[GRASS-SVN] r71116 - grass-addons/grass7/raster/r.modis/r.modis.import
svn_grass at osgeo.org
Tue May 23 06:26:16 PDT 2017
Author: lucadelu
Date: 2017-05-23 06:26:15 -0700 (Tue, 23 May 2017)
New Revision: 71116
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
r.modis.import: improved output files for t.register
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2017-05-23 09:47:46 UTC (rev 71115)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2017-05-23 13:26:15 UTC (rev 71116)
@@ -48,6 +48,10 @@
#% key: l
#% description: List more info about the supported MODIS products
#%end
+#%flag
+#% key: g
+#% description: Print output message in shell script style
+#%end
#%option
#% key: input
#% type: string
@@ -254,11 +258,6 @@
def import_tif(basedir, rem, write, pm, prod, target=None, listfile=None):
"""Import TIF files"""
- try:
- # try to import pymodis (modis) and some classes for r.modis.download
- from rmodislib import projection
- except:
- grass.fatal("r.modis library is not installed")
# list of tif files
pref = modis_prefix(pm.hdfname)
tifiles = glob.glob1(basedir, "{pr}*.tif".format(pr=pref))
@@ -266,11 +265,6 @@
tifiles = glob.glob1(os.getcwd(), "{pr}*.tif".format(pr=pref))
if not tifiles:
grass.fatal(_('Error during the conversion'))
- # check if user is in latlong location to set flag l
- if projection().val == 'll':
- f = "l"
- else:
- f = None
outfile = []
# for each file import it
for t in tifiles:
@@ -326,6 +320,7 @@
dat = datetime.strptime('{ye} {doy}'.format(ye=year, doy=doy), '%Y %j')
return dat.strftime('%Y-%m-%d')
def single(options, remove, an, ow, fil):
"""Convert the HDF file to TIF and import it
@@ -524,19 +519,22 @@
analyze = False
else:
analyze = True
+ # return the number of select layer from HDF files
if options['spectral']:
count = options['spectral'].strip('(').strip(')').split().count('1')
else:
count = 0
outfile = None
+ # check if file for t.register has to been created
if options['outfile']:
outfile = open(options['outfile'], 'w')
- elif flags['w'] and not options['outfile'] and count == 1:
+ if count > 1:
+ grass.warning("The spectral subsets are more than one so the final"
+ " name's files will be renamed")
+ elif flags['w'] and not options['outfile']:
outfile = tempfile.NamedTemporaryFile(delete=False)
- elif flags['w'] and count != 1:
- grass.warning(_("To use correctly the file in t.rast.import you have "
- "to select only a subset in the 'spectral' option. "
- "Out file will be not created"))
# check if import simple file or mosaic
if flags['m'] and options['input'] != '':
grass.fatal(_('It is not possible to create a mosaic with a single'
@@ -546,12 +544,42 @@
mosaic(options, remove, analyze, over, outfile)
else:
single(options, remove, analyze, over, outfile)
+ # if t.register file is create
if outfile:
outfile.close()
- grass.message(_("You can continue with temporal framework, registering"
- " the maps using t.register input=your_strds "
- "'file={name}'".format(name=outfile.name)))
+ # one layer only
+ if count == 1:
+ if flags['g']:
+ grass.message(_("file={name}".format(name=outfile.name)))
+ else:
+ grass.message(_("You can use temporal framework, registering"
+ " the maps using t.register input=your_strds "
+ "'file={name}'".format(name=outfile.name)))
+ # for more layer create several files with only a subset for each layer
+ elif count > 1:
+ tfile = open(outfile.name)
+ outfiles = {}
+ lines = tfile.readlines()
+ # get the codes from only one HDF
+ for line in lines[:count]:
+ code = line.split('|')[0].split('.')[-1]
+ outfiles[code] = tempfile.NamedTemporaryFile(delete=False)
+ # split the lines for each code
+ for line in lines:
+ outfiles[code].write(line)
+ if flags['g']:
+ message = ""
+ else:
+ message = "You can use temporal framework, registering the " \
+ "maps in different temporal datasets using " \
+ "t.register and \n"
+ tfile.close()
+ for fil in outfiles.values():
+ message += "'file={name}'\n".format(name=fil.name)
+ grass.message(_(message))
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
