[GRASS-SVN] r71081 - in grass/trunk/gui/wxpython: . photo2image
Fri May 12 05:47:31 PDT 2017
Author: ychemin
Date: 2017-05-12 05:47:31 -0700 (Fri, 12 May 2017)
New Revision: 71081
Added:
   grass/trunk/gui/wxpython/photo2image/
   grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.html
   grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.py
Removed:
   grass/trunk/gui/wxpython/iphoto2image/
   grass/trunk/gui/wxpython/photo2image/g.gui.iphoto2image.html
   grass/trunk/gui/wxpython/photo2image/g.gui.iphoto2image.py
renamed iphoto2image to photo2image
Deleted: grass/trunk/gui/wxpython/photo2image/g.gui.iphoto2image.html
--- grass/trunk/gui/wxpython/iphoto2image/g.gui.iphoto2image.html	2017-05-12 12:46:00 UTC (rev 71080)
+++ grass/trunk/gui/wxpython/photo2image/g.gui.iphoto2image.html	2017-05-12 12:47:31 UTC (rev 71081)
@@ -1,69 +0,0 @@
-<!-- meta page description: wxGUI GCP Manager for photo to image registration -->
-<!-- meta page index: topic_gui|GUI -->
-<h2>DESCRIPTION</h2>
-This module is based on <b>g.gui.gcp</b>, the GCP manager of GRASS GIS.
-It is part of i.ortho.photo suite.
-<p>
-The aim of this module is to give absolute location values to the fiducial
-points present (in number of 4 or 8) in a <i>scanned</i> aerial photo.
-<p>
-This is necessary as (manual) scanning introduces distortions, rotations and also
-may not be limited to scan the boundary of the photo itself. It is thus necessary
-to give to each fiducial the exact coordinates in mm as given by the aerial
-photographic instrument design, which is unique per camera.
-<p>
-This module requires you to have made a group with your aerial photo <b>(i.group)</b>, a camera
-description file <b>(i.ortho.target)</b> and use them to launch the module. Additional requirements
-are the order of rectification (1 if no of Fiducials is 4, 2 if no of Fiducials is 8) and
-an extension file (if not given, defaults to \$filename_ip2i_out)
-<p>
-An example for Location <b>imagery60</b>:
-<div class="code"><pre>
-g.gui.iphoto2image group=aerial at PERMANENT raster=gs13.1 at PERMANENT camera=gscamera order=2 extension=try --o
-</pre></div>
-<h3>Screenshot of g.gui.iphoto2image</h3>
-<div align="center" style="margin: 10px">
-<a href="wxGUI_iphoto2image_frame.jpg">
-<img src="wxGUI_iphoto2image_frame.jpg" width="600" alt="Screenshot of g.gui.iphoto2image" border=0>
-</a><br>
-<i>Figure: Screenshot of g.gui.iphoto2image</i>
-</div>
-<h2>For a detailed operation manual please read</h2>
-<em>
-<a href="wxGUI.html">wxGUI</a><br>
-<a href="wxGUI.components.html">wxGUI components</a>
-</em>
-<p>
-See also <a href="http://grasswiki.osgeo.org/wiki/WxGUI/Video_tutorials#Georectifier">video
-tutorials</a> on GRASS Wiki.
-<h2>SEE ALSO</h2>
-<em>
-<a href="i.ortho.photo.html">i.ortho.photo</a>,
-<a href="i.group.html">i.group</a>,
-<a href="i.ortho.camera.html">i.ortho.camera</a>,
-<a href="i.ortho.target.html">i.ortho.target</a>,
-<a href="i.rectify.html">i.rectify</a>,
-<a href="m.transform.html">m.transform</a>,
-<a href="v.rectify.html">v.rectify</a>
-</em>
-<h2>AUTHORS</h2>
-Markus Metz<br><br>
-<em>Based on the Georectifier (GRASS 6.4.0)</em> by Michael Barton<br>
-Martin Landa, Czech Technical University in Prague, Czech Republic
-<p>
-<i>$Date$</i>
Deleted: grass/trunk/gui/wxpython/photo2image/g.gui.iphoto2image.py
--- grass/trunk/gui/wxpython/iphoto2image/g.gui.iphoto2image.py	2017-05-12 12:46:00 UTC (rev 71080)
+++ grass/trunk/gui/wxpython/photo2image/g.gui.iphoto2image.py	2017-05-12 12:47:31 UTC (rev 71081)
@@ -1,127 +0,0 @@
-#!/usr/bin/env python
-# MODULE:    Correcting distortions of a scanned photo (modified from GCP Manager)
-# AUTHOR(S): Yann modified the code (was Markus Metz for the GCP Manager)
-# PURPOSE:   Takes a scanned photo and fits fiducial points to known geometry
-# COPYRIGHT: (C) 2012-2017 by Markus Metz, and the GRASS Development Team
-#  This program is free software; you can redistribute it and/or modify
-#  it under the terms of the GNU General Public License as published by
-#  the Free Software Foundation; either version 2 of the License, or
-#  (at your option) any later version.
