[GRASS-SVN] r71089 - in grass-addons/grass7/vector: . v.net.curvedarcs
svn_grass at osgeo.org
Mon May 15 08:17:51 PDT 2017
Author: mlennert
Date: 2017-05-15 08:17:51 -0700 (Mon, 15 May 2017)
New Revision: 71089
Added:
grass-addons/grass7/vector/v.net.curvedarcs/
grass-addons/grass7/vector/v.net.curvedarcs/Makefile
grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.html
grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.py
grass-addons/grass7/vector/v.net.curvedarcs/v_net_curvedarcs.png
grass-addons/grass7/vector/v.net.curvedarcs/v_net_curvedarcs2.png
New addon v.net.curvedarcs: create curved arcs between points
Added: grass-addons/grass7/vector/v.net.curvedarcs/Makefile
--- grass-addons/grass7/vector/v.net.curvedarcs/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.net.curvedarcs/Makefile 2017-05-15 15:17:51 UTC (rev 71089)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.net.curvedarcs
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.net.curvedarcs/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.html
--- grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.html (rev 0)
+++ grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.html 2017-05-15 15:17:51 UTC (rev 71089)
@@ -0,0 +1,76 @@
+<h2>DESCRIPTION</h2>
+<em>v.net.curvedarcs</em> is a frontend to
+<em><a href="v.net.html">v.net</a></em> and
+<em><a href="v.segment.html">v.segment</a></em>
+ that creates curved arcs between given start and end points.
+The user provides a point vector map and a text file (see Notes section) with
+start and end point categories as well as a flow volume for this link which
+will be transferred to the attribute table of the curved arcs.
+<p>
+The user can determine the nature of the curve with the <em>minimum_offset</em>
+and <em>maximum_offset</em> parameters. The longest curve's maximum offset
+from a straight line is equal to the value of <em>maximum_offset</em> in
+map units. The other curves maximum offset from a straight line is calulated
+as length(x)/max_length * max_offset. In other words, shorter lines are less
+curved than longer lines. However, any line's maximum offset is always at
+least <em>minimum_offset</em> from the straight line.
+<h2>NOTES</h2>
+<h2>EXAMPLE</h2>
+TODO
+<div class="code"><pre>
+v.extract census_wake2000 cat=1,52,70,99,101 type=centroid out=tmp
+v.type tmp from=centroid to=point out=points
+echo >> flows.txt << EOF
+> from,to,volume
+> 52,1,100
+> 1,52,50
+> 70,1,50
+> 1,70,50
+> 99,1,66
+> 1,99,100
+> 101,1,25
+> 1,101,75
+> EOF
+v.net.curvedarcs in=points flow=flows.txt sep=comma out=flows minoff=0 maxoff=2000
+d.vect map=flows display=shape,dir width_column=volume width_scale=0.05 size=10
+d.vect map=points display=shape,cat fill_color=red icon=basic/circle label_bcolor=black label_size=12 yref=bottom
+</pre></div>
+<center>
+ <img src="v_net_curvedarcs.png" border="1"><br>
+ The curved arcs with minimum offset = 150 and maximum offset = 2000
+</center>
+<p>
+Using different amount of curvature:
+v.net.curvedarcs in=points flow=flows.txt sep=comma out=flows minoff=150 maxoff=5000 --o
+</pre></div>
+<center>
+ <img src="v_net_curvedarcs2.png" border="1"><br>
+ The curved arcs with minimum offset = 0 and maximum offset = 5000
+</center>
+<h2>SEE ALSO</h2>
+<em>
+ <a href="v.net.html">v.net</a>,
+ <a href="v.segment.html">v.segment</a>,
+</em>
+<h2>AUTHORS</h2>
+Moritz Lennert, DGES-ULB
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.py
--- grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.py (rev 0)
+++ grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.py 2017-05-15 15:17:51 UTC (rev 71089)
@@ -0,0 +1,247 @@
+#!/usr/bin/env python
+# MODULE: v.net.curvedarcs
+# AUTHOR(S): Moritz Lennert
+# PURPOSE: Draws curved arcs
+# COPYRIGHT: (C) 2017 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Draws curved arcs between points (e.g. flows)
+#% keyword: vector
+#% keyword: network
+#% keyword: flows
+#%end
+#%option G_OPT_V_INPUT
+#% label: Point map containing origins and destinations
+#%end
+#%option G_OPT_V_FIELD
+#% label: Layer number where to find point categories
+#%end
+#%option G_OPT_F_INPUT
+#% key: flow_input_file
+#% label: File containing origins, destinations and flow volumes
+#%end
+#%option G_OPT_F_SEP
+#% label: Separator used in input text file
+#%end
+#%option G_OPT_V_OUTPUT
+#% label: Output map with curved lines
+#%end
+#%option
+#% key: minimum_offset
+#% type: double
+#% label: minimum offset at furthest point from straight line
+#% required: yes
+#%end
+#%option
+#% key: maximum_offset
+#% type: double
+#% label: maximum offset at furthest point from straight line
+#% required: yes
+#%end
+#%option
+#% key: vertices
+#% type: integer
