[GRASS-SVN] r70771 - grass/trunk/raster/r.topmodel
svn_grass at osgeo.org
Mon Mar 20 21:37:51 PDT 2017
Author: hcho
Date: 2017-03-20 21:37:51 -0700 (Mon, 20 Mar 2017)
New Revision: 70771
grass/trunk/raster/r.topmodel/global.h
grass/trunk/raster/r.topmodel/infiltration.c
grass/trunk/raster/r.topmodel/topmodel.c
r.topmodel: Fix cumulative infiltration (Ludek Strouhal); Get rid of gotos
Modified: grass/trunk/raster/r.topmodel/global.h
--- grass/trunk/raster/r.topmodel/global.h 2017-03-19 06:16:24 UTC (rev 70770)
+++ grass/trunk/raster/r.topmodel/global.h 2017-03-21 04:37:51 UTC (rev 70771)
@@ -1,19 +1,7 @@
#include <stdio.h>
-#define FILL 0x1
-#define DIR 0x2
-#define BELEV 0x4
-#define TOPIDX 0x8
-#define IDXSTATS 0x10
-#define OUTPUT 0x20
+#define BUF_SIZE 1024
-#define BUFSIZE 1024
-#define ZERO 0.0000001
-#define TOLERANCE 0.00001
-#define MAXITER 20
-#define NTERMS 10
/* file_io.c */
void get_line(FILE * fp, char *buffer);
void read_input(void);
@@ -140,4 +128,4 @@
GLOBAL struct misc misc;
/* Miscellaneous variables */
-GLOBAL char buf[BUFSIZE];
+GLOBAL char buf[BUF_SIZE];
Modified: grass/trunk/raster/r.topmodel/infiltration.c
--- grass/trunk/raster/r.topmodel/infiltration.c 2017-03-19 06:16:24 UTC (rev 70770)
+++ grass/trunk/raster/r.topmodel/infiltration.c 2017-03-21 04:37:51 UTC (rev 70771)
@@ -3,7 +3,14 @@
#include <grass/glocale.h>
#include "global.h"
-/* Calculates the infiltrate rate (m/hr) for the given timestep. For variable
+#define TOLERANCE 0.00001
+#define MAX_ITER 20
+#define NUM_TERMS 10
+#define PONDING_NO 0
+#define PONDING_STARTED 1
+#define PONDING_YES 2
+/* Calculates the infiltrate rate (m/hr) for the given time step. For variable
* names and equation numbers in comments, refer to Beven (1984).
* Beven, K. J., 1984. Infiltration into a class of vertically non-uniform
@@ -40,9 +47,9 @@
* R Rainfall intensity (m/h)
* r Infiltration rate (m/h)
- * cumI Cumulative infiltration at the start of timestep (m)
- * I Cumulative infiltration at the end of timestep (m)
- * dIdt Infiltration rate for the current timestep (m/hr)
+ * cumI Cumulative infiltration at the start of time step (m)
+ * I Cumulative infiltration at the end of time step (m)
+ * dIdt Infiltration rate for the current time step (m/hr)
* C Storage-suction factor (m) (Morel-Seytoux and Khanji,
* 1974); C = psi * dtheta
* IC I + C
@@ -50,61 +57,72 @@
* from params.lambda
* t Current time (hr)
* tp Time to ponding (hr)
+ * ponding Ponding indicator
+ * PONDING_NO: no ponding
+ * PONDING_STARTED: ponding started in this time step
+ * PONDING_YES: ponding has started in a previous time step
- static double cumI = 0.0, I = 0.0;
- static char ponding = 0;
- double r, C, IC, lambda, dIdt, t, tp;
+ static double cumI = 0.0, I = 0.0, lambda = 0.0, tp = 0.0;
+ static int ponding = PONDING_NO;
+ double r, C, IC, dIdt, t;
double f1, f2, df, sum;
int fact;
int i, j;
/* reset if there is no rainfall */
if (R <= 0.0) {
- cumI = 0.0;
- I = 0.0;
- ponding = 0;
+ cumI = I = lambda = tp = 0.0;
+ ponding = PONDING_NO;
return 0.0;
t = timestep * input.dt;
- lambda = tp = f1 = 0.0;
C = params.psi * params.dtheta;
+ f1 = 0.0;
- /* if no ponding occurred yet */
- if (!ponding) {
- if (cumI > 0) {
- f1 = cumI;
- /* infiltration rate: Eq. (6)
- * Note that his Ks = K0 * exp(f * z) in Eq. (1a) instead of
- * Ks = K0 * exp(-f * z) used in his TOPMODEL code, TMOD9502.F.
- * Substitute f=-dtheta/m for f in Eq. (1a), hence -K0 and
- * exp(f1/m), slightly different from the original Eq. (6).
+ /* if ponding hasn't started and cumulative infiltration is greater than 0
+ if (ponding == PONDING_NO && cumI > 0) {
+ f1 = cumI;
+ /* infiltration rate: Eq. (6)
+ * Note that his Ks=K0*exp(f*z) in Eq. (1a) instead of Ks=K0*exp(-f*z)
+ * used in his TOPMODEL code, TMOD9502.F. Substitute f=-dtheta/m for f
+ * in Eq. (1a), hence -K0 and exp(f1/m), slightly different from the
+ * original Eq. (6).
