[GRASS-SVN] r71112 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Tue May 23 01:58:33 PDT 2017
Author: lucadelu
Date: 2017-05-23 01:58:33 -0700 (Tue, 23 May 2017)
New Revision: 71112
grass/trunk/lib/python/temporal/temporal_granularity.py
temporal library: added functions to return singular and plural granularity forms, improved gran_to_gran function
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2017-05-23 08:14:10 UTC (rev 71111)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2017-05-23 08:58:33 UTC (rev 71112)
@@ -1017,9 +1017,92 @@
gran += "s"
return "%i %s"%(num, gran)
+def gran_singular_unit(gran):
+ """Return the absolute granularity unit in its singular term
+ :param gran: input granularity
+ :return: granularity unit
+ .. code-block:: python
+ >>> import grass.temporal as tgis
+ >>> tgis.init()
+ >>> tgis.gran_singular_unit('1 month')
+ month
+ >>> tgis.gran_singular_unit('2 months')
+ month
+ >>> tgis.gran_singular_unit('6 seconds')
+ second
+ >>> tgis.gran_singular_unit('1 year')
+ year
+ if check_granularity_string(gran, 'absolute'):
+ output, unit = gran.split(" ")
+ if unit in PLURAL_GRAN:
+ return unit[:-1]
+ elif unit in SINGULAR_GRAN:
+ return unit
+ else:
+ lists = "{gr}".format(gr=SUPPORTED_GRAN).replace('[',
+ '').replace(']',
+ print(_("Output granularity seems not to be valid. Please use "
+ "one of the following values : {gr}".format(gr=lists)))
+ return False
+ else:
+ print(_("Invalid absolute granularity"))
+ return False
+def gran_plural_unit(gran):
+ >>> tgis.init()
+ months
+ months
+ seconds
+ years
+ return unit
+ return "{gr}s".format(gr=unit)
+ else:
+ '').replace(']',
+ else:
+ return False
def gran_to_gran(from_gran, to_gran="days", shell=False):
- """Converts the computed granularity of a STDS to a smaller
+ """Converts the computed absolute granularity of a STDS to a smaller
granularity based on the Gregorian calendar hierarchy that 1 year
equals 12 months or 365.2425 days or 24 * 365.2425 hours or 86400 *
365.2425 seconds.
@@ -1028,30 +1111,30 @@
:param to_gran: output granularity
:return: The output granularity
- .. code-block:: python
- >>> import grass.temporal as tgis
- >>> tgis.init()
- >>> tgis.gran_to_gran('1 month', 'days')
- '30.436875 days'
+ >>> tgis.init()
+ >>> tgis.gran_to_gran('1 month', 'days')
+ '30.436875 days'
- >>> tgis.gran_to_gran('1 month', 'days', True)
- 30.436875
+ >>> tgis.gran_to_gran('1 month', 'days', True)
+ 30.436875
- >>> tgis.gran_to_gran('10 year', 'hour')
- '87658.20000000001 hours'
+ >>> tgis.gran_to_gran('10 year', 'hour')
+ '87658.20000000001 hours'
- >>> tgis.gran_to_gran('10 year', 'minutes')
- '5259492.000000001 minutes'
+ >>> tgis.gran_to_gran('10 year', 'minutes')
+ '5259492.000000001 minutes'
- >>> tgis.gran_to_gran('6 months', 'days')
- '182.62125 days'
+ >>> tgis.gran_to_gran('6 months', 'days')
+ '182.62125 days'
- >>> tgis.gran_to_gran('1 months', 'second')
- '2629746.0 seconds'
+ >>> tgis.gran_to_gran('1 months', 'second')
+ '2629746.0 seconds'
- >>> tgis.gran_to_gran('1 month', 'seconds', True)
- 2629746.0
+ >>> tgis.gran_to_gran('1 month', 'seconds', True)
+ 2629746.0
#TODO check the leap second
msgr = get_tgis_message_interface()
@@ -1060,17 +1143,8 @@
unit = unit[:-1]
myunit = unit
- if to_gran in SINGULAR_GRAN:
- tounit = to_gran
- elif to_gran in PLURAL_GRAN:
- tounit = to_gran[:-1]
- else:
- lists = "{gr}".format(gr=SUPPORTED_GRAN).replace('[',
- '').replace(']',
- msgr.fatal(_("Output granularity seems not to be valid. "
- "Please use one of the following values : "
- "{gr}".format(gr=lists)))
+ tounit = gran_singular_unit(to_gran)
output = ast.literal_eval(output)
for k, v in CONVERT_GRAN.items():
if k == myunit:
@@ -1086,6 +1160,9 @@
return "{val} {unit}s".format(val=output, unit=tounit)
msgr.warning(_("Probably you need to invert 'from_gran' and 'to_gran'"))
return False
+ else:
+ return False