-#  This program is distributed in the hope that it will be useful,
-#  but WITHOUT ANY WARRANTY; without even the implied warranty of
-#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-#  GNU General Public License for more details.
-#%module
-#% description: Corrects scanning distortions of a paper photo.
-#% keyword: imagery
-#% keyword: aerial
-#% keyword: photo
-#% keyword: GUI
-#%end
-#%option G_OPT_I_GROUP
-#% key: group
-#% required: yes
-#%end
-#%option G_OPT_R_INPUT
-#% key: raster
-#% required: yes
-#%end
-#%option
-#% key: camera
-#% type: string
-#% label: The name of the camera (generated in i.ortho.camera)
-#% description: The name of the camera (generated in i.ortho.camera)
-#% required: yes
-#%end
-#%option
-#% key: order
-#% type: string
-#% label: The rectification order (no of Fiducial=4 -> order=1, no of Fiducial=8 -> order=2)
-#% description: The rectification order (no of Fiducial=4 -> order=1, no of Fiducial=8 -> order=2)
-#% required: yes
-#% answer: 1
-#%end
-#%option
-#% key: extension
-#% type: string
-#% label: The name of the output files extension (used in i.rectify)
-#% description: The name of the output files extension (used in i.rectify)
-#% required: yes
-#% answer: _ip2i_out
-#%end
-Module to run GCP management tool as stadalone application.
- at author Vaclav Petras  <wenzeslaus gmail.com> (standalone module)
-import os
-import grass.script as gscript
-def main():
-    """Sets the GRASS display driver
-    options, flags = gscript.parser()
-    import wx
-    from grass.script.setup import set_gui_path
-    set_gui_path()
-    from core.settings import UserSettings
-    from core.globalvar import CheckWxVersion
-    from core.giface import StandaloneGrassInterface
-    from iphoto2image.ip2i_manager import GCPWizard
-    driver = UserSettings.Get(group='display', key='driver', subkey='type')
-    if driver == 'png':
-        os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
-    else:
-        os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
-    if options['group']:
-        group = options['group']
-    else:
-        gscript.fatal(_("Please provide a group name to process"))
-    if options['raster']:
-        raster = options['raster']
-    else:
-        gscript.fatal(_("Please provide a raster map name to process"))
-    if options['camera']:
-        camera = options['camera']
-    else:
-        gscript.fatal(_("Please provide a camera name (generated by i.ortho.camera)"))
-    if options['order']:
-        order = options['order']
-    else:
-        gscript.fatal(_("Please provive an order value (1 if 4 Fiducials, 2 if 8 Fiducials)"))
-    if options['extension']:
-        extension = options['extension']
-    else:
-        gscript.fatal(_("Please provive an output files extension (used by i.rectify)"))
-    app = wx.App()
-    if not CheckWxVersion([2, 9]):
-        wx.InitAllImageHandlers()
-    wizard = GCPWizard(parent=None, giface=StandaloneGrassInterface(), group=group,
-            raster=raster, raster1=raster, camera=camera, order=order, extension=extension)
-    app.MainLoop()
-if __name__ == '__main__':
-    main()
Copied: grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.html (from rev 71079, grass/trunk/gui/wxpython/iphoto2image/g.gui.iphoto2image.html)
--- grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.html	                        (rev 0)
+++ grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.html	2017-05-12 12:47:31 UTC (rev 71081)
@@ -0,0 +1,69 @@
+<!-- meta page description: wxGUI GCP Manager for photo to image registration -->
+<!-- meta page index: topic_gui|GUI -->
+<h2>DESCRIPTION</h2>
+This module is based on <b>g.gui.gcp</b>, the GCP manager of GRASS GIS.
+It is part of i.ortho.photo suite.
+<p>
+The aim of this module is to give absolute location values to the fiducial
+points present (in number of 4 or 8) in a <i>scanned</i> aerial photo.
+<p>
+This is necessary as (manual) scanning introduces distortions, rotations and also
+may not be limited to scan the boundary of the photo itself. It is thus necessary
+to give to each fiducial the exact coordinates in mm as given by the aerial
+photographic instrument design, which is unique per camera.
+<p>
+This module requires you to have made a group with your aerial photo <b>(i.group)</b>, a camera
+description file <b>(i.ortho.target)</b> and use them to launch the module. Additional requirements
+are the order of rectification (1 if no of Fiducials is 4, 2 if no of Fiducials is 8) and
+an extension file (if not given, defaults to \$filename_ip2i_out)
+<p>
+An example for Location <b>imagery60</b>:
+<div class="code"><pre>
+g.gui.iphoto2image group=aerial at PERMANENT raster=gs13.1 at PERMANENT camera=gscamera order=2 extension=try --o
+</pre></div>
+<h3>Screenshot of g.gui.iphoto2image</h3>
+<div align="center" style="margin: 10px">
+<a href="wxGUI_iphoto2image_frame.jpg">
+<img src="wxGUI_iphoto2image_frame.jpg" width="600" alt="Screenshot of g.gui.iphoto2image" border=0>
+</a><br>
+<i>Figure: Screenshot of g.gui.iphoto2image</i>
+</div>
+<h2>For a detailed operation manual please read</h2>
+<em>
+<a href="wxGUI.html">wxGUI</a><br>
+<a href="wxGUI.components.html">wxGUI components</a>
+</em>
+<p>
+See also <a href="http://grasswiki.osgeo.org/wiki/WxGUI/Video_tutorials#Georectifier">video
+tutorials</a> on GRASS Wiki.
