[GRASS-SVN] r71105 - in grass/trunk/temporal/t.rast.what: . testsuite
svn_grass at osgeo.org
Mon May 22 03:08:54 PDT 2017
Author: lucadelu
Date: 2017-05-22 03:08:54 -0700 (Mon, 22 May 2017)
New Revision: 71105
grass/trunk/temporal/t.rast.what/t.rast.what.py
grass/trunk/temporal/t.rast.what/testsuite/test_what.py
t.rast.what: added new r.what v flag; added test cases
Modified: grass/trunk/temporal/t.rast.what/t.rast.what.py
--- grass/trunk/temporal/t.rast.what/t.rast.what.py 2017-05-22 09:02:03 UTC (rev 71104)
+++ grass/trunk/temporal/t.rast.what/t.rast.what.py 2017-05-22 10:08:54 UTC (rev 71105)
@@ -109,10 +109,16 @@
##% description: Output integer category values, not cell values
##%end
+#%flag
+#% key: v
+#% description: Show the category for vector points map
+#%end
import sys
import copy
import grass.script as gscript
+import pdb
@@ -130,11 +136,12 @@
order = options["order"]
layout = options["layout"]
null_value = options["null_value"]
- separator = options["separator"]
+ separator = gscript.separator(options["separator"])
nprocs = int(options["nprocs"])
write_header = flags["n"]
use_stdin = flags["i"]
+ vcat = flags["v"]
#output_cat_label = flags["f"]
#output_color = flags["r"]
@@ -148,6 +155,9 @@
if not coordinates and not points and not use_stdin:
gscript.fatal(_("Please specify the coordinates, the points option or use the 'i' flag to pipe coordinate positions to t.rast.what from stdin, to provide the sampling coordinates"))
+ if vcat and not points:
+ gscript.fatal(_("Flag 'v' required option 'points'"))
if use_stdin:
coordinates_stdin = str(sys.__stdin__.read())
# Check if coordinates are given with site names or IDs
@@ -169,22 +179,9 @@
maps = sp.get_registered_maps_as_objects(where=where, order=order,
dbif=dbif)
dbif.close()
if not maps:
gscript.fatal(_("Space time raster dataset <%s> is empty") % sp.get_id())
- # Setup separator
- if separator == "pipe":
- separator = "|"
- if separator == "comma":
- separator = ","
- if separator == "space":
- separator = " "
- if separator == "tab":
- separator = "\t"
- if separator == "newline":
- separator = "\n"
# Setup flags are disabled due to test issues
flags = ""
#if output_cat_label is True:
@@ -193,6 +190,8 @@
# flags += "r"
#if output_cat is True:
# flags += "i"
+ if vcat is True:
+ flags += "v"
# Configure the r.what module
if points:
@@ -286,18 +285,18 @@
# Out the output files in the correct order together
if layout == "row":
one_point_per_row_output(separator, output_files, output_time_list,
- output, write_header, site_input)
+ output, write_header, site_input, vcat)
elif layout == "col":
one_point_per_col_output(separator, output_files, output_time_list,
else:
one_point_per_timerow_output(separator, output_files, output_time_list,
def one_point_per_row_output(separator, output_files, output_time_list,
- output, write_header, site_input):
+ output, write_header, site_input, vcat):
"""Write one point per row
output is of type: x,y,start,end,value
@@ -305,13 +304,15 @@
out_file = open(output, 'w') if output != "-" else sys.stdout
if write_header is True:
+ out_str = ""
+ if vcat:
+ out_str += "cat{sep}"
if site_input:
- out_file.write("x%(sep)sy%(sep)ssite%(sep)sstart%(sep)send%(sep)svalue\n"\
- %({"sep":separator}))
+ out_str += "x{sep}y{sep}site{sep}start{sep}end{sep}value\n"
