</h2>
 You can download a sample data set from <a href=
-"http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet</a>.
-The sample data contains 4 clipped Bioclim variable layers for
-Australia and South Africa sourced from the CliMond dataset. In this
-example we will use the Australia data as reference and the South
-Africa data as projected or test. In the example below I will assume
-you have downloaded the data and imported it in the currently open
+"http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet</a>.
+The sample data contains 4 clipped Bioclim variable layers for
+Australia and South Africa sourced from the CliMond dataset. In this
+example we will use the Australia data as reference and the South
+Africa data as projected or test. In the example below I will assume
+you have downloaded the data and imported it in the currently open
 location/mapset (the coordinate system is latlon, EPSG 4326).
 <div class="code"><pre>
-g.region raster=AusBio13
+g.region raster=AusBio13
 r.exdet -p reference=AusBio13 at example,AusBio14,AusBio5,AusBio6 projection=SaBio13,SaBio14,SaBio5,SaBio6 output=AusSa
 </pre></div>
 <h2>CITATION</h2>
-When using this tool, please cite the paper describing the method in your publications or other derived products.
+When using this tool, please cite the paper describing the method in your publications or other derived products.
 <ul><li>Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.</li></ul>
@@ -102,7 +102,7 @@
 quantification of novel uni- and multi-variate environments. URL:
 https://grass.osgeo.org/grass70/manuals/addons/r.exdet.html</li></ul>
-<h2>REFERENCES</h2>
+<h2>REFERENCES</h2>
 [1] Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity &  Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
@@ -116,7 +116,7 @@
 <h2>AUTHOR</h2>
-Paulo van Breugel, paulo at ecodiv.org
+Paulo van Breugel, paulo at ecodiv.earth
 <p><i>Last changed: $Date$</i>
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.py
--- grass-addons/grass7/raster/r.exdet/r.exdet.py	2017-03-15 13:08:20 UTC (rev 70756)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.py	2017-03-15 13:22:32 UTC (rev 70757)
@@ -4,7 +4,7 @@
 # MODULE:       r.exdet
-# AUTHOR(S):    paulo van Breugel <paulo at ecodiv.org>
+# AUTHOR(S):    paulo van Breugel <paulo at ecodiv.earth>
 # PURPOSE:      Detection and quantification of novel environments, with
 #               points / locations being novel because they are outside
 #               the range of individual covariates (NT1) and points/locations
@@ -12,7 +12,7 @@
 #               combinations between covariates (NT2).
 #               Based on Mesgaran et al.2014 [1]
-# COPYRIGHT: (C) 2014-2016 by Paulo van Breugel and the GRASS Development Team
+# COPYRIGHT: (C) 2014-2017 by Paulo van Breugel and the GRASS Development Team
 #        This program is free software under the GNU General Public
 #        License (>=v2). Read the file COPYING that comes with GRASS
@@ -147,9 +147,8 @@
 def CoVar(maps):
     """Compute the covariance matrix over reference layers"""
     tmpcov = tempfile.mkstemp()[1]
-    text_file = open(tmpcov, "w")
-    text_file.write(gs.read_command("r.covar", quiet=True, map=maps))
-    text_file.close()
+    with open(tmpcov, "w") as text_file:
+        text_file.write(gs.read_command("r.covar", quiet=True, map=maps))
     covar = np.loadtxt(tmpcov, skiprows=1)
     os.remove(tmpcov)
     VI = np.linalg.inv(covar)
@@ -210,9 +209,8 @@
     hist = ' '.join("{!s}={!r}".format(k, v) for (k, v) in opt2.iteritems())
     hist = "r.exdet {}".format(hist)
     unused, tmphist = tempfile.mkstemp()
-    text_file = open(tmphist, "w")
-    text_file.write(hist)
-    text_file.close()
+    with open(tmphist, "w") as text_file:
+        text_file.write(hist)
     # Create covariance table
     VI = CoVar(maps=REF)
@@ -284,9 +282,9 @@
         gs.info(_("Mahalanobis distance map saved: {}").format(mahalpro))
         gs.run_command("r.support", map=mahalpro,
                        title="Mahalanobis distance map projection domain",
-                       units="unitless", loadhistory=tmphist, description=
-                       "Mahalanobis distance map in projection domain "
-                       "estimated using covariance of refence data")
+                       units="unitless", loadhistory=tmphist,
+                       description="Mahalanobis distance map in projection "
+                       "domain estimated using covariance of refence data")
     # Compute NT1
     tmplay = tmpname(out)
@@ -378,11 +376,10 @@
         # Write category labels to MIC maps
         tmpcat = tempfile.mkstemp()
-        text_file = open(tmpcat[1], "w")
-        text_file.write("-1:None\n")
-        for cats in xrange(len(opn)):
-            text_file.write("{}:{}\n".format(cats, opn[cats]))
-        text_file.close()
+        with open(tmpcat[1], "w") as text_file:
+            text_file.write("-1:None\n")
+            for cats in xrange(len(opn)):
+                text_file.write("{}:{}\n".format(cats, opn[cats]))
         gs.run_command("r.category", quiet=True, map=mic12, rules=tmpcat[1],
                        separator=":")
         os.remove(tmpcat[1])