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.ortho.photo.html">i.ortho.photo</a>,
+<a href="i.group.html">i.group</a>,
+<a href="i.ortho.camera.html">i.ortho.camera</a>,
+<a href="i.ortho.target.html">i.ortho.target</a>,
+<a href="i.rectify.html">i.rectify</a>,
+<a href="m.transform.html">m.transform</a>,
+<a href="v.rectify.html">v.rectify</a>
+</em>
+<h2>AUTHORS</h2>
+Markus Metz<br><br>
+<em>Based on the Georectifier (GRASS 6.4.0)</em> by Michael Barton<br>
+Martin Landa, Czech Technical University in Prague, Czech Republic
+<p>
+<i>$Date$</i>
Copied: grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.py (from rev 71079, grass/trunk/gui/wxpython/iphoto2image/g.gui.iphoto2image.py)
--- grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/photo2image/g.gui.photo2image.py	2017-05-12 12:47:31 UTC (rev 71081)
@@ -0,0 +1,127 @@
+#!/usr/bin/env python
+# MODULE:    Correcting distortions of a scanned photo (modified from GCP Manager)
+# AUTHOR(S): Yann modified the code (was Markus Metz for the GCP Manager)
+# PURPOSE:   Takes a scanned photo and fits fiducial points to known geometry
+# COPYRIGHT: (C) 2012-2017 by Markus Metz, and the GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%module
+#% description: Corrects scanning distortions of a paper photo.
+#% keyword: imagery
+#% keyword: aerial
+#% keyword: photo
+#% keyword: GUI
+#%end
+#%option G_OPT_I_GROUP
+#% key: group
+#% required: yes
+#%end
+#%option G_OPT_R_INPUT
+#% key: raster
+#% required: yes
+#%end
+#%option
+#% key: camera
+#% type: string
+#% label: The name of the camera (generated in i.ortho.camera)
+#% description: The name of the camera (generated in i.ortho.camera)
+#% required: yes
+#%end
+#%option
+#% key: order
+#% type: string
+#% label: The rectification order (no of Fiducial=4 -> order=1, no of Fiducial=8 -> order=2)
+#% description: The rectification order (no of Fiducial=4 -> order=1, no of Fiducial=8 -> order=2)
+#% required: yes
+#% answer: 1
+#%end
+#%option
+#% key: extension
+#% type: string
+#% label: The name of the output files extension (used in i.rectify)
+#% description: The name of the output files extension (used in i.rectify)
+#% required: yes
+#% answer: _ip2i_out
+#%end
+Module to run GCP management tool as stadalone application.
+ at author Vaclav Petras  <wenzeslaus gmail.com> (standalone module)
+import os
+import grass.script as gscript
+def main():
+    """Sets the GRASS display driver
+    options, flags = gscript.parser()
+    import wx
+    from grass.script.setup import set_gui_path
+    set_gui_path()
+    from core.settings import UserSettings
+    from core.globalvar import CheckWxVersion
+    from core.giface import StandaloneGrassInterface
+    from iphoto2image.ip2i_manager import GCPWizard
+    driver = UserSettings.Get(group='display', key='driver', subkey='type')
+    if driver == 'png':
+        os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
+    else:
+        os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+    if options['group']:
+        group = options['group']
+    else:
+        gscript.fatal(_("Please provide a group name to process"))
+    if options['raster']:
+        raster = options['raster']
+    else:
+        gscript.fatal(_("Please provide a raster map name to process"))
+    if options['camera']:
+        camera = options['camera']
+    else:
+        gscript.fatal(_("Please provide a camera name (generated by i.ortho.camera)"))
+    if options['order']:
+        order = options['order']
+    else:
+        gscript.fatal(_("Please provive an order value (1 if 4 Fiducials, 2 if 8 Fiducials)"))
+    if options['extension']:
+        extension = options['extension']
+    else:
+        gscript.fatal(_("Please provive an output files extension (used by i.rectify)"))
+    app = wx.App()
+    if not CheckWxVersion([2, 9]):
+        wx.InitAllImageHandlers()
+    wizard = GCPWizard(parent=None, giface=StandaloneGrassInterface(), group=group,
+            raster=raster, raster1=raster, camera=camera, order=order, extension=extension)
+    app.MainLoop()
+if __name__ == '__main__':
+    main()