else:
- out_file.write("x%(sep)sy%(sep)sstart%(sep)send%(sep)svalue\n"\
+ out_str += "x{sep}y{sep}start{sep}end{sep}value\n"
+ out_file.write(out_str.format(sep=separator))
for count in range(len(output_files)):
file_name = output_files[count]
gscript.verbose(_("Transforming r.what output file %s"%(file_name)))
@@ -319,15 +320,28 @@
in_file = open(file_name, "r")
for line in in_file:
line = line.split(separator)
- x = line[0]
- y = line[1]
- if site_input:
- site = line[2]
+ if vcat:
+ cat = line[0]
+ x = line[1]
+ y = line[2]
+ values = line[4:]
+ if site_input:
+ site = line[3]
+ values = line[5:]
+ else:
+ x = line[0]
+ y = line[1]
+ if site_input:
+ site = line[2]
+ values = line[3:]
- # We ignore the site name
- values = line[3:]
for i in range(len(values)):
start, end = map_list[i].get_temporal_extent_as_tuple()
+ if vcat:
+ cat_str = "{ca}{sep}".format(ca=cat, sep=separator)
+ else:
+ cat_str = ""
if site_input:
coor_string = "%(x)10.10f%(sep)s%(y)10.10f%(sep)s%(site_name)s%(sep)s"\
%({"x":float(x),"y":float(y),"site_name":str(site),"sep":separator})
@@ -338,7 +352,7 @@
%({"start":str(start), "end":str(end),
"val":(values[i].strip()),"sep":separator})
- out_file.write(coor_string + time_string)
+ out_file.write(cat_str + coor_string + time_string)
in_file.close()
@@ -348,7 +362,7 @@
def one_point_per_col_output(separator, output_files, output_time_list,
"""Write one point per col
output is of type:
start,end,point_1 value,point_2 value,...,point_n value
@@ -374,38 +388,47 @@
if first is True:
- out_file.write("start%(sep)send"%({"sep":separator}))
- if site_input:
- for row in matrix:
+ out_str = "start%(sep)send"%({"sep":separator})
+ for row in matrix:
+ if vcat:
+ cat = row[0]
+ x = row[1]
+ y = row[2]
+ out_str += "{sep}{cat}{sep}{x:10.10f};" \
+ "{y:10.10f}".format(cat=cat, x=float(x),
+ y=float(y),
+ sep=separator)
+ if site_input:
+ site = row[3]
+ out_str += "{sep}{site}".format(sep=separator,
+ site=site)
+ else:
x = row[0]
y = row[1]
- site = row[2]
- out_file.write("%(sep)s%(x)10.10f;%(y)10.10f;%(site_name)s"\
- %({"sep":separator,
- "x":float(x),
- "y":float(y),
- "site_name":str(site)}))
- else:
- x = row[0]
- y = row[1]
- out_file.write("%(sep)s%(x)10.10f;%(y)10.10f"\
- "x":float(x),
- "y":float(y)}))
+ out_str += "{sep}{x:10.10f};" \
+ "{y:10.10f}".format(x=float(x), y=float(y),
+ sep=separator)
+ if site_input:
+ site = row[2]
+ site=site)
- out_file.write("\n")
+ out_file.write(out_str + "\n")
first = False
- for col in range(num_cols - 3):
+ if vcat:
+ ncol = 4
+ else:
+ ncol = 3
+ for col in range(num_cols - ncol):
start, end = output_time_list[count][col].get_temporal_extent_as_tuple()
time_string = "%(start)s%(sep)s%(end)s"\
"sep":separator})
out_file.write(time_string)
for row in range(len(matrix)):
- value = matrix[row][col + 3]
+ value = matrix[row][col + ncol]
out_file.write("%(sep)s%(value)s"\
%({"sep":separator,
"value":value.strip()}))
@@ -418,7 +441,7 @@
def one_point_per_timerow_output(separator, output_files, output_time_list,
"""Use the original layout of the r.what output and print instead of
the raster names, the time stamps as header
@@ -441,10 +464,14 @@
if write_header:
if first is True:
+ if vcat:
+ header = "cat{sep}".format(sep=separator)
+ else:
+ header = ""
