[GRASS-SVN] r71136 - grass-addons/grass7/raster/r.modis/r.modis.import
svn_grass at osgeo.org
Thu May 25 00:32:31 PDT 2017
Author: lucadelu
Date: 2017-05-25 00:32:30 -0700 (Thu, 25 May 2017)
New Revision: 71136
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
r.modis.import: added new pymodis option, added try/except to maintain compatible also with older pymodis versions
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2017-05-24 13:46:44 UTC (rev 71135)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2017-05-25 07:32:30 UTC (rev 71136)
@@ -132,8 +132,11 @@
# read the file with the list of HDF
if opt['files'] != '':
- listoffile = open(opt['files'], 'r')
- basedir = os.path.split(listoffile.name)[0]
+ if os.path.exists(opt['files']):
+ listoffile = open(opt['files'], 'r')
+ basedir = os.path.split(listoffile.name)[0]
+ else:
+ grass.fatal(_("File {name} does not exist".format(name=opt['files'])))
# if mosaic create a dictionary
if mosaik:
filelist = {}
@@ -368,7 +371,10 @@
outname = outname.replace(' ', '_')
execmodis = convertModisGDAL(hdf, outname, spectr, res,
wkt=projwkt)
- execmodis.run()
+ try:
+ execmodis.run(quiet=True)
+ except:
+ execmodis.run()
import_tif(basedir=basedir, rem=remove, write=ow, pm=pm,
listfile=fil, prod=prod)
if options['mrtpath']:
@@ -416,7 +422,10 @@
basedir = targetdir
listfiles = [os.path.join(basedir, i) for i in listfiles]
cm = createMosaicGDAL(listfiles, spectr)
- cm.write_vrt(outname)
+ try:
+ cm.write_vrt(outname, quiet=True)
+ except:
+ cm.write_vrt(outname)
hdfiles = glob.glob1(basedir, outname + "*.vrt")
for i in hdfiles:
# the full path to hdf file
@@ -442,7 +451,10 @@
res = None
execmodis = convertModisGDAL(hdf, out, spectr, res, wkt=projwkt,
vrt=True)
- execmodis.run()
+ try:
+ except:
+ execmodis.run()
# remove hdf
if remove:
# import tif files
@@ -530,8 +542,8 @@
if options['outfile']:
outfile = open(options['outfile'], 'w')
if count > 1:
- grass.warning("The spectral subsets are more than one so the final"
- " name's files will be renamed")
+ grass.warning("The spectral subsets are more than one so the "
+ " output file will be renamed")
elif flags['w'] and not options['outfile']:
outfile = tempfile.NamedTemporaryFile(delete=False)
