[GRASS-SVN] r71110 - in grass-addons/grass7/raster/r.modis: r.modis.download r.modis.import
svn_grass at osgeo.org
Mon May 22 15:05:27 PDT 2017
Author: lucadelu
Date: 2017-05-22 15:05:27 -0700 (Mon, 22 May 2017)
New Revision: 71110
grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
r.modis.download: added new product; fixed library import error messages
Modified: grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
--- grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2017-05-22 22:04:16 UTC (rev 71109)
+++ grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2017-05-22 22:05:27 UTC (rev 71110)
@@ -50,7 +50,7 @@
#% label: Name of MODIS product(s)
#% multiple: yes
#% required: no
-#% options: lst_terra_daily_1000, lst_aqua_daily_1000, lst_terra_eight_1000, lst_aqua_eight_1000, lst_terra_daily_6000, lst_aqua_daily_6000, ndvi_terra_sixteen_250, ndvi_aqua_sixteen_250, ndvi_terra_sixteen_500, ndvi_aqua_sixteen_500, ndvi_terra_sixteen_1000, ndvi_aqua_sixteen_1000, ndvi_terra_sixteen_5600, ndvi_aqua_sixteen_5600, snow_terra_daily_500, snow_aqua_daily_500, snow_terra_eight_500, snow_aqua_eight_500, surfreflec_terra_daily_500, surfreflec_aqua_daily_500, surfreflec_terra_eight_500, surfreflec_aqua_eight_500, water_terra_250
+#% options: lst_terra_daily_1000, lst_aqua_daily_1000, lst_terra_eight_1000, lst_aqua_eight_1000, lst_terra_daily_5600, lst_aqua_daily_5600, lst_terra_monthly_5600, lst_aqua_monthly_5600, ndvi_terra_sixteen_250, ndvi_aqua_sixteen_250, ndvi_terra_sixteen_500, ndvi_aqua_sixteen_500, ndvi_terra_sixteen_1000, ndvi_aqua_sixteen_1000, ndvi_terra_sixteen_5600, ndvi_aqua_sixteen_5600, snow_terra_daily_500, snow_aqua_daily_500, snow_terra_eight_500, snow_aqua_eight_500, surfreflec_terra_daily_500, surfreflec_aqua_daily_500, surfreflec_terra_eight_500, surfreflec_aqua_eight_500, water_terra_250
#% answer: lst_terra_daily_1000
#%end
#%option
@@ -156,9 +156,12 @@
def main():
try:
from rmodislib import product
+ except:
+ grass.fatal("r.modis library is not installed")
+ try:
from pymodis.downmodis import downModis
except:
- grass.fatal("r.modis library is not installed")
+ grass.fatal("pymodis library is not installed")
# check if you are in GRASS
gisbase = os.getenv('GISBASE')
if not gisbase:
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2017-05-22 22:04:16 UTC (rev 71109)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2017-05-22 22:05:27 UTC (rev 71110)
@@ -301,7 +301,10 @@
if target != basedir:
shutil.move(name, target)
if listfile:
- fdata = data + timedelta(prod['days'])
+ days = prod['days']
+ fdata = data + timedelta(days)
+ if days == 31:
+ fdata = datetime(fdata.year, fdata.month, 1)
listfile.write("{name}|{sd}|{fd}\n".format(name=basename,
sd=data.strftime("%Y-%m-%d"),
fd=fdata.strftime("%Y-%m-%d")))
