[GRASS-SVN] r71108 - in grass/trunk/gui/wxpython: lmgr xml
svn_grass at osgeo.org
Mon May 22 12:49:57 PDT 2017
Author: mmetz
Date: 2017-05-22 12:49:57 -0700 (Mon, 22 May 2017)
New Revision: 71108
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/xml/toolboxes.xml
grass/trunk/gui/wxpython/xml/wxgui_items.xml
wxGUI: use [r|v].import for simplified import with wizard and r.in.gdal|v.in.ogr for standard import
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2017-05-22 19:48:01 UTC (rev 71107)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2017-05-22 19:49:57 UTC (rev 71108)
@@ -326,9 +326,9 @@
# create 'command output' text area
self._gconsole = GConsole(
guiparent=self, giface=self._giface,
- ignoredCmdPattern='^d\..*|^r[3]?\.mapcalc$|^i.group$|^r.in.gdal$|'
+ ignoredCmdPattern='^d\..*|^r[3]?\.mapcalc$|^i.group$|^r.import$|'
'^r.external$|^r.external.out$|'
- '^v.in.ogr$|^v.external$|^v.external.out$|'
+ '^v.import$|^v.external$|^v.external.out$|'
'^cd$|^cd .*')
self.goutput = GConsoleWindow(
parent=self.notebook,
@@ -715,13 +715,13 @@
self.OnMapCalculator(event=None, cmd=command)
elif command[0] == 'i.group':
self.OnEditImageryGroups(event=None, cmd=command)
- elif command[0] == 'r.in.gdal':
+ elif command[0] == 'r.import':
self.OnImportGdalLayers(event=None, cmd=command)
elif command[0] == 'r.external':
self.OnLinkGdalLayers(event=None, cmd=command)
elif command[0] == 'r.external.out':
self.OnRasterOutputFormat(event=None)
- elif command[0] == 'v.in.ogr':
+ elif command[0] == 'v.import':
self.OnImportOgrLayers(event=None, cmd=command)
elif command[0] == 'v.external':
self.OnLinkOgrLayers(event=None, cmd=command)
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2017-05-22 19:48:01 UTC (rev 71107)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2017-05-22 19:49:57 UTC (rev 71108)
@@ -252,9 +252,9 @@
<toolbox name="ImportRasterData">
<label>Import raster data</label>
<items>
- <wxgui-item name="CommonFormatsImport"/>
- <module-item name="r.import">
- <label>Import of common formats with reprojection</label>
+ <wxgui-item name="CommonRasterFormats"/>
+ <module-item name="r.in.gdal">
+ <label>Import of common raster formats</label>
</module-item>
<separator/>
<module-item name="r.in.xyz">
@@ -304,9 +304,9 @@
<toolbox name="ImportVectorData">
<label>Import vector data</label>
<items>
- <wxgui-item name="CommonImportFormats"/>
- <module-item name="v.import">
+ <wxgui-item name="CommonVectorFormats"/>
+ <module-item name="v.in.ogr">
+ <label>Import of common vector formats</label>
</module-item>
<separator/>
<module-item name="v.in.ascii">
Modified: grass/trunk/gui/wxpython/xml/wxgui_items.xml
--- grass/trunk/gui/wxpython/xml/wxgui_items.xml 2017-05-22 19:48:01 UTC (rev 71107)
+++ grass/trunk/gui/wxpython/xml/wxgui_items.xml 2017-05-22 19:49:57 UTC (rev 71108)
@@ -211,17 +211,17 @@
<handler>OnDisplayCloseAll</handler>
<description>Close all open map display windows</description>
</wxgui-item>
- <wxgui-item name="CommonFormatsImport">
- <label>Common formats import</label>
+ <wxgui-item name="CommonRasterFormats">
+ <label>Simplified raster import with reprojection</label>
<handler>OnImportGdalLayers</handler>
- <related-module>r.in.gdal</related-module>
+ <related-module>r.import</related-module>
<description>Imports raster data into a GRASS raster map using GDAL library.</description>
<keywords>raster,import</keywords>
</wxgui-item>
- <wxgui-item name="CommonImportFormats">
- <label>Common import formats</label>
+ <wxgui-item name="CommonVectorFormats">
+ <label>Simplified vector import with reprojection</label>
<handler>OnImportOgrLayers</handler>
- <related-module>v.in.ogr</related-module>
+ <related-module>v.import</related-module>
<description>Imports vector data into a GRASS vector map using OGR library.</description>
<keywords>vector,import</keywords>
</wxgui-item>
