[GRASS-SVN] r70816 - grass-addons/grass7/raster/r.vif
svn_grass at osgeo.org
Fri Mar 31 12:22:27 PDT 2017
Author: pvanbosgeo
Date: 2017-03-31 12:22:26 -0700 (Fri, 31 Mar 2017)
New Revision: 70816
grass-addons/grass7/raster/r.vif/r.vif.html
r.vif addon: small correction
Modified: grass-addons/grass7/raster/r.vif/r.vif.html
--- grass-addons/grass7/raster/r.vif/r.vif.html 2017-03-31 19:22:20 UTC (rev 70815)
+++ grass-addons/grass7/raster/r.vif/r.vif.html 2017-03-31 19:22:26 UTC (rev 70816)
@@ -45,8 +45,8 @@
<p>Using random sub-set of raster cells as input means that the vif values may
vary between runs. If the sub-set is too small it may even lead to differences
in variables selected when running the step-wise procedure. Special care should
-be taken when many of the equations are underdetermined (when the vif is
-<i>Inf</i>).
+be taken when many of the equations are underdetermined (the value of vif is
+shown as <i>Inf</i>).
<p>As an alternative, the user can set the <em>f</em> flag to evoke the
'low-memory option'. This will use the <a
