[GRASS-SVN] r71079 - grass-addons/grass7/imagery/i.segment.uspo
svn_grass at osgeo.org
Fri May 12 05:36:51 PDT 2017
Author: mlennert
Date: 2017-05-12 05:36:51 -0700 (Fri, 12 May 2017)
New Revision: 71079
grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.html
grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
i.segment.uspo: make non-hierarchical segmentation the default (makes more sense and allows better parallelization)
Modified: grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.html
--- grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.html 2017-05-11 19:43:49 UTC (rev 71078)
+++ grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.html 2017-05-12 12:36:51 UTC (rev 71079)
@@ -28,10 +28,12 @@
href="https://en.wikipedia.org/wiki/Moran%27s_I">Moran's I</a> or <a
href="https://en.wikipedia.org/wiki/Geary%27s_C">Geary's C</a>.
-<p> The user can chose between hierarchical and non-hierarchical segmentation
-using the <b>n</b> flag. The former uses each segmentation at a given threshold
-level as seed for the segmentation at the next threshold level within a given
-minimum segment size.i
+<p>The user can chose between non-hierarchical (default) and hierarchical
+segmentation using the <b>h</b> flag. The latter uses each segmentation at a
+given threshold level as seed for the segmentation at the next threshold level
+within a given minimum segment size. Note that this leads to less optimal
+parallelization as for a given minsize, all segmentations have to be done
+sequentially (see below).
<p>The <b>segment_map</b> parameter allows to provide a
basename for keeping the <b>number_best</b> best segmentations for each given
@@ -40,7 +42,7 @@
minsize and the rank of the map within the region according to its optimization
criteria value.
-<p> The module uses high-level parallelisation (running different segmentations
+<p> The module uses high-level parallelization (running different segmentations
in parallel and then running the collection of parameter values in parallel).
The parameter <b>processes</b> allows to define how many processes should be run
in parallel. Note that when using hierarchical segmentation the number of parallel
Modified: grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
--- grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py 2017-05-11 19:43:49 UTC (rev 71078)
+++ grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py 2017-05-12 12:36:51 UTC (rev 71079)
@@ -266,10 +266,15 @@
#%flag
#% key: n
-#% description: Non-hierarchical segmentation
+#% description: Non-hierarchical segmentation (DEPRECATED: This is now the default setting)
#%end
#%flag
+#% key: h
+#% description: Use hierarchical segmentation
+#%end
+#%flag
#% key: a
#% description: Use adaptive spectral bandwidth (with mean shift)
#% guisection: Mean Shift
@@ -647,6 +652,24 @@
keep = False
if flags['k']:
keep = True
+ hierarchical_segmentation = False
+ if not flags['n'] and not flags['h']:
+ message = "There has been a change in API:\n"
+ message += "Non-hierarchical segmentation is now default.\n"
+ message += "If you want hierarchical segmentation, use the 'h' flag."
+ gscript.warning(message)
+ if flags['n']:
+ message = "The 'n' flag is deprecated.\n"
+ message += "Non-hierarchical segmentation is now the default.\n"
+ message += "For hierarchical segmentation set the '-h' flag.\n"
+ message += "The '-n' flag will soon be removed."
+ if flags['h']:
+ hierarchical_segmentation = True
+ message = "INFO: Using hierarchical segmentation.\n"
+ message += "INFO: Note that this leads to less optimal parallization."
+ gscript.info(message)
check_progs()
@@ -759,7 +782,7 @@
processes_list = []
result_queue = Queue()
if rg:
- if not flags['n']:
+ if hierarchical_segmentation:
minsize_queue = Queue()
for minsize in minsizes:
minsize_queue.put(minsize)