+#% label: number of vertices used to draw curved lines
+#% answer: 30
+#%end
+#%flag
+#% key: s
+#% description: Draw also short line for flow from and to same node
+#%end
+import os
+import atexit
+import math
+import grass.script as gscript
+def cleanup():
+ if tmplines:
+ gscript.run_command('g.remove',
+ flags='f',
+ type='vector',
+ name=tmplines,
+ quiet=True)
+ if tmplines2:
+ flags='f',
+ type='vector',
+ name=tmplines2,
+ quiet=True)
+ if tmppoints:
+ flags='f',
+ type='vector',
+ name=tmppoints,
+ quiet=True)
+ gscript.try_remove(vseginfile)
+ gscript.try_remove(vnetinfile)
+def write_segmentdefs(lineinfo, minoffset, maxoffset, nbvertices):
+ filename = gscript.tempfile()
+ maxlength = max(lineinfo.values())
+ step = 100000/nbvertices
+ t = [x/100000.0 for x in range(0,int(math.pi*100000),step)]
+ x = [a/max(t)*100 for a in t]
+ x[-1] -= 0.001
+ with open(filename, 'w') as fout:
+ for linecat in lineinfo:
+ offset = lineinfo[linecat] / maxlength * maxoffset
+ if offset < minoffset:
+ offset = minoffset
+ y = [math.sin(a)*offset for a in t]
+ P = zip(x,y)
+ cat = linecat*10000
+ for px, py in P:
+ cat += 1
+ fout.write("P %d %d %f%% %f\n" % (cat, linecat, px, py))
+ return filename, len(x)
+def write_segarcdefs(lineinfo, maxcat):
+ for arccat in lineinfo:
+ for cat in range(1, maxcat):
+ pointcat = arccat*10000 + cat
+ fout.write("%d %d %d\n" % (arccat, pointcat, pointcat+1))
+ return filename
+def process_infile(flow_file, separator, header, sameok, outputfile):
+ vnetinfile = gscript.tempfile()
+ sqlfile = gscript.tempfile()
+ cat = 0
+ with open(vnetinfile, 'w') as fout:
+ with open(sqlfile, 'w') as sqlout:
+ sqlout.write("BEGIN TRANSACTION;\n")
+ with open(flow_file, 'r') as fin:
+ for line in fin:
+ cat += 1
+ if header:
+ header = False
+ continue
+ data = line.rstrip().split(separator)
+ print data
+ if sameok or not (data[0] == data[1]):
+ fout.write("%s %s %s\n" % (cat, data[0], data[1]))
+ sqlout.write("UPDATE %s SET from_node = %s, to_node = %s, volume = %s WHERE cat = %d;\n" % (outputfile, data[0], data[1], data[2], cat))
+ sqlout.write("END TRANSACTION;\n")
+ return vnetinfile, sqlfile
+def main():
+ orig_point_map = options['input']
+ flow_file = options['flow_input_file']
+ minoffset = float(options['minimum_offset'])
+ maxoffset = float(options['maximum_offset'])
+ vertices = int(options['vertices'])
+ outputfile = options['output']
+ separator = gscript.separator(options['separator'])
+ sameok = flags['s']
+ header = True
+ pid = os.getpid()
+ global tmplines, tmplines2, tmppoints, vseginfile, vnetinfile
+ tmplines = 'tmp_vnetcurvedarcs_tmplines_%d' % pid
+ tmplines2 = 'tmp_vnetcurvedarcs_tmplines2_%d' % pid
+ tmppoints = 'tmp_vnetcurvedarcs_tmppoints_%d' % pid
+ vnetinfile, sqlfile = process_infile(flow_file, separator, header, sameok, outputfile)
+ gscript.message(_("Creating straight flow lines..."))
+ gscript.run_command('v.net',
+ points=orig_point_map,
+ operation='arcs',
+ file_=vnetinfile,
+ out=tmplines,
+ overwrite=True,
+ quiet=True)
+ linedata = gscript.read_command('v.to.db',
+ flags='p',
+ map_=tmplines,
+ option='length',
+ quiet=True).splitlines()
+ lineinfo = {}
+ for line in linedata:
+ data = line.split('|')
+ if int(data[0]) > 0:
+ lineinfo[int(data[0])] = float(data[1])
+ vseginfile, maxcat = write_segmentdefs(lineinfo, minoffset, maxoffset, vertices)
+ gscript.message(_("Creating points of curved lines..."))
+ gscript.run_command('v.segment',
+ input_=tmplines,
+ out=tmppoints,
+ rules=vseginfile,
+ overwrite=True,
+ quiet=True)
+ gscript.message(_("Creating curved lines from points..."))
+ vnetinfile = write_segarcdefs(lineinfo, maxcat)
+ points=tmppoints,
+ output=tmplines,
+ operation='arcs',
+ file_=vnetinfile,
+ overwrite=True,
+ quiet=True)
+ gscript.run_command('v.extract',
+ input_=tmplines,
+ output=tmplines2,
+ layer=1,
+ overwrite=True,
+ quiet=True)
+ gscript.message(_("Creating polylines..."))
+ gscript.run_command('v.build.polylines',
+ input_=tmplines2,
+ output=outputfile,
+ cats='multi',
+ overwrite=True,
+ quiet=True)
+ gscript.run_command('v.db.addtable',
+ map_=outputfile,
+ columns="from_node int, to_node int, volume double precision",
+ quiet=True,
+ overwrite=True)
+ gscript.run_command('db.execute',
+ input_=sqlfile,
+ quiet=True)
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/vector/v.net.curvedarcs/v.net.curvedarcs.py
+ text/x-python
+ native
Added: grass-addons/grass7/vector/v.net.curvedarcs/v_net_curvedarcs.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.net.curvedarcs/v_net_curvedarcs.png
+ image/png
Added: grass-addons/grass7/vector/v.net.curvedarcs/v_net_curvedarcs2.png
Property changes on: grass-addons/grass7/vector/v.net.curvedarcs/v_net_curvedarcs2.png
+ image/png
