[GRASS-SVN] r71002 - grass-addons/grass7/raster/r.vif
svn_grass at osgeo.org
Tue May 2 14:58:07 PDT 2017
Author: pvanbosgeo
Date: 2017-05-02 14:58:07 -0700 (Tue, 02 May 2017)
New Revision: 71002
grass-addons/grass7/raster/r.vif/r.vif.py
addon r.vif: removed unused dependency on scipy stats
Modified: grass-addons/grass7/raster/r.vif/r.vif.py
--- grass-addons/grass7/raster/r.vif/r.vif.py 2017-05-02 19:57:32 UTC (rev 71001)
+++ grass-addons/grass7/raster/r.vif/r.vif.py 2017-05-02 21:58:07 UTC (rev 71002)
@@ -7,7 +7,7 @@
# AUTHOR(S): Paulo van Breugel <p.vanbreugel AT gmail.com>
# PURPOSE: Calculate the variance inflation factor of set of
# variables. The computation is done using an user defined number
-# (or percentage) of random cells (default 10.000) as input.
+# (or percentage) of random cells (default 10.000) as input.
# The user can set a maximum VIF, in wich case the VIF will
# calculated again after removing the variables with the highest
# VIF. This will be repeated till the VIF falls below the user
@@ -91,7 +91,6 @@
import sys
import math
import numpy as np
-from scipy import stats
import uuid
import tempfile
import atexit
