[GRASS-SVN] r71056 - in grass/branches/releasebranch_7_2/raster: r.stats.quantile r.stats.zonal
svn_grass at osgeo.org
Sun May 7 13:28:36 PDT 2017
Author: neteler
Date: 2017-05-07 13:28:36 -0700 (Sun, 07 May 2017)
New Revision: 71056
grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html
grass/branches/releasebranch_7_2/raster/r.stats.zonal/r.stats.zonal.html
r.stats.quantile and r.stats.zonal manuals: examples added (trunk, r71055)
Modified: grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html
--- grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html 2017-05-07 20:27:56 UTC (rev 71055)
+++ grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html 2017-05-07 20:28:36 UTC (rev 71056)
@@ -13,6 +13,30 @@
which are absent from
<em><a href="r.stats.zonal.html">r.stats.zonal</a></em>.
+<h2>EXAMPLE</h2>
+In this example, the raster polygon map <tt>zipcodes</tt> in the North
+Carolina sample dataset is used to calculate quantile raster statistics using
+the <tt>elevation</tt> raster map:
+<div class="code"><pre>
+g.region raster=zipcodes -p
+# print quantiles
+r.stats.quantile base=zipcodes cover=elevation quantiles=3 -p
+27511:0:33.333333:134.717392
+27511:1:66.666667:143.985723
+27513:0:33.333333:140.669993
+27513:1:66.666667:146.279449
+27518:0:33.333333:115.140101
+27518:1:66.666667:129.893723
+# write out percentile raster maps
+r.stats.quantile base=zipcodes cover=elevation percentiles=25,50,75 \
+ output=zipcodes_elev_q25,zipcodes_elev_q50,zipcodes_elev_q75
+</pre></div>
<h2>SEE ALSO</h2>
<em>
Modified: grass/branches/releasebranch_7_2/raster/r.stats.zonal/r.stats.zonal.html
--- grass/branches/releasebranch_7_2/raster/r.stats.zonal/r.stats.zonal.html 2017-05-07 20:27:56 UTC (rev 71055)
+++ grass/branches/releasebranch_7_2/raster/r.stats.zonal/r.stats.zonal.html 2017-05-07 20:28:36 UTC (rev 71056)
@@ -12,6 +12,24 @@
for floating-point cover maps at the expense of not supporting
quantiles. For this, see <em>r.stats.quantile</em>.
+<h2>EXAMPLE</h2>
+Carolina sample dataset is used to calculate zonal raster statistics using
+# pixel count in zipcode areas
+r.stats.zonal base=zipcodes cover=elevation method=count output=zipcodes_elev_count
+r.colors zipcodes_elev_count color=gyr -g
+# average elevation in zipcode areas
+r.stats.zonal base=zipcodes cover=elevation method=average output=zipcodes_elev_avg
+r.colors zipcodes_elev_avg color=elevation -g
+</pre></div>
<h2>SEE ALSO</h2>
<em>
<a href="r.quantile.html">r.quantile</a>,
