[GRASS-SVN] r71004 - grass-addons/grass7/raster/r.denoise
svn_grass at osgeo.org
Tue May 2 18:47:05 PDT 2017
Author: wenzeslaus
Date: 2017-05-02 18:47:05 -0700 (Tue, 02 May 2017)
New Revision: 71004
grass-addons/grass7/raster/r.denoise/r.denoise.py
r.denoise: lazy import pyproj
Modified: grass-addons/grass7/raster/r.denoise/r.denoise.py
--- grass-addons/grass7/raster/r.denoise/r.denoise.py 2017-05-02 22:34:41 UTC (rev 71003)
+++ grass-addons/grass7/raster/r.denoise/r.denoise.py 2017-05-03 01:47:05 UTC (rev 71004)
@@ -73,11 +73,7 @@
from itertools import izip
import grass.script as grass
-# pyproj
-try:
- import pyproj
-except ImportError:
- grass.fatal(_("pyproj not found, install it first: pip install pyproj (https://jswhit.github.io/pyproj)"))
+# pyproj lazy imported at the end of the file
# PID for temporary files
unique = str(os.getpid())
@@ -219,6 +215,17 @@
#run the module
if __name__ == "__main__":
options, flags = grass.parser()
+ # lazy import
+ # TODO: ideally, it should be done only if reprojection is needed
+ # or replace by pure GRASS GIS if pyproj not available
+ try:
+ import pyproj
+ except ImportError:
+ grass.fatal(_("pyproj not found, install it first, e.g.:"
+ " pip install pyproj"
+ " (https://jswhit.github.io/pyproj)"))
atexit.register(cleanup)
check_requirements()
main()