+ r = -params.K0 / params.m * (C + f1) / (1 - exp(f1 / params.m));
+ /* if infiltration rate is less than rainfall intensity, ponding starts
+ if (r < R) {
+ I = cumI;
+ /* ponding time: tp will remain the same until next ponding occurs
- r = -params.K0 / params.m * (C + f1) / (1 - exp(f1 / params.m));
- /* rainfall intensity is greater than infiltration
- * rate, so ponding starts */
- if (r < R) {
- I = cumI;
- tp = t - input.dt;
- ponding = 1;
- goto cont1;
+ tp = t - input.dt;
+ ponding = PONDING_STARTED;
+ /* if ponding hasn't started yet */
+ if (ponding == PONDING_NO) {
/* try full infiltration */
f2 = cumI + R * input.dt;
/* infiltration rate */
r = -params.K0 / params.m * (C + f2) / (1 - exp(f2 / params.m));
- /* if infiltration rate is greater than rainfall intensity, all
- * rainfall will be infiltrated */
- if (f2 == 0.0 || r > R)
- goto cont2;
+ /* if potential cumulative infiltration is 0 or infiltration rate is
+ * greater than rainfall intensity, all rainfall will be infiltrated
+ if (f2 == 0.0 || r > R) {
+ /* full infiltration */
+ dIdt = R;
+ cumI += dIdt * input.dt;
+ return dIdt;
/* infiltration rate is less than rainfall intensity */
/* Newton-Raphson iteration to solve Eq. (6) for I */
/* guess new cumulative infiltration */
I = cumI + r * input.dt;
- for (i = 0; i < MAXITER; i++) {
+ for (i = 0; i < MAX_ITER; i++) {
/* new infiltration rate */
r = -params.K0 / params.m * (C + I) / (1 - exp(I / params.m));
/* if new infiltration rate is greater than rainfall intensity,
@@ -125,12 +143,12 @@
if (fabs(df) <= TOLERANCE)
break;
- if (i == MAXITER)
+ if (i == MAX_ITER)
G_warning(
- _("Maximum number of iterations exceeded at timestep %d"),
+ _("Maximum number of iterations exceeded at time step %d"),
timestep);
- /* ponding time */
+ /* ponding time: tp will remain the same until next ponding occurs */
tp = t - input.dt + (I - cumI) / R;
/* if ponding time is greater than the current time,
* tp = t - dt + (I - cumI) / R > t
@@ -140,32 +158,41 @@
* total rainfall (R * dt), which cannot happen when there is no
* ponding, so infiltrate all rainfall
- if (tp > t)
- goto cont2;
+ if (tp > t) {
+ dIdt = R;
+ return dIdt;
- cont1:
- /* if additional infiltration is less than the total rainfall, ponding
- * starts
+ /* ponding starts if additional infiltration is less than the total
+ * rainfall because not all rainfall can be infiltrated in this time
+ * step
+ /* if ponding just started */
+ if (ponding == PONDING_STARTED) {
+ /* lambda will remain the same until next ponding occurs */
lambda = 0.0;
fact = 1;
IC = I + C;
- for (j = 1; j <= NTERMS; j++) {
+ for (j = 1; j <= NUM_TERMS; j++) {
fact *= j;
lambda += pow(IC / params.m, (double)j) / (double)(j * fact);
/* lambda in Eq. (8) */
lambda = log(IC) - (log(IC) + lambda) / exp(C / params.m);
I += R * (t - tp) / 2.0;
- ponding = 1;
/* Newton-Raphson iteration to solve Eq. (8) for I */
IC = I + C;
sum = 0.0;
fact = 1;
fact *= j;
sum += pow(IC / params.m, (double)j) / (double)(j * fact);
@@ -179,14 +206,15 @@
/* inverse of Eq. (7) in hr/m */
f2 = (exp(I / params.m) - 1.0) / (IC * params.K0 / params.m);
/* -(Eq. (8) - (t-tp)) * Eq. (7): cumulative infiltration in a short
- * time period */
+ * time period
df = -f1 / f2;
I += df;
break;
- if (i == MAXITER)
- G_warning(_("Maximum number of iterations exceeded at timestep %d"),
+ G_warning(_("Maximum number of iterations exceeded at time step %d"),
timestep);
/* if new cumulative infiltration is less than the previous cumulative
@@ -194,18 +222,18 @@
* infiltration and guess cumulative infiltration for the next time step
if (I < cumI + R * input.dt) {
+ /* less than full infiltration */
dIdt = (I - cumI) / input.dt;
cumI = I;
/* initial guess for next time step */
- return dIdt;
+ ponding = PONDING_YES
+ } else {
+ dIdt = R;
-cont2:
- /* infiltrate all rainfall */
- dIdt = R;
- cumI += dIdt * input.dt;
- ponding = 0;
return dIdt;
Modified: grass/trunk/raster/r.topmodel/topmodel.c
--- grass/trunk/raster/r.topmodel/topmodel.c 2017-03-19 06:16:24 UTC (rev 70770)
+++ grass/trunk/raster/r.topmodel/topmodel.c 2017-03-21 04:37:51 UTC (rev 70771)
@@ -4,6 +4,8 @@
#include "global.h"
+#define ZERO 0.0000001
void create_topidxstats(char *topidx, int ntopidxclasses, char *outtopidxstats)
char input[GPATH_MAX], nsteps[32];