if site_input:
- header = "x%(sep)sy%(sep)ssite"%({"sep":separator})
+ header += "x%(sep)sy%(sep)ssite"%({"sep":separator})
else:
- header = "x%(sep)sy"%({"sep":separator})
+ header += "x%(sep)sy"%({"sep":separator})
for map in map_list:
start, end = map.get_temporal_extent_as_tuple()
time_string = "%(sep)s%(start)s;%(end)s"\
@@ -458,7 +485,9 @@
cols = lines[i].split(separator)
if first is True:
- if site_input:
+ if vcat and site_input:
+ matrix.append(cols[:4])
+ elif vcat or site_input:
matrix.append(cols[:3])
else:
matrix.append(cols[:2])
Modified: grass/trunk/temporal/t.rast.what/testsuite/test_what.py
--- grass/trunk/temporal/t.rast.what/testsuite/test_what.py 2017-05-22 09:02:03 UTC (rev 71104)
+++ grass/trunk/temporal/t.rast.what/testsuite/test_what.py 2017-05-22 10:08:54 UTC (rev 71105)
@@ -69,6 +69,14 @@
self.assertFileMd5("out_row_coords.txt",
"cd917ac4848786f1b944512eed1da5bc", text=True)
+ def test_row_output_cat(self):
+ self.assertModule("t.rast.what", strds="A", output="out_row_cat.txt",
+ points="points", flags="nv", layout="row",
+ nprocs=1, overwrite=True, verbose=True)
+ self.assertFileMd5("out_row_cat.txt",
+ "bddde54bf4f40c41a17305c3442980e5", text=True)
def test_col_output(self):
self.assertModule("t.rast.what", strds="A", output="out_col.txt",
points="points", flags="n", layout="col",
@@ -93,6 +101,22 @@
self.assertFileMd5("out_timerow.txt",
"129fe0b63019e505232efa20ad42c03a", text=True)
+ def test_col_output_cat(self):
+ self.assertModule("t.rast.what", strds="A", output="out_col_cat.txt",
+ points="points", flags="nv", layout="col",
+ self.assertFileMd5("out_col_cat.txt",
+ "e1d8e6651b3bff1c35e366e48d634db4", text=True)
+ def test_timerow_output_cat(self):
+ self.assertModule("t.rast.what", strds="A", output="out_col_trow.txt",
+ points="points", flags="nv", layout="timerow",
+ self.assertFileMd5("out_col_trow.txt",
+ "55e2ff8ddaeb731a73daca48adf2768d", text=True)
def test_timerow_output_coords(self):
self.assertModule("t.rast.what", strds="A", output="out_timerow_coords.txt",
coordinates=(30, 30, 45, 45), flags="n", layout="timerow",
@@ -122,6 +146,27 @@
self.assertLooksLike(text, t_rast_what.outputs.stdout)
+ def test_row_stdout_where_parallel_cat(self):
+ t_rast_what = SimpleModule("t.rast.what", strds="A", output="-",
+ where="start_time > '2001-03-01'",
+ nprocs=4, overwrite=True, verbose=True)
+ self.assertModule(t_rast_what)
+ text = """cat|x|y|start|end|value
+1|115.0043586274|36.3593955783|2001-04-01 00:00:00|2001-07-01 00:00:00|200
+2|79.6816763826|45.2391522853|2001-04-01 00:00:00|2001-07-01 00:00:00|200
+3|97.4892579600|79.2347263950|2001-04-01 00:00:00|2001-07-01 00:00:00|200
+1|115.0043586274|36.3593955783|2001-07-01 00:00:00|2001-10-01 00:00:00|300
+2|79.6816763826|45.2391522853|2001-07-01 00:00:00|2001-10-01 00:00:00|300
+3|97.4892579600|79.2347263950|2001-07-01 00:00:00|2001-10-01 00:00:00|300
+1|115.0043586274|36.3593955783|2001-10-01 00:00:00|2002-01-01 00:00:00|400
+2|79.6816763826|45.2391522853|2001-10-01 00:00:00|2002-01-01 00:00:00|400
+3|97.4892579600|79.2347263950|2001-10-01 00:00:00|2002-01-01 00:00:00|400
+ self.assertLooksLike(text, t_rast_what.outputs.stdout)
def test_row_stdout_where_parallel2(self):
"""Here without output definition, the default is used then"""
