[GRASS-SVN] r70759 - grass/trunk/vector/v.to.rast
svn_grass at osgeo.org
Wed Mar 15 20:03:42 PDT 2017
Author: annakrat
Date: 2017-03-15 20:03:42 -0700 (Wed, 15 Mar 2017)
New Revision: 70759
Added:
grass/trunk/vector/v.to.rast/v_to_rast_direction.png
grass/trunk/vector/v.to.rast/main.c
grass/trunk/vector/v.to.rast/v.to.rast.html
v.to.rast: fix description of option use=dir to not limit it to flow, add better example with picture to manual
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c 2017-03-15 13:23:23 UTC (rev 70758)
+++ grass/trunk/vector/v.to.rast/main.c 2017-03-16 03:03:42 UTC (rev 70759)
@@ -78,7 +78,7 @@
_("use category values"),
_("use value specified by value option"),
_("use z coordinate (points or contours only)"),
- _("output as flow direction (lines only)"));
+ _("line direction in degrees CCW from east (lines only)"));
use_opt->descriptions = desc;
col = G_define_standard_option(G_OPT_DB_COLUMN);
Modified: grass/trunk/vector/v.to.rast/v.to.rast.html
--- grass/trunk/vector/v.to.rast/v.to.rast.html 2017-03-15 13:23:23 UTC (rev 70758)
+++ grass/trunk/vector/v.to.rast/v.to.rast.html 2017-03-16 03:03:42 UTC (rev 70759)
@@ -36,7 +36,7 @@
<li>
<em>z</em> - use z coordinate (points or contours only)
<li>
-<em>dir</em> - output as flow direction in degrees (lines only)
+<em>dir</em> - line direction in degrees counterclockwise from east (lines only)
</ul>
<p>The <em><b>column</b></em> parameter uses an existing column from the vector map
database table as the category value in the output raster map. Existing table
@@ -58,7 +58,7 @@
Points and orphaned centroids will be converted into single cells on the
resultant raster map.
</ul>
-<p><p><b>Flow directions</b> are given in degrees counterclockwise from east.
+<p><p><b>Line directions</b> are given in degrees counterclockwise from east.
<p><p>Raster category labels are supported for all of <em>use=</em> except <em>use=z</em>.
<p>
The <b>-d</b> flag applies only to lines and boundaries, the default is
@@ -92,6 +92,25 @@
v.to.rast input=streams output=streamsdir use=dir
</pre></div>
+<h3>Calculate slope along path</h3>
+Using slope and aspect maps, compute slope along a bus route (use full NC sample dataset):
+<div class="code"><pre>
+g.region raster=elevation -p
+r.slope.aspect elevation=elevation slope=slope aspect=aspect
+# compute direction of the bus route
+v.to.rast input=busroute11 type=line output=busroute11_dir use=dir
+# extract steepest slope values and transform them into slope along path
+r.mapcalc "route_slope = if(busroute11, slope)"
+r.mapcalc "route_slope_dir = abs(atan(tan(slope) * cos(aspect - busroute11_dir)))"
+</pre></div>
+<center>
+<img src="v_to_rast_direction.png" alt="Slope along path" border=1><br>
+Slope in degrees along bus route
+</center>
<h3>Convert a vector polygon map to raster including descriptive labels (Spearfish)</h3>
Added: grass/trunk/vector/v.to.rast/v_to_rast_direction.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.to.rast/v_to_rast_direction.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
