[GRASS-SVN] r71052 - in grass/branches/releasebranch_7_2: display/d.vect general/g.region raster/r.random vector/v.cluster vector/v.decimate vector/v.edit vector/v.external vector/v.in.ascii vector/v.in.dxf vector/v.in.lidar vector/v.info vector/v.patch vector/v.perturb vector/v.random vector/v.rectify
svn_grass at osgeo.org
Sun May 7 10:28:47 PDT 2017
Author: martinl
Date: 2017-05-07 10:28:47 -0700 (Sun, 07 May 2017)
New Revision: 71052
grass/branches/releasebranch_7_2/display/d.vect/main.c
grass/branches/releasebranch_7_2/general/g.region/main.c
grass/branches/releasebranch_7_2/raster/r.random/main.c
grass/branches/releasebranch_7_2/vector/v.cluster/main.c
grass/branches/releasebranch_7_2/vector/v.decimate/main.c
grass/branches/releasebranch_7_2/vector/v.edit/main.c
grass/branches/releasebranch_7_2/vector/v.external/main.c
grass/branches/releasebranch_7_2/vector/v.in.ascii/main.c
grass/branches/releasebranch_7_2/vector/v.in.dxf/main.c
grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c
grass/branches/releasebranch_7_2/vector/v.info/main.c
grass/branches/releasebranch_7_2/vector/v.patch/main.c
grass/branches/releasebranch_7_2/vector/v.perturb/main.c
grass/branches/releasebranch_7_2/vector/v.random/main.c
grass/branches/releasebranch_7_2/vector/v.rectify/main.c
add new keyword: level1
(merge r70978 from trunk)
Modified: grass/branches/releasebranch_7_2/display/d.vect/main.c
--- grass/branches/releasebranch_7_2/display/d.vect/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/display/d.vect/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -73,6 +73,7 @@
G_add_keyword(_("display"));
G_add_keyword(_("graphics"));
G_add_keyword(_("vector"));
+ G_add_keyword(_("level1"));
module->description = _("Displays user-specified vector map "
"in the active graphics frame.");
Modified: grass/branches/releasebranch_7_2/general/g.region/main.c
--- grass/branches/releasebranch_7_2/general/g.region/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/general/g.region/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -65,6 +65,7 @@
G_add_keyword(_("computational region"));
G_add_keyword(_("extent"));
G_add_keyword(_("resolution"));
_("Manages the boundary definitions for the " "geographic region.");
Modified: grass/branches/releasebranch_7_2/raster/r.random/main.c
--- grass/branches/releasebranch_7_2/raster/r.random/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/raster/r.random/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -52,6 +52,8 @@
G_add_keyword(_("sampling"));
G_add_keyword(_("random"));
_("Creates a raster map layer and vector point map "
"containing randomly located points.");
Modified: grass/branches/releasebranch_7_2/vector/v.cluster/main.c
--- grass/branches/releasebranch_7_2/vector/v.cluster/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.cluster/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -91,6 +91,8 @@
G_add_keyword(_("point cloud"));
G_add_keyword(_("cluster"));
G_add_keyword(_("clump"));
module->description = _("Performs cluster identification.");
/* Define the different options as defined in gis.h */
Modified: grass/branches/releasebranch_7_2/vector/v.decimate/main.c
--- grass/branches/releasebranch_7_2/vector/v.decimate/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.decimate/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -127,6 +127,8 @@
G_add_keyword(_("extract"));
G_add_keyword(_("select"));
G_add_keyword(_("points"));
module->label = _("Decimates a point cloud");
module->description = _("Copies points from one vector to another"
" while applying different decimations");
Modified: grass/branches/releasebranch_7_2/vector/v.edit/main.c
--- grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -58,6 +58,8 @@
G_add_keyword(_("node"));
G_add_keyword(_("point"));
G_add_keyword(_("vertex"));
module->description = _("Edits a vector map, allows adding, deleting "
"and modifying selected vector features.");
Modified: grass/branches/releasebranch_7_2/vector/v.external/main.c
--- grass/branches/releasebranch_7_2/vector/v.external/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.external/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -52,6 +52,8 @@
G_add_keyword(_("external"));
G_add_keyword("OGR");
G_add_keyword("PostGIS");
module->description = _("Creates a new pseudo-vector map as a link to an OGR-supported layer "
"or a PostGIS feature table.");
parse_args(argc, argv,
Modified: grass/branches/releasebranch_7_2/vector/v.in.ascii/main.c
--- grass/branches/releasebranch_7_2/vector/v.in.ascii/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.in.ascii/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -70,6 +70,8 @@
G_add_keyword(_("import"));
G_add_keyword("ASCII");
_("Creates a vector map from an ASCII points file or ASCII vector file.");
Modified: grass/branches/releasebranch_7_2/vector/v.in.dxf/main.c
--- grass/branches/releasebranch_7_2/vector/v.in.dxf/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.in.dxf/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -64,6 +64,8 @@
G_add_keyword("DXF");
_("Converts file in DXF format to GRASS vector map.");
Modified: grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c
--- grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.in.lidar/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -136,6 +136,8 @@
G_add_keyword(_("LIDAR"));
module->description = _("Converts LAS LiDAR point clouds to a GRASS vector map with libLAS.");
in_opt = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/branches/releasebranch_7_2/vector/v.info/main.c
--- grass/branches/releasebranch_7_2/vector/v.info/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.info/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -40,6 +40,7 @@
G_add_keyword(_("history"));
G_add_keyword(_("attribute columns"));
_("Outputs basic information about a vector map.");
Modified: grass/branches/releasebranch_7_2/vector/v.patch/main.c
--- grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -68,6 +68,8 @@
module = G_define_module();
G_add_keyword(_("geometry"));
module->description = _("Creates a new vector map "
"by combining other vector maps.");
Modified: grass/branches/releasebranch_7_2/vector/v.perturb/main.c
--- grass/branches/releasebranch_7_2/vector/v.perturb/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.perturb/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -64,6 +64,7 @@
G_add_keyword(_("statistics"));
G_add_keyword(_("point pattern"));
_("Random location perturbations of vector points.");
Modified: grass/branches/releasebranch_7_2/vector/v.random/main.c
--- grass/branches/releasebranch_7_2/vector/v.random/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.random/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -100,6 +100,8 @@
G_add_keyword(_("stratified random sampling"));
module->description = _("Generates random 2D/3D vector points.");
parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/branches/releasebranch_7_2/vector/v.rectify/main.c
--- grass/branches/releasebranch_7_2/vector/v.rectify/main.c 2017-05-07 17:25:18 UTC (rev 71051)
+++ grass/branches/releasebranch_7_2/vector/v.rectify/main.c 2017-05-07 17:28:47 UTC (rev 71052)
@@ -69,6 +69,8 @@
G_add_keyword(_("rectify"));
_("Rectifies a vector by computing a coordinate "
"transformation for each object in the vector based on the "
