[GRASS-SVN] r70785 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Mar 21 13:58:25 PDT 2017
Author: mmetz
Date: 2017-03-21 13:58:25 -0700 (Tue, 21 Mar 2017)
New Revision: 70785
grass/trunk/lib/vector/Vlib/break_polygons.c
vectorlib: reduce compiler warnings
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c 2017-03-21 20:51:43 UTC (rev 70784)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c 2017-03-21 20:58:25 UTC (rev 70785)
@@ -71,7 +71,7 @@
static int fpoint;
/* Function called from RTreeSearch for point found */
-static int srch(int id, const struct RTree_Rect *rect, int *arg)
+static int srch(int id, const struct RTree_Rect *rect, void *arg)
fpoint = id;
@@ -196,7 +196,7 @@
/* Already in DB? */
fpoint = -1;
- RTreeSearch(RTree, &rect, (void *)srch, NULL);
+ RTreeSearch(RTree, &rect, srch, NULL);
G_debug(3, "fpoint = %d", fpoint);
if (Points->n_points <= 2 ||
@@ -324,7 +324,7 @@
/* One point only or
* last point and line is not broken, do nothing */
- RTreeSearch(RTree, &rect, (void *)srch, 0);
/* read point */
@@ -671,7 +671,7 @@
void Vect_break_polygons(struct Map_info *Map, int type, struct Map_info *Err)
if (getenv("GRASS_VECTOR_LOWMEM"))
- return Vect_break_polygons_file(Map, type, Err);
+ Vect_break_polygons_file(Map, type, Err);
else
- return Vect_break_polygons_mem(Map, type, Err);
+ Vect_break_polygons_mem(Map, type, Err);
