[GRASS-SVN] r71098 - in grass/branches/releasebranch_7_2/vector: v.lidar.correction v.lidar.edgedetection v.lidar.growing v.outlier
Thu May 18 02:47:07 PDT 2017
Author: neteler
Date: 2017-05-18 02:47:07 -0700 (Thu, 18 May 2017)
New Revision: 71098
   grass/branches/releasebranch_7_2/vector/v.lidar.correction/main.c
   grass/branches/releasebranch_7_2/vector/v.lidar.edgedetection/main.c
   grass/branches/releasebranch_7_2/vector/v.lidar.growing/main.c
   grass/branches/releasebranch_7_2/vector/v.outlier/main.c
v.lidar.*, v.outlier: document units used for step parameters (completion of trunk r71094; backport of trunk r71097)
Modified: grass/branches/releasebranch_7_2/vector/v.lidar.correction/main.c
--- grass/branches/releasebranch_7_2/vector/v.lidar.correction/main.c	2017-05-18 09:46:13 UTC (rev 71097)
+++ grass/branches/releasebranch_7_2/vector/v.lidar.correction/main.c	2017-05-18 09:47:07 UTC (rev 71098)
@@ -98,7 +98,7 @@
     stepE_opt->required = NO;
     stepE_opt->answer = "25";
     stepE_opt->description =
-	_("Length of each spline step in the east-west direction");
+	_("Length of each spline step (pixels) in the east-west direction");
     stepE_opt->guisection = _("Settings");
     stepN_opt = G_define_option();
@@ -107,7 +107,7 @@
     stepN_opt->required = NO;
     stepN_opt->answer = "25";
     stepN_opt->description =
-	_("Length of each spline step in the north-south direction");
+	_("Length of each spline step (pixels) in the north-south direction");
     stepN_opt->guisection = _("Settings");
     lambda_f_opt = G_define_option();
Modified: grass/branches/releasebranch_7_2/vector/v.lidar.edgedetection/main.c
--- grass/branches/releasebranch_7_2/vector/v.lidar.edgedetection/main.c	2017-05-18 09:46:13 UTC (rev 71097)
+++ grass/branches/releasebranch_7_2/vector/v.lidar.edgedetection/main.c	2017-05-18 09:47:07 UTC (rev 71098)
@@ -95,7 +95,7 @@
     stepE_opt->answer = "4";
@@ -104,7 +104,7 @@
     stepN_opt->answer = "4";
     lambdaB_opt = G_define_option();
Modified: grass/branches/releasebranch_7_2/vector/v.lidar.growing/main.c
--- grass/branches/releasebranch_7_2/vector/v.lidar.growing/main.c	2017-05-18 09:46:13 UTC (rev 71097)
+++ grass/branches/releasebranch_7_2/vector/v.lidar.growing/main.c	2017-05-18 09:47:07 UTC (rev 71098)
@@ -70,7 +70,7 @@
     dbCursor cursor;
-    /* Options' declaration */ ;
+    /* Options' declaration */
     module = G_define_module();
     G_add_keyword(_("vector"));
     G_add_keyword(_("LIDAR"));
Modified: grass/branches/releasebranch_7_2/vector/v.outlier/main.c
--- grass/branches/releasebranch_7_2/vector/v.outlier/main.c	2017-05-18 09:46:13 UTC (rev 71097)
+++ grass/branches/releasebranch_7_2/vector/v.outlier/main.c	2017-05-18 09:47:07 UTC (rev 71098)
@@ -100,7 +100,7 @@
     stepE_opt->answer = "10";
@@ -109,7 +109,7 @@
     stepN_opt->answer = "10";
