[GRASS-SVN] r70776 - in grass/branches/releasebranch_7_0/vector: v.lidar.correction v.lidar.edgedetection
svn_grass at osgeo.org
Tue Mar 21 02:35:15 PDT 2017
Author: martinl
Date: 2017-03-21 02:35:15 -0700 (Tue, 21 Mar 2017)
New Revision: 70776
grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c
grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c
v.lidar.edgedetection+v.in.lidar.correction: message cosmetics
no i18n for debug
progress info messages are important
(merge r70774 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c
--- grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c 2017-03-21 09:33:14 UTC (rev 70775)
+++ grass/branches/releasebranch_7_0/vector/v.lidar.correction/main.c 2017-03-21 09:35:15 UTC (rev 70776)
@@ -270,11 +270,11 @@
P_get_edge(P_BILINEAR, &dims, stepE, stepN);
P_set_dim(&dims, stepE, stepN, &nsplx_adj, &nsply_adj);
- G_verbose_message(n_("adjusted EW spline %d",
- "adjusted EW splines %d",
+ G_verbose_message(n_("Adjusted EW spline %d",
+ "Adjusted EW splines %d",
nsplx_adj), nsplx_adj);
- G_verbose_message(n_("adjusted NS spline %d",
- "adjusted NS splines %d",
+ G_verbose_message(n_("Adjusted NS spline %d",
+ "Adjusted NS splines %d",
nsply_adj), nsply_adj);
/* calculate number of subregions */
@@ -321,7 +321,7 @@
nsply = NSPLY_MAX;
- G_debug(1, _("nsply = %d"), nsply);
+ G_debug(1, "nsply = %d", nsply);
elaboration_reg.east = original_reg.west;
last_column = FALSE;
@@ -330,7 +330,7 @@
subregion++;
if (nsubregions > 1)
- G_message(_("subregion %d of %d"), subregion, nsubregions);
+ G_message(_("Subregion %d of %d"), subregion, nsubregions);
P_set_regions(&elaboration_reg, &general_box, &overlap_box, dims,
GENERAL_COLUMN);
@@ -354,21 +354,21 @@
nsplx = NSPLX_MAX;
- G_debug(1, _("nsplx = %d"), nsplx);
+ G_debug(1, "nsplx = %d", nsplx);
dim_vect = nsplx * nsply;
- G_debug(1, _("read vector region map"));
+ G_debug(1, "read vector region map");
observ =
P_Read_Vector_Correction(&In, &elaboration_reg, &npoints,
&nterrain, dim_vect, &lcat);
- G_debug(5, _("npoints = %d, nterrain = %d"), npoints, nterrain);
+ G_debug(5, "npoints = %d, nterrain = %d", npoints, nterrain);
if (npoints > 0) { /* If there is any point falling into elaboration_reg. */
count_terrain = 0;
nparameters = nsplx * nsply;
/* Mean calculation */
- G_debug(3, _("Mean calculation"));
+ G_important_message(_("Performing mean calculation..."));
mean = P_Mean_Calc(&elaboration_reg, observ, npoints);
/*Least Squares system */
@@ -382,7 +382,7 @@
lineVect = G_alloc_ivector(npoints + 1);
/* Setting obsVect vector & Q matrix */
- G_debug(3, _("Only TERRAIN points"));
+ G_debug(3, "Only TERRAIN points");
for (i = 0; i < npoints; i++) {
if (observ[i].cat == TERRAIN_SINGLE) {
obsVect[count_terrain][0] = observ[i].coordX;
@@ -412,7 +412,7 @@
G_free_vector(Q);
G_free_matrix(obsVect);
- G_verbose_message( _("Correction and creation of terrain vector"));
+ G_important_message( _("Correction and creation of terrain vector..."));
P_Sparse_Correction(&In, &Out, &Terrain, &elaboration_reg,
general_box, overlap_box, obsVect_all, lcat,
parVect, lineVect, stepN, stepE,
@@ -434,7 +434,7 @@
/* Dropping auxiliar table */
if (npoints > 0) {
- G_debug(1, _("Dropping <%s>"), table_name);
+ G_debug(1, "Dropping <%s>", table_name);
if (P_Drop_Aux_Table(driver, table_name) != DB_OK)
G_fatal_error(_("Auxiliar table could not be dropped"));
Modified: grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c
--- grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c 2017-03-21 09:33:14 UTC (rev 70775)
+++ grass/branches/releasebranch_7_0/vector/v.lidar.edgedetection/main.c 2017-03-21 09:35:15 UTC (rev 70776)
@@ -292,8 +292,8 @@
P_get_edge(P_BICUBIC, &dims, stepE, stepN);
- G_verbose_message(_("adjusted EW splines %d"), nsplx_adj);
- G_verbose_message(_("adjusted NS splines %d"), nsply_adj);
+ G_verbose_message(_("Adjusted EW splines %d"), nsplx_adj);
+ G_verbose_message(_("Adjusted NS splines %d"), nsply_adj);
edgeE = dims.ew_size - dims.overlap - 2 * dims.edge_v;
@@ -348,7 +348,7 @@
subregion++;
GENERAL_COLUMN);
@@ -390,7 +390,7 @@
/* Least Squares system */
- G_debug(1, _("Allocating memory for bilinear interpolation"));
+ G_debug(1, "Allocating memory for bilinear interpolation");
BW = P_get_BandWidth(P_BILINEAR, nsply); /* Bilinear interpolation */
N = G_alloc_matrix(nparameters, BW); /* Normal matrix */
TN = G_alloc_vector(nparameters); /* vector */
@@ -411,7 +411,7 @@
G_free(observ);
- G_verbose_message(_("Bilinear interpolation"));
+ G_important_message(_("Performing bilinear interpolation..."));
normalDefBilin(N, TN, Q, obsVect, stepE, stepN, nsplx,
nsply, elaboration_reg.west,
elaboration_reg.south, npoints, nparameters,
@@ -423,12 +423,12 @@
for (tn = 0; tn < nparameters; tn++)
TN[tn] = 0;
- G_debug(1, _("Allocating memory for bicubic interpolation"));
+ G_debug(1, "Allocating memory for bicubic interpolation");
BW = P_get_BandWidth(P_BICUBIC, nsply);
parVect_bicub = G_alloc_vector(nparameters); /* Bicubic parameters vector */
- G_verbose_message(_("Bicubic interpolation"));
+ G_important_message(_("Performing bicubic interpolation..."));
normalDefBicubic(N, TN, Q, obsVect, stepE, stepN, nsplx,
@@ -440,7 +440,7 @@
G_free_vector(TN);
G_free_vector(Q);
- G_verbose_message(_("Point classification"));
+ G_important_message(_("Point classification..."));
classification(&Out, elaboration_reg, general_box,
overlap_box, obsVect, parVect_bilin,
parVect_bicub, mean, alpha, grad_H, grad_L,
@@ -462,7 +462,7 @@
if (npoints > 0) {
G_warning(_("Auxiliar table could not be dropped"));
