[GRASS-SVN] r71033 - grass-addons/grass7/raster/r.vect.stats
svn_grass at osgeo.org
Fri May 5 06:46:51 PDT 2017
Author: martinl
Date: 2017-05-05 06:46:51 -0700 (Fri, 05 May 2017)
New Revision: 71033
grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py
r.vect.stats: export only points falling into current region
Modified: grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py
--- grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py 2017-05-05 13:45:58 UTC (rev 71032)
+++ grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py 2017-05-05 13:46:51 UTC (rev 71033)
@@ -71,7 +71,7 @@
out_process = gs.pipe_command(
'v.out.ascii', input=vector, layer=layer, format='point',
- separator=sep, **out_args)
+ separator=sep, flags='r', **out_args)
in_process = gs.start_command(
'r.in.xyz', input='-', output=raster, method=method, z=z,
separator=sep, stdin=out_process.stdout)
