[GRASS-SVN] r71064 - grass/trunk/gui/wxpython/iimage2target
svn_grass at osgeo.org
Mon May 8 12:08:24 PDT 2017
Author: ychemin
Date: 2017-05-08 12:08:24 -0700 (Mon, 08 May 2017)
New Revision: 71064
grass/trunk/gui/wxpython/iimage2target/ii2t_manager.py
first working version of the module
Modified: grass/trunk/gui/wxpython/iimage2target/ii2t_manager.py
--- grass/trunk/gui/wxpython/iimage2target/ii2t_manager.py 2017-05-08 17:30:06 UTC (rev 71063)
+++ grass/trunk/gui/wxpython/iimage2target/ii2t_manager.py 2017-05-08 19:08:24 UTC (rev 71064)
@@ -15,7 +15,7 @@
- manager::EditGCP
- manager::GrSettingsDialog
-(C) 2006-2014 by the GRASS Development Team
+(C) 2006-2017 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -24,10 +24,13 @@
@author Original version improved by Martin Landa <landa.martin gmail.com>
@author Rewritten by Markus Metz redesign georectfier -> GCP Manage
@author Support for GraphicsSet added by Stepan Turek <stepan.turek seznam.cz> (2012)
-TODO: i.ortho.transform has 6 appearances, check each of them and configure
+ at author port i.image.2target (v6) to version 7 in 2017 by Yann
+#TODO: i.ortho.transform has 6 appearances, check each of them and configure
+#TODO: i.ortho.transform looks for REF_POINTS/CONTROL_POINTS and not POINTS
+#TODO: CHECK CONTROL_POINTS format and create it for i.ortho.transform to use.
import os
import sys
import shutil
@@ -1003,18 +1006,18 @@
self.VectGRList = []
self.file = {
- 'ii2t_points': os.path.join(self.grassdatabase,
+ 'control_points': os.path.join(self.grassdatabase,
self.xylocation,
self.xymapset,
'group',
self.xygroup,
- 'II2T_POINTS'),
- 'ii2t_points_bak': os.path.join(self.grassdatabase,
+ 'CONTROL_POINTS'),
+ 'control_points_bak': os.path.join(self.grassdatabase,
self.xylocation,
self.xymapset,
'group',
self.xygroup,
- 'II2T_POINTS_BAK'),
+ 'CONTROL_POINTS_BAK'),
'rgrp': os.path.join(self.grassdatabase,
self.xylocation,
self.xymapset,
@@ -1042,8 +1045,8 @@
# make a backup of the current points file
- if os.path.exists(self.file['ii2t_points']):
- shutil.copy(self.file['ii2t_points'], self.file['ii2t_points_bak'])
+ if os.path.exists(self.file['control_points']):
+ shutil.copy(self.file['control_points'], self.file['control_points_bak'])
# polynomial order transformation for georectification
self.gr_order = 1
@@ -1390,7 +1393,7 @@
self.list.SetStringItem(index, 5, str(coord1))
self.mapcoordlist[key][4] = coord[0]
self.mapcoordlist[key][5] = coord[1]
- #TODO ADD ELEVATION FROM MAP AS HEIGHT
+ #ADD ELEVATION FROM MAP AS HEIGHT PARAMETER
if os.path.exists(self.file['elevation']):
#Parse the i.ortho.elev generated file
#Get all lines from file
@@ -1426,12 +1429,12 @@
# self.list.ResizeColumns()
def SaveGCPs(self, event):
- """Make a POINTS file or save GCP coordinates to existing
+ """Make a CONTROL_POINTS file or save GCP coordinates to existing
POINTS file
self.GCPcount = 0
try:
- f = open(self.file['ii2t_points'], mode='w')
+ f = open(self.file['control_points'], mode='w')
# use os.linesep or '\n' here ???
f.write('# Ground Control Points File\n')
f.write("# \n")
@@ -1474,8 +1477,8 @@
GError(
parent=self,
message="%s <%s>. %s%s" %
- (_("Writing POINTS file failed"),
- self.file['ii2t_points'],
+ (_("Writing CONTROL_POINTS file failed"),
+ self.file['control_points'],
os.linesep,
err))
return
@@ -1484,9 +1487,9 @@
# if event != None save also to backup file
if event:
self._giface.WriteLog(
- _('POINTS file saved for group <%s>') %
+ _('CONTROL_POINTS file saved for group <%s>') %
self.xygroup)
#self.SetStatusText(_('POINTS file saved'))
@@ -1511,7 +1514,7 @@
os.linesep, err))
try:
- f = open(self.file['ii2t_points'], 'r')
+ f = open(self.file['control_points'], 'r')
GCPcnt = 0
for line in f.readlines():
@@ -1537,8 +1540,8 @@
GError(
parent=self,
- (_("Reading POINTS file failed"),
+ (_("Reading CONTROL_POINTS file failed"),
os.linesep,
err))
return
@@ -1558,7 +1561,7 @@
"""Reload data from file"""
# use backup
- shutil.copy(self.file['ii2t_points_bak'], self.file['ii2t_points'])
+ shutil.copy(self.file['control_points_bak'], self.file['control_points'])
# delete all items in mapcoordlist
self.mapcoordlist = []
@@ -1793,11 +1796,11 @@
self.SaveGCPs(None)
elif ret == wx.NO:
# restore POINTS file from backup
- if os.path.exists(self.file['ii2t_points_bak']):
+ if os.path.exists(self.file['control_points_bak']):
- os.unlink(self.file['ii2t_points_bak'])
+ os.unlink(self.file['control_points_bak'])
self.SrcMap.Clean()
self.TgtMap.Clean()
@@ -1839,7 +1842,7 @@
def RMSError(self, xygroup, order):
Uses i.ortho.transform to calculate forward and backward error for each used GCP
- in POINTS file and insert error values into GCP list.
+ in CONTROL_POINTS file and insert error values into GCP list.
Calculates total forward and backward RMS error for all used points
# save GCPs to points file to make sure that all checked GCPs are used
@@ -2238,7 +2241,7 @@
self.DeleteAllItems()
self.render = False
- if os.path.isfile(self.gcp.file['ii2t_points']):
+ if os.path.isfile(self.gcp.file['control_points']):
self.gcp.ReadGCPs()
else:
# 3 gcp is minimum
@@ -2559,7 +2562,6 @@
# source coordinates
gridSizer = wx.GridBagSizer(vgap=5, hgap=5)
- #YANN TODO update z and h from i.ortho.elevation selected map
self.xcoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
self.ycoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
self.zcoord = wx.TextCtrl(parent=panel, id=wx.ID_ANY, size=(150, -1))
